Fixed Focal Length Lenses
November 26, 2007
These lenses are designed for high-speed, high-resolution imaging, making them suited for online inspection applications.
3-D Video Microscope
October 30, 2007
SurPhase is a stand-alone 3-D video microscope integrating a high-resolution CCD camera, controlled LED illumination and an objective turret with six positions for sample analysis in reflection. It is suited for 3-D surface characterization, combining 2-D video microscopy and 3-D measurement capabilities. The microscope is certified and verified with a traceable calibration standard and provides measurements in the nanometer resolution range according to ISO standards. Automatic acquisition and processing are performed by the GetPhase software package.
Laser Probe
October 29, 2007
The ScanShark V5 laser probe is an addition to the company’s portable inspection and reverse engineering system. A ScanShark system includes the company’s seven-axis Infinite portable CMM, a ScanShark V5 laser scanning probe, PolyWorks software and a laptop or desktop computer. The mobile metrology system delivers the power of articulated arm measurement and laser scanning for on-demand part inspection and reverse engineering right on the shop floor. The V5 can deliver 458,000 points per second scanning speed, nearly 20X greater than the previous version, with a point-to-point resolution of 12 microns, and a 140-millimeter-wide laser stripe. A proprietary integrated rangefinder simplifies the scanning process for the operator. The V5 is capable of scanning reflective surfaces and varying colors without applying surface preparation.
FireWire Digital Camera System
October 29, 2007
The Spot RT3 Slider digital camera system combines performance and FireWire connectivity. The system has optical color rendering, particularly when used with Spot Imaging software featuring Correct Color Technology/ICC color profiling. The performance of the RT3 Slider, along with the built-in flexibility of both color and monochrome imaging in one camera, makes the camera suited for core laboratory imaging needs. Low read noise and deep pixel wells of its Kodak KAI 2020 CCD make it a sensitive imaging system. With effective differential cooling of -43 C, dark current has been reduced to under 0.003 e/p/s, making the camera suited for fluorescence imaging. Spot Basic Image Capture software is included with each RT3 Slider camera and can be enhanced to include macro scripting and peripheral device control.
General-Purpose Laboratory Software
October 29, 2007
Bluehill Lite is a general-purpose software package that provides a range of tailored application solutions. It is to be used for fundamental applications and standardized tensile, compression, flexure, peel, tear, friction and simple cyclic test requirements. The software is compatible with all of the company’s 3300 Series universal test systems, and has a Web-like interface that consolidates testing, test method definition and reports, and system administration. The software is divided into color-coded tabs and has a distinct home screen for ease of navigation. Designed with screens that are tailored to the application requirements of each test type, parameters such as fixture setup, test terminology, unit choices and calculations are configured automatically.
Air-Actuated Connectors
October 29, 2007
CTS Connect air-actuated internal or external connectors are for sealing smooth, rough or threaded circular features of a part. The connectors consist of an air-driven internal piston that compresses the urethane seal material against the surface of the part, creating a tight seal that meets all test pressure requirements, regardless of surface shape or finish. The connectors are ideal for leak testing, filling, cleaning, burst or pressure testing, flushing, charging, integrity, sealing and part handling in a variety of industries including automotive, medical, appliance, industrial and military.
Digital Readout System
October 29, 2007
The Quadra-Chek 300 is a digital readout system now with image archiving. This capability allows operators to store measured part features, including test data and descriptive text, as JPG. images for documenting, testing and quality inspection purposes. The system uses proprietary technology to combine multiple video measuring functions in a single display unit, including video display, cross line generator and automated edge detection for improved accuracy, increased measuring speed and reliability. It has a high-resolution LCD monitor, plus integrated direct camera input that provides live feed video display. The system’s programming features include alphanumeric program naming, operator messages and arrow-to-target stage directions to operators.
Fixed-Bridge CMM
October 29, 2007
The VideoCheck is a fixed-bridge type multisensor coordinate measuring machine with a patented Z-axis ram design that allows easy integration of additional sensors for increased productivity. The measuring capacity extends up to 15.7 inches (400 millimeters) in X axis and 7.8 inches (200 millimeters) in the Y axis. Typical applications are in the automotive, electro, plastics, rubber good, watch and glass industries.
Finite Element Analysis Software Suite
October 29, 2007
Abaqus Version 6.7, a finite element analysis software suite, now has a new architecture for high-performance linear dynamics, advanced capabilities for composites simulation and nonlinear materials modeling. The software also has an intuitive and customizable interface for accelerated model building and results visualization, as well as two new interfaces for CAD associativity. The new linear dynamics architecture is fully integrated with existing nonlinear capabilities, enabling engineers to share model data and results across workgroups. The release provides a unified simulation environment for general-purpose structural integrity, power train durability, noise and vibration behavior, crashworthiness, occupant safety and tire-roadway interaction.
Portable CMM
October 29, 2007
The MicroScribe X portable CMM features data collection with SmartCapture trigger for continuous or single-point data collection with a variety of tips; an electromechanical brake to help prevent arm damage; application-specific calibration for increased accuracy; a verification gage; and software included for accuracy self-check. The unit comes with a standard three-year warranty, and the customer chooses which third-party software to use. Re-certification procedures can be done at either an authorized center or on-site for reduced down time and no shipping risk or expense.
Multimedia
Videos
Podcasts
Bill Arbogast explains his perspective on quality, ISO 9001, and how to manage inevitable business changes.
Read: The 2013 Quality Professional of the Year
More Podcasts
THE MAGAZINE
Quality Magazine
june 2013 magazine cover
2013 June
Check out the June 2013 edition of Quality Magazine for features about Measurement, Software and Test & Inspection.
Table Of Contents Subscribe
Plant of the Year
Which is the most important factor in considering a Quality plant of the Year?
View Results Poll Archive
THE QUALITY MAGAZINE STORE
M:\General Shared\__AEC Store Katie Z\AEC Store\Images\Quality\prac-field-guide-for-iso.gif
A Practical Field Guide for ISO 9001:2008
The purpose of this field guide is to assist organizations, step by step, in implementing a quality management system (QMS) in conformance with ISO 9001:2008, whether from scratch or by transitioning from ISO 9001:2000. It examines each sub-clause of Sections 4–8 of ISO 9001:2008, which contain the requirements, and gives a list of the documentation/documents required, internal audit questions, a summary of management’s responsibilities, and a flowchart of the steps that need to be undertaken to satisfy the requirements.
More Products
Clear Seas Research
qcast_ClearSeas_logo.gifWith access to over one million professionals and more than 60 industry-specific publications,Clear Seas Research offers relevant insights from those who know your industry best. Let us customize a market research solution that exceeds your marketing goals.
eNewsletters
STAY CONNECTED
