Dimensional Measurement System
August 31, 2007
The SmartScope Flash 625 dimensional measurement system is a small-footprint floor stand system featuring a 500- by 610- by 200-millimeter XYZ measurement volume, with the added flexibility of a 300-millimeter extended Z-axis option. Additionally, the system can be equipped with a through-the-lens (TTL) laser, adding noncontact surface contouring to its touch probe, video and micro-probe measuring capability. The system also is configurable with sensors for almost any application. The system’s optical assembly moves in the X-axis across an angled steel crossbeam while the part moves in the Y-axis on a precision servo-driven stage. Both axes use high-resolution scales for positional feedback. A metrologically stable granite platform ensures proper damping and structural integrity. And integral system electronics minimize the system’s footprint while maximizing stage travel.
    Optical Gaging Products (OGP)
    (800) 647-4243
    www.ogpnet.com
    Booth 7513
    Reply 644
Replacement Contracers
August 31, 2007
A complete line of replacement contracers and surface testers is available. The replacement parts for popular indicators- including Mitutoyo, Renishaw, Zeiss and Mahr–--are in stock and available for immediate shipment. In addition, custom-manufactured surface testers and contact points are available. Also, the repair of existing equipment also is offered.
Calibration Management Software
August 31, 2007
GAGEtrak calibration management software manages the forecasting the workload, reduces costs and provides compliance with equipment calibration standards. The software monitors gage calibration schedules, gage locations, calibration history, calibration certificates and integrated gage R&R, while providing the operator with thorough reports for improved analysis capabilities. GAGEtrak is ISO 9000, QS-9000, ISO-ANSI 17025, TS 16949 and FDA 21CFR Part 11 compliant.
Tomography System
August 31, 2007
Metrotom is a computed tomography system for industrial applications such as R&D, production and quality. The system can see inside parts and quantify characteristics normally inaccessible to probing or optical sensors. The same dataset can be used to inspect the structure of material (porosity/wall thickness), measure external features and generate fully surfaced or solid CAD models. X-rays penetrate an object and display it on a suitable detector. The details of the object appear as a 2-D image in varying intensity depending on the geometry and absorption properties. The 3-D image is created by rotating the object 360 degrees along its axis on a rotary table and then converting this data to a 3-D volume model.
    Carl Zeiss Industrial Metrology
    (763) 744-2409
    www.zeiss.com
    Booth 7007
    Reply 632
Hardness Tester Upgrades
August 31, 2007
The Minuteman ELT Series of semi- and fully automatic systems for Knoop, Vickers and Rockwell hardness testing is available in four different versions. The entry level ELT1, the intermediate ELT2 and the fully automatic ELT3 are options for the Tukon microindentation testers, while the ELT4 version is for Rockwell and MicroRockwell testers. When used on a microindentation tester, the Minuteman ELT series is an upgradeable system that allows the operator to start with a low-cost basic system and progress to a fully automatic version as their needs and budget change. All of the Minuteman ELT systems feature complete computer control of the tester for hands-off operations.
Digital Microscope Camera
August 31, 2007
The ProgRes CT3 is a digital microscope camera with CMOS Sensor technology. The unit provides resolution of up to 3 megapixels and a subtle color differentiation. The integrated CMOS sensor is resistant against blooming and shows superior performance in imaging highlights. The fast live image, available in several resolutions, meets the requirements of professionals and fits easily into any laboratory. Configured with standard interfaces such as C-Mount and IEEE1394 Firewire, the unit easily connects to any microscope and computer. The unit includes ProgRes CapturePro image acquisition software designed for intuitive handling. The unit is dedicated to brightfield and reflective light microscopy, but also is suitable for many other contrast methods.
