  • HOME
  • PROCESS CONTROL
  • QUALITY ANALYTICS
  • SIMULATION
  • Quality Home
Next Generation SPC & Quality AnalyticsSoftwareReal Time Statistical Process Control
Making Capability Studies Work for You
Two factory workers in blue overalls and white safety hats and safety eyewear, working in at factory.
Image Source: eyesfoto / E+ / Getty Images
July 7, 2025
Capability studies are a routine part of quality work. Teams often calculate indices, document the results and share them to show that a process can meet specifications or satisfy audit requirements. But when applied proactively, capability studies offer insight into how a process is performing and where small changes might bring it into even tighter control.
The key is knowing when and how to use them, and making sure the data you're working with is reliable in the first place.
First, a capability study is only as good as the process it measures. That means the process needs to be stable. If your data shows a pattern of shifting averages, or if you’re chasing points that jump outside control limits, that’s a sign the process isn’t in statistical control. In this phase, any capability index you calculate won’t be meaningful. Before you begin, use a control chart to verify process stability.
Next, it’s important to understand what your capability index is actually telling you. Capability Process, or Cp, looks at the spread of your process compared to the tolerance width, assuming the process is centered. Process Capability Index, or Cpk, adjusts for any off-centeredness by comparing each tail to the spec limit. So, while a Cp of 1.33 might suggest your process has potential, a much lower Cpk might reveal a centering issue that needs attention. Looking at both gives a fuller picture.
Of course, none of that matters if your data is flawed. Measurement systems analysis is a precursor to capability work. A gage R&R study can help determine whether variation in your data comes from the part or the measurement system itself. If your gage isn’t consistent or precise, your capability indices won’t reflect the true process.
Capability studies also shouldn’t be treated as one-and-done exercises. Over time, processes drift. Inputs change. People, machines and materials introduce potential variability. Running periodic capability studies helps maintain awareness of those shifts and catch early signs that a process may no longer meet requirements.
When capability indices fall short, they can help point to where improvements might make the most impact. A high Cp but low Cpk might call for re-centering the process. A low Cp might mean the process variation is simply too wide, and you’ll need to reduce variation (perhaps through equipment upgrades, training or tighter control on inputs).
When used thoughtfully and supported by good data, capability studies can help quality professionals drive meaningful improvement.
KEYWORDS: data Measurement System Analysis (MSA) quality professionals
MiniTab Whitepaper download
