Featured Stories
Short, Sharp, Shock-- High Strain Rate Material Testing
May 19, 2003
Under routine operating conditions, many structural materials are sub-jected--either by accident or design--to high rates of loading, which can cause catastrophic failure or corresponding high rates of straining.
DAP Helps Eliminate Stacking Errors
May 19, 2003
Circular geometry measurements of rotors for gas turbine generators are important because the accurate assembly of these components has an impact on bearing life.
Machine Vision Boosts Assembly Line Quality
May 19, 2003
You can tell a lot about a Ford pickup truck if you know how to decode the letters and numbers--which Ford calls the truck's badge--mounted on the front fender panels.
Mailbag:<br>Quality Investments?
May 19, 2003
I read your editorial "New Ways to Invest" (June 2001, p. 8) with much interest. I must say that at first glance, the data and conclusions that you cite were very impressive.
Quality Begins with Good Data
May 19, 2003
The QS-9000 standard aims to prevent defects in procured parts, but many quality decisions are still made using incorrect information.
Manufacturer Has No Room for Error
May 19, 2003
High accuracy is of utmost importance to Group 5 Engineering Inc. (El Segundo, CA), which machines high-end parts for use in commercial aviation and custom home building.
Better Tooling Improves Product
May 19, 2003
A higher grade tooling system has helped improve product while contributing to dramatically reduced cycle Arial--in some cases by 50% or more--at Waukesha Cutting Tools (Waukesha, WI).
Bottle Closure Capacity Increases With CMM
May 19, 2003
A full-inspection cycle that used to require an entire day now takes about 40 minutes to complete.
In-Line Mobile Measurement
May 19, 2003
Performing in-line test, measurement and inspection in an automated, production environment requires a fast, accurate and robust system that can withstand the environmental challenges found on the factory floor.
Metrology and Calibration on the Web
May 19, 2003
For information on Metrology, the science of measurement, or calibration, a set of graduations to indicate values or positions, turn to the Internet. This month's Web site review looks at metrology and calibration related sites.
Multimedia
Videos
Podcasts
Bill Arbogast explains his perspective on quality, ISO 9001, and how to manage inevitable business changes.
Read: The 2013 Quality Professional of the Year
More Podcasts
THE MAGAZINE
Quality Magazine
magazine quality cover 2013 may audits
2013 May
Check out the May 2013 edition of Quality Magazine for features about Measurement, Software and Test & Inspection.
Table Of Contents Subscribe
Plant of the Year
Which is the most important factor in considering a Quality plant of the Year?
View Results Poll Archive
THE QUALITY MAGAZINE STORE
M:\General Shared\__AEC Store Katie Z\AEC Store\Images\Quality\prac-field-guide-for-iso.gif
A Practical Field Guide for ISO 9001:2008
The purpose of this field guide is to assist organizations, step by step, in implementing a quality management system (QMS) in conformance with ISO 9001:2008, whether from scratch or by transitioning from ISO 9001:2000. It examines each sub-clause of Sections 4–8 of ISO 9001:2008, which contain the requirements, and gives a list of the documentation/documents required, internal audit questions, a summary of management’s responsibilities, and a flowchart of the steps that need to be undertaken to satisfy the requirements.
More Products
Clear Seas Research
qcast_ClearSeas_logo.gifWith access to over one million professionals and more than 60 industry-specific publications,Clear Seas Research offers relevant insights from those who know your industry best. Let us customize a market research solution that exceeds your marketing goals.
eNewsletters
STAY CONNECTED
