Home » Topics » The Quality Industry Voices » The Quality Edge
The Quality Edge
The Quality Edge  RSS Feed RSS
Young man industrial engineer wearing a white helmet while check the welding on the production line in the factory.
The Quality Edge
ITAF Rule 6 Changes
The transition to the new Rules 6 must be completed by January 1, 2025, after which they will be mandatory for all audits.
QM 0322 Professional of the Year John Vandenbemden
John Vandenbemden
October 14, 2024
The sixth edition of the IATF Rules, released on March 31, 2024, introduces significant changes to certification requirements, including a shift to performance and risk-based audits. These updates, aimed at improving audit efficiency and certifiability, must be adopted by January 1, 2025.
After installing a program on the robotic arm, a female engineer with a robotic arm controller performs a test run.
The Quality Edge
ISO45001 and the OSHA Regulations
Since its publication there have been numerous articles about ISO 45001 but very little about OSHA and its requirement in Occupational Safety and Health Standards 29 CFR 1910.
John Vandenbemden
September 29, 2024
Safety is paramount in manufacturing and distribution, with ISO 45001 (2018) guiding Health and Safety programs under federal regulations. However, there's less focus on OSHA's requirements in 29 CFR 1910.
Robotics and planning with two engineers collaborating in a warehouse with robotics in the background.
The Quality Edge
The AIAG Control Plan Manual
If you are not familiar with control plans there are three types of quality plans referred to as control plans as outputs of APQP.
John Vandenbemden
August 2, 2024
Starting March 1, 2024, a standalone Control Plan Reference Manual will maintain linkages between core tools under APQP, providing more guidance for creating and using control plans.
Engineers working in metal manufacturing industry, doing quality control of the production with tablet.
The Quality Edge
Brief History of ANSI/ASQ Z1.4
Military standards came from a need for a sampling system that did not require 100% inspection for use in testing munitions and other destructive tests.
John Vandenbemden
July 3, 2024
The ANSI/ASQ Z1.4 standard is similar in format to MIL-STD-105E and ASTM E2234-09 but differs in its definition of a rejectable item. It uses definitions and terminology in line with ANSI/ISO/ASQ 3534-2:2006. Two definitions are particularly important in applying the standard.
People's hands joining different metal cog wheel together.
The Quality Edge
Organizational Knowledge: So, where do we begin?
There is so much information and knowledge within an organization.
John Vandenbemden
June 27, 2024
What is the purpose of the requirement in ISO9001: 2015 for organizational knowledge? This particular requirement is part of a set of six requirements categorized under resources. Allow me to outline the specific details of this requirement.
April 2024 John Vandenbemden column feature image of climage change from green growth to barren land.
The Quality Edge
Climate Change and Management Standards
The integration of climate change considerations into the international standards highlights the need to acknowledge the impact it is having on our external environment.
John Vandenbemden
April 9, 2024
The ISO has added new statements to management standards in support of the ISO London Declaration on Climate Change. The change addresses the impact of climate change on management system effectiveness.
Young man texting using smartphone over isolated background stressed with hand on head.
The Quality Edge
Is Customer Satisfaction Dead?
Human nature requires face-to-face interaction as a key component for happiness.
John Vandenbemden
March 28, 2024
Blaming technology for lower customer satisfaction due to reduced personal interaction, while emphasizing the importance of face-to-face meetings for happiness and increased effectiveness, highlights the need for strategies like limiting electronics during meals and following established standards.
High-Tech Factory: Quality Control Engineer Picks up and Visually Checks Smart Electronic Device for Possible Damages. In the Background Assembly Line for PCB with Surface Mount Pick and Place Technology.
The Quality Edge
The Standard Explained: What is ISO 17025: 2017?
John Vandenbemden
March 11, 2024
The official document is titled ISO/IEC 17025: 2017, General requirements for the competence of testing and calibration laboratories. It is the international reference for laboratories performing calibration and testing activities.
John Vandenbemden Column.  Staff meeting presentation.
The Quality Edge
An Effective Management System and Lean Enterprise Require a Cultural Change
Lean and Management Standards
John Vandenbemden
December 18, 2023
A management system such as ISO9001, when implemented and deployed properly, provides the organization with predictable and consistent processes. This is also a critical component for the success of lean enterprise.
QM 1223 John Vandenbemden Column feature image of warehouse with pallets and a semi truck.
The Quality Edge
Performance Measures Not Always What They Appear
Their selection of supplier B looks like a good choice. But is it?
John Vandenbemden
November 23, 2023
At times, performance measures reveal a hidden story that can only be found by peeling back the onion. Let’s pursue this concept with an example.
Previous 1 2 3 Next
