Electronic devices have become common in today’s modern society. Chances are everyone may have come across and utilized a silicon wafer indirectly with their usage of electronic devices.
Silicon, the Core Material of Semiconductors
Silicon wafer is a thin substrate of semiconductor material which is used in electronics for integrated circuits fabrication. There are many types of semiconductor materials and one of the most commonly used semiconductor material in electronics is Silicon (Si).
Silicon wafer is a key component in integrated circuits. It is formed from highly pure, nearly defect-free, monocrystalline silicon thinly sliced from a silicon boule. It serves as the substrate for microelectronic devices built in and over the wafer. The wafer undergoes many microfabrication process steps such as masking, etching, doping, and metallization.
Integrated circuit has become the principal components of almost all electronic devices. Integrated circuit, commonly referred to as an IC, is a microscopic array of electronic circuits and components that has been implanted onto the surface of a single crystal of semiconductor material such as Silicon (Si). It is called integrated circuit because the components, circuits and base material are all made together out of a single piece of silicon wafer. Hundreds of integrated circuits are made at the same time on a single, thin slice of silicon wafer and then they are cut apart into individual IC chips.
Silicon Cracks Jeopardize End-Product Quality
Wafers accumulates residual stress during the growth, sawing, grinding, etching and polishing process. Cracks may be generated throughout the process, and if undetected, the wafers that survived can be rendered unusable in subsequent manufacturing stages. Cracks may also happen when the integrated circuits are cut into individual IC. Therefore, inspecting the raw material substrate for impurities before processing and detecting defects during processing is critical to keep the costs down.
Infrared Imaging Detects Cracks Inside Silicon Substrate
Silicon has the property to be transparent to infrared light. As a result, Indium gallium arsenide (InGaAs) cameras, operating in the SWIR wavelength band from 900 nm to 1700 nm, allow users to see through semiconductor silicon substrates. The ability to see through these semiconductor materials offers great benefit to the manufacturing process because infrared images highlight defects such as cracks inside the silicon wafer.
Radiant Optronics, a technology company headquartered in Singapore, is specialized in applying the latest technology developments to failure analysis applications with a strong focus in the Semiconductor field, wafer fabrication, service laboratories, packaging and PCB assembly in Asia. The company’s diverse customer base includes organizations in the Electronics, Semiconductor, R & D Institutions and BioTech sectors.
Manufacturer of integrated circuits (IC) use Radiant Optronics’ Infrared Imaging Microscopes fitted with Allied Vision’s SWIR camera, Goldeye G-008, to inspect the IC for internal defects or cracks which might happen during the manufacturing process.
Allied Vision’s Goldeye models are short-wave infrared cameras (SWIR) building on high performance InGaAs sensors which are designed to fulfill the highest industrial standards. All Goldeye cameras are equipped with an active thermo-electric cooling device (TEC1) to delivery low-noise images regardless of the ambient temperature. Their robust, compact housing with fan-less cooling system provides multiple mounting option for easy system integration.
“The Goldeye G-008 is a low-resolution model with an affordable price. The low resolution is sufficient to detect the defects, so it is the ideal choice for this cost-sensitive application. Our customers can benefit from the Goldeye’s outstanding performance and we enjoy support from Allied Vision’s Asia-Pacific office just next door in Singapore,” stated Christopher Cheong, director of Radiant Optronics.
With increasing demand of electronics in society, semiconductor fabrication plants and integrated circuit manufacturers are manufacturing higher quantities of wafers and IC to fulfill the demand. The escalating demand is driving the industry to use advanced imaging technologies for quality control. This is critical to keep the costs down. The Goldeye G-008 is the fastest 1/4-VGA resolution SWIR with GigE Vision interface. With frame rates up to 344 fps at full resolution, versatile application fields can be addressed, and manufacturing processes can be improved tremendously.
