Before you choose a QMS, ask who actually owns it
Quality leaders spend years building their quality programs, designing workflows, training teams and earning organizational buy-in. Then they discover that a meaningful portion of what they built doesn't belong to them.
The culprit is usually the platform underneath.
When a QMS is built on top of a third-party platform, the platform's priorities become your constraints. Its update schedule becomes your revalidation calendar. Its storage pricing becomes your budget variable. Its licensing model becomes the ceiling on how far quality participation can reach across your organization.
This platform dependency doesn't appear on day one. It shows up gradually as:
- Unexpected overage invoices
- Forced updates that trigger a revalidation cycle
- Simple workflow changes that require IT involvement or a vendor call because the configuration layer isn't yours to touch
Problem 1: The updates
In regulated industries, such as medical devices, pharma and aerospace, every software change needs to be validated. It’s not optional, and it’s not cheap.
When a platform like Salesforce pushes updates on its own schedule, any QMS built on top of it inherits that timeline. Your revalidation work gets scheduled around someone else's release cycle, not yours. If you’re operating a single site, then it’s just a disruption. If you’re operating across multiple sites with complex processes dependent on the system, it becomes a recurring operational burden that compounds every time the platform decides it's time to update.
A QMS provider that owns and manages its own release cycle gives you control over your timeline. Changes happen when your organization is ready for them, not when a platform vendor decides they should.
Problem 2: The cost structure
Licensing and storage costs that seem manageable at the point of purchase tend to reveal themselves as programs mature. Per-user, per-seat licensing models create a wall every time you want to expand quality participation, such as a new facility, onboarding a new supplier or giving frontline workers visibility into quality processes.
Each expansion comes with a line item. The program grows, and so does the bill.
Storage works similarly. Quality management continuously generates data. And those documents, audit records, CAPAs, attachments, inspection records and more cost money to store on a third party.
Every time you add data, you pay that platform's rates and absorb any overage fees as the program matures. The more seriously you take quality, the more you're penalized for it.
Problem 3: The configuration
If quality processes stayed static, you’d be okay. But they don’t. Regulations change, products evolve and organizations grow into new markets. A quality program that can't adapt to those changes without involving IT or a vendor is a liability.
When configuration requires specialist access or external support for even routine changes, the quality team loses practical ownership of the system they're supposed to be running. Drag-and-drop, no-code configurability is often the difference between a quality team that can respond to change and one that has to file a ticket and wait.
The case for true ownership
None of this means that quality leaders shouldn't evaluate platforms carefully, or that third-party integrations don't have value. What it means is that the question of ownership deserves to be part of the evaluation from the start.
A QMS you truly own is one where:
- Your team controls the configuration without external dependencies
- Updates happen in a way you can plan for
- Expanding quality participation across the organization doesn't trigger a licensing conversation
- The data your program generates lives in infrastructure you control
No matter which QMS you go with, if it depends on a platform to run, you depend on that platform, too. Make sure it will scale with you.
Want to see what true QMS ownership looks like in practice? Schedule time to set up a personalized demo of Reliance.
