Home » Topics » New Products
New Products RSS Feed RSS
Solder Inspection
July 30, 2009
The VT-S700 in-line system for soldered component inspection uses a telecentric lens with a two-megapixel camera to reduce image distortion and improve inspection accuracy at the edges of its field of view.
X-ray Imaging
July 30, 2009
The Y.Cheetah is an X-ray imager that combines the company’s Feinfocus X-ray technology with high-speed flat panel detector technology.
Articulating Borescopes
July 30, 2009
BoresEyes DC Series articulating borescopes are available with two- or four-way articulation in 5.5-, 6-, 8- and 11-millimeter diameter from 10 inches to 16 feet.
Weld Inspection
July 30, 2009
The WeldRover is an automated scanner for nondestructive testing (NDT) on metal plate, pipes, vessels and welded components from 4 inches in diameter to flat surfaces.
Handheld Laser Scanner
July 1, 2009
The LaserGauge HS701 DSP sensor is a handheld laser profiler with on-board processing, nonvolatile memory and a color LCD.
Leak Test Instrument
July 1, 2009
The Sentinel C-28 leak tester provides pressure decay, pressure drop, pressure loss over time and occlusion tests.
Compliance Software
July 1, 2009
ComplianceBuilder is an add-on compliance solution that is specifically integrated with the company’s Bluehill software.
Pressure Gage
July 1, 2009
The DXD digital pressure transducer is available with a LabVIEW driver and a LabVIEW-based utility software that allows operators to address, configure and monitor one or more of the gages.
Materials Simulation
July 1, 2009
Abaqus 6.9 is a unified finite element analysis (FEA) product suite used by designers, engineers and researchers in a range of industries.
Cylindricity Measurement
July 1, 2009
The MMQ 200 Formtester measures cylindricity and other deviations of form and position.
Previous 1 2 … 126 127 128 129 130 131 132 133 134 … 140 141 Next
