Knoop/Vickers testers
August 14, 2007
The 400 Series of Knoop/Vickers testers provides a microhardness testing solution for Knoop and Vickers testing of metals, ceramics and other non-metallic materials. The series is available with manual or automatic turrets. Having eight dial-selectable test forces ranging from 10 grams to 1,000 grams, the system can be adjusted to the correct setting for the specific specimen being tested. An optional 2,000-gram test force system is available. Equipped with optics that have a total magnification of 100X and 400X, the operator can measure the indention made during the test. The series is equipped with a 100 millimeter by 100 millimeter precision XY stage with 25-millimeter movement in each direction.
Instron
(800) 695-4273
www.wilsoninstruments.com
Reply 714
  • ij
    Buehler Obtains ISO Certification for Vickers and Knoop Reference Hardness Testing Blocks
  • Phase II Micro Vickers Hardness Testers
  • Vickers Hardness Tester
  • Lean Automation DVD
  • The Quality Toolbox, Second Edition
  • July 29, 2025
  • Sun-Tec Corp.
    Sun-Tec Corporation specializes in Rockwell-type, Brinell, Vickers & Knoop, Leeb, Tensile/Compression, Ductility testing equipment. We also supply hardness standards, indenters, and anvils. Clark Instrument, Detroit Testing Machine, Service Physical Testers and Gogan are divisions of Sun-Tec: offering an extensive product line. Sun-Tec is a 17025 accredited company.
