Home » Topics » Channels » Measurement
Measurement RSS Feed RSS
Rubber Process Analyzer
September 29, 2009
The RPA 8000 rubber process analyzer is a dynamic mechanical rheological test instrument that measures the properties of polymer and rubber compounds before, during and after the cure.
Surface/Contour Measurement
September 29, 2009
The Surfcom 1900SD2 produces both surface and contour measurements.
Measuring Scanner
September 29, 2009
The FlatScope scanner provides inspection of flat workpieces and extrusion profiles in a production environment.
Length Measurement
September 29, 2009
The Linear 100 is a universal length measuring instrument for rapid internal and external measurements on the shop floor.
Modular Fixturing
September 2, 2009
Modular fixturing is available for coordinate measuring machines (CMMs) and machine vision systems.
Optical Metrology
September 2, 2009
The MarSurf WS 1 optical surface metrology system uses white light interferometry to achieve vertical resolution of 0.1 nanometer and provide 3-D measurement.
Tactile-Optical Measurement
September 2, 2009
The Fiber Probe is a tactile-optical sensor that can have a contact sphere with a diameter between 20 and 300 micrometers.
Worker measuring detail
Understand Gage R&R
Rick Sloop
September 1, 2009
Any quality professional worth his keep knows that gage repeatability and reproducibility (R&R) studies are a critical part of a successful process control system, but it is amazing how many do not understand how to properly conduct a study or how to interpret the results.
Videoscope
August 3, 2009
The Techno Pack XT videoscope has recessed wheels, retractable handle and a lightweight design.
ID/OD Measurement
August 3, 2009
The Labmaster Universal is a laser-based ID/OD measuring instrument for gage calibration laboratories that need to precisely measure length, outside diameter, inside diameter, threads and gage standards.
Previous 1 2 … 111 112 113 114 115 116 117 118 119 Next
