When several devices need to be accurately sequenced in a machine vision system, the usual solution was to program a PLC to generate the necessary signals. However, a PLC is a significant investment and requires specialist knowledge to program the Relay Ladder Logic.
Manufacturers are grappling with multiple challenges—global competition, evolving quality standards, regulatory compliance, and profitability—not to mention a demanding, informed consumer. With no room for inefficiency in managing operations, companies have to rely on internal business processes to effectively support the enterprise.
When the temperature drops, so does the ability of many cars and trucks to safely and smoothly operate. To prevent this, automakers often turn to winter testing facilities and quality testing companies to verify their products’ durability and drivability on icy roads, through snow, and in temperatures well below 0 degrees Celsius.
You may be unfamiliar with the term “optical shaft metrology.” But you’ve no doubt experienced the advantages of this technology. Traveling by car or airplane, for example. In fact, it might surprise you to learn that anytime you’ve used a machine with an electric motor, a turbo charger, fuel injection, precision bearings, transaxles or spindles, chances are good you’ve benefited from optical shaft metrology.
The use of industrial vision as part of Industry 4.0 and smart factories has been discussed extensively in recent years, but requires machines to speak the same language.
Machine vision systems consist of several component parts, including illumination, lenses, camera, image acquisition and data transfer, and image processing and measurement software.
Increasingly complex customer and regulatory compliance requirements, tighter time-to-market schedules from customers who want greater product customization, and the constant pressure on costs and pricing make aerospace manufacturing one of the most challenging businesses in the world to compete in.
The load cell sensor is arguably the most important component in a force measurement or material testing system’s ability to provide accurate, precise and valid measurements. A sensor’s accuracy is often the primary characteristic that is used to specify a load cell sensor for a given application.
Hazard- and risk-based approaches to product design and manufacturing may be required by some standards, but they are also simply good practice. These approaches require a more holistic view of the product, intended use, skillset of users, materials, environment, and end-of-life.
The requirements of ISO 9001:2015 are viewed and implemented very differently by organizations, depending upon such variables as their size, resources, business sector, maturity, and external requirements.
