The Checker 232 provides inspection of small features on production lines, detecting and inspecting up to 1,500 parts per minute. It is appropriate for applications in which small features are being inspected on large parts, such as the inspection of clips and springs on large automotive assemblies. The sensor also is appropriate for situations in which the vision sensor must be mounted far from the area of inspection. There is no limit to the number of part features that a single sensor can inspect, because the sensor uses multi-image analysis to determine if a part is present without an external trigger, which also enables it to track parts in varying positions along the production line.
Cognex Corp.
(508) 650-3000
www.cognex.com
