Home » Topics » Featured Stories
Featured Stories
Featured Stories RSS Feed RSS
Inspect with Eddy Current
BNP Media Staff
July 31, 2007
Within the myriad of inspection systems and technologies available in the industry that are relatively inexpensive and can be fully automated, one inspection technology stands out-eddy current inspection. It is available to the machining industry in two forms: noncontact and contact.
Measure Better with Borescopes
BNP Media Staff
July 31, 2007
Viewing and quantifying defect damage during a visual inspection has become a critical function of quality control engineers and all borescope operators. This need to quantify inspection data has driven borescope manufacturers to achieve higher levels of system performance.
Back to Basics: Alloy Analysis with X-ray Spectrometry
BNP Media Staff
July 31, 2007
Alloy identification and analysis is an essential aspect of numerous industrial applications, ranging from scrap metal recycling to the manufacture of special steels for aircraft engines. X-ray fluorescence (XRF) spectrometry is one method that can be used for alloy analysis. The advantages of XRF have established the technique as an industry standard.
Tech Showcase: Which Hardness Test Works?
Steve Wichelecki
July 31, 2007
Used to check material uniformity or processing treatment, most hardness tests employed in quality control applications yield numerical values based on a material’s resistance to indentation under the conditions imposed by the particular test. Resistance to scratching and the measurement of the amount of energy absorbed by a material when struck by a falling object also are measures of hardness.
NDT Applications: Helium Leak Tested Integrity
July 31, 2007
Titan Metal Fabricators Inc. (Camarillo, CA), a designer and manufacturer of heat exchangers, pressure vessels and related products for the steel, pharmaceutical and chemical industries, was commissioned to construct a 90-foot-long, 5-foot-diameter pressurized column for a customer. The column was to be used for the containment of pressurized hydrochloric acid at a high temperature. Before the column could be delivered to the field, it had to undergo leak testing that would verify its conformity to applicable requirements of the American Society of Mechanical Engineers (ASME) and stringent customer demands.
The Last Word: Practical Technology
Thomas Sloma-Williams
July 31, 2007
In the United States it’s dangerous to unveil a new technology before it’s ready to go to market. Customers are bound to be frustrated by their inability to purchase a usable product after viewing new technology. It is better to hold off demonstrating new technology until there’s a product ready to ship.
Probing the Limits: Time to Say Good-Bye
Scott Dalgleish
July 31, 2007
This is my last column for Quality Magazine. When I was invited to write this column in 2002, I would have never guessed that I would be doing this for five years.
Quality 101: Caliper Basics
George Schuetz
George Schuetz
July 31, 2007
Calipers are extremely versatile tools for making a wide range of distance measurements, including both outside diameters (OD) and inside diameters (ID). While micrometers are more accurate, they have a limited measurement range, typically several inches. Calipers can span from 2 inches to 4 feet, depending on the length of the scale. External measurements are made by closing the jaws over the piece to be measured, while internal measurements are made by opening up the inside diameter contacts. Depth and other measurements can be made with a depth rod built into the instrument’s beam.
Quality Expo Preview
July 31, 2007
Quality Expo 2007 is the leading quality show and conference that provides hand-on access to the newest tools and broadest array of technologies to help you improve quality, streamline your process and compete globally.
Quality Innovations: All About Eve
Michelle Bangert
Michelle Bangert
July 31, 2007
MTI, a subsidiary of Mechanical Technology Inc., officially announced the release of Eve, a stand-alone measurement solution and data acquisition system, on June 18 at their shareholder’s meeting. Eve is compatible with most sensors, including MTI’s noncontact displacement sensors, allowing correlation of displacement, temperature, pressure and other physical parameters for test, research or process monitoring applications.
Previous 1 2 … 173 174 175 176 177 178 179 180 181 … 273 274 Next
