Home » Topics » New Products » Featured Products
Featured Products RSS Feed RSS
Portable 4-20mA Calibrator
November 26, 2007
The model 420 is for calibration/test of DPMs, PLCs, transmitters, sensors or any other device requiring a 4- to 20-milliampere current loop signal.
Wireless Data Loggers
November 26, 2007
The RTR-5 family of data loggers is portable and waterproof with battery life up to two years. These units are suited for wet, freezing or high humidity environments.
Laser Tracker Reflectors
November 26, 2007
A line of high-precision break resistant reflectors (BRR) for use with the company’s laser trackers is available, compatible with all models of the company’s laser tracker in a full range of up to 40 meters.
USB Cameras
November 26, 2007
The Lw570 and Lw575 Series of color megapixel USB 2.0 cameras are for use in industrial and scientific applications where high-resolution and low-light performance are required.
Noncontact CMM
November 26, 2007
The Maxos CMM solution includes a noncontact light probe, a bridge or horizontal gantry, a turntable option, installation, custom programming, training and maintenance.
Spring Testing System
November 26, 2007
The SF1390 is a motor-driven spring testing system designed to perform testing on tension and compression springs and other spring-type products.
Dry-Block Calibrator
November 26, 2007
The JOFRA CTC 1200A dry-block calibrator ensures accurate, high-temperature calibrations despite power supply instability because it is equipped with mains power variance immunity (MVI)-a proprietary circuitry design developed to continuously monitor supply voltages and ensure a constant and stable energy flow to the dry block’s heating elements.
Fixed Focal Length Lenses
November 26, 2007
These lenses are designed for high-speed, high-resolution imaging, making them suited for online inspection applications.
3-D Video Microscope
October 30, 2007
SurPhase is a stand-alone 3-D video microscope integrating a high-resolution CCD camera, controlled LED illumination and an objective turret with six positions for sample analysis in reflection. It is suited for 3-D surface characterization, combining 2-D video microscopy and 3-D measurement capabilities. The microscope is certified and verified with a traceable calibration standard and provides measurements in the nanometer resolution range according to ISO standards. Automatic acquisition and processing are performed by the GetPhase software package.
    Armstrong Optical Ltd.
    +44 (0) 1604 654220
    www.armstrongoptical.co.uk
    Reply 612
Laser Probe
October 29, 2007
The ScanShark V5 laser probe is an addition to the company’s portable inspection and reverse engineering system. A ScanShark system includes the company’s seven-axis Infinite portable CMM, a ScanShark V5 laser scanning probe, PolyWorks software and a laptop or desktop computer. The mobile metrology system delivers the power of articulated arm measurement and laser scanning for on-demand part inspection and reverse engineering right on the shop floor. The V5 can deliver 458,000 points per second scanning speed, nearly 20X greater than the previous version, with a point-to-point resolution of 12 microns, and a 140-millimeter-wide laser stripe. A proprietary integrated rangefinder simplifies the scanning process for the operator. The V5 is capable of scanning reflective surfaces and varying colors without applying surface preparation.
    Romer Inc.
    (800) 218-7125
    http://us.romer.com
    Reply 608
Previous 1 2 … 17 18 19 20 21 22 23 24 25 … 28 29 Next
