If January is the month of resolutions, April is the month of renewals, a time of spring cleaning. Like people, businesses of all sizes undergo a similar ritual. Instead of tackling overstuffed closets, C-suite executives update their quarterly economic forecasts and prepare for the second half of the year.
Effective communication only happens when the intended message is expressed successfully by one person and received and understood by another. If executed correctly, it cuts down the unintended consequences that arise as a result of miscommunication.
With the advancements of many manufacturing processes, computed tomography (CT) and digital radiography (DR) are continuing to expand into new sectors of nearly all industries. Historically, these nondestructive testing (NDT) methods were primarily used for inspection of critical components, however, we are seeing an increasing number of companies extensively applying these technologies beyond just inspection work.
My work in inspection, and as a quality management system auditor, provides numerous opportunities to acquire knowledge. It also provides areas of risk for ensuring valid and reliable results.
Force measurement is the measure of a push (compression) or pull (tension) against an object. It sounds elementary enough, but it’s a crucial part of quality control testing with more and more applications in today’s globalized supply chain. The needs for force measurement are all around us.
The Thermo Scientific™ Niton™ Apollo™ handheld LIBS analyzer gives users confidence when engaging in Quality Control (QC) and Positive Material Identification (PMI).
Ever since the revolution of Henry Ford’s assembly line, it has been possible to produce identical complex products in drastically less time. It was the inception of mass production as we know it today.
