The Ashcroft 1305D series portable deadweight tester is a pressure calibration system that includes a low range and high range piston assembly, weight set, a hydraulic (oil) test pump to generate test pressures, metal carrying cases, tools and other accessories. Depending on the weight set provided, the 1305D is capable of establishing test points from 15 to 10,000 psi in an accuracy of ±0.1% of reading. DeadweightTester_IN
As a primary standard, the 1305D will provide years of accurate calibration measurement, helping to ensure that pressure instruments operate safely and reliably.
Ashcroft
(203) 385-0229
[email protected]
www.ashcroft.com/products
