The simple shaft is one of the ubiquitous items in every mechanical system. Shafts contain a number of key functional elements, such as splines, tapers, grooves, threads, cams and gears, which all have associated critical dimensions to allow these mechanical systems to perform the function for which they were designed.
If you were to ask an assembler at a Tesla factory how they measure the diameter of a piston, the response could very well be “what’s a piston?” If the same question were asked, a traditional combustion engine assembler would likely exclaim “with calipers, of course!”
The Quality Show will provide an opportunity for ZEISS Industrial Quality Solutions to look back at 100 years of company history, thanking its customers for their trust and loyalty while focusing on the theme, Connect to Productivity, moving forward.
Optical measurement refers to noncontact measurement using various light sources. It usually requires at least one lens, a light source and a detector.
Readers of this column will be familiar with the subject of measurement uncertainty since I comment on it from time to time, as I did last month. Those readers that have not been that interested in it will certainly run across it on reports from their calibration sources.