CMM inspection System
August 31, 2007
Renscan5 software and the REVO measuring head compose a system for ultra-high-speed scanning in coordinate measuring machine (CMM) inspection of critical and complex parts. The system combines a dynamic, infinite positioning measurement head with 5-axis machine control and a laser-corrected probe to measure at speeds up to 500 millimeters per second. (vs. conventional CMM scanning at 5 to 15 millimeters per second). Renscan5 helps eliminate the measurement errors normally associated with three-axis scanning systems. The five-axis system achieves this by allowing the REVO measuring head to perform most of the motion during inspection routines.
CAD-Based Inspection Software
August 31, 2007
The latest version of CAD-based inspection software PowerINSPECT includes support for multi-axis on-machine verification, improved ease of use and compatibility with the AIMS Metrology system. The new compatibility with AIMS will allow seamless sharing of CAD geometry, inspection plans and measurement results between PowerINSPECT and other hardware and software platforms. The multi-axis option for on-machine verification will allow companies with four-, five- or six-axis equipment to undertake comprehensive verification of their parts on complex machine tools both during and after machining. The main advantage of the new option will be the ability to check undercut regions without any need to reposition the work piece.
Prox Light
August 29, 2007
The Prox Light comes with a Light One 5-watt high-current LED 24VDC, 30-millimeter barrel sensor housing and constant current driver. The unit also has a built-in strobe NPN/PNP trigger control, intensity control/internal pot or 0 through 10 VDC analog signal and three filters-thin file, opaque and polizer. The unit will work with any M12-5 pin connector, and will mount with any 30-millimeter barrel bracket.
Smart Vision Lights
(231) 744-4652
www.smartvisionlights.com
Reply 699
Vision Appliances
August 29, 2007
IPD VA3X vision appliances provide quick setup, factory-friendly wiring and support for one or two cameras with choice of sensor resolution. Available in two versions, the VA3X offers operators choice and flexibility to satisfy their near and long-term application needs. The VA30 comes with iNspect software, while the sister VA31 version includes Sherlock. The vision appliances can be positioned alongside other automation controllers, with the benefit of small camera heads for easy mounting. The dual camera capability of the product also provides significant cost savings in multi-camera applications. The units have industrial grade I/O and external connections located on the front, and include status lights for every input and output connection to help application debugging. On the sensor side, the VA3X provides operators with many resolution choices, from presence and absence to high-precision measurements. Standard supported sensor resolutions are 640 by 480 and 1024 by 768; however, higher resolutions to 1600 by 1200 are possible.
Dalsa IPD
(978) 670-2002
www.goipd.com
Reply 698
Multimedia
Videos
Podcasts
Bill Arbogast explains his perspective on quality, ISO 9001, and how to manage inevitable business changes.
Read: The 2013 Quality Professional of the Year
More Podcasts
THE MAGAZINE
Quality Magazine
magazine quality cover 2013 may audits
2013 May
Check out the May 2013 edition of Quality Magazine for features about Measurement, Software and Test & Inspection.
Table Of Contents Subscribe
Plant of the Year
Which is the most important factor in considering a Quality plant of the Year?
View Results Poll Archive
THE QUALITY MAGAZINE STORE
M:\General Shared\__AEC Store Katie Z\AEC Store\Images\Quality\prac-field-guide-for-iso.gif
A Practical Field Guide for ISO 9001:2008
The purpose of this field guide is to assist organizations, step by step, in implementing a quality management system (QMS) in conformance with ISO 9001:2008, whether from scratch or by transitioning from ISO 9001:2000. It examines each sub-clause of Sections 4–8 of ISO 9001:2008, which contain the requirements, and gives a list of the documentation/documents required, internal audit questions, a summary of management’s responsibilities, and a flowchart of the steps that need to be undertaken to satisfy the requirements.
More Products
Clear Seas Research
qcast_ClearSeas_logo.gifWith access to over one million professionals and more than 60 industry-specific publications,Clear Seas Research offers relevant insights from those who know your industry best. Let us customize a market research solution that exceeds your marketing goals.
eNewsletters
STAY CONNECTED
