NDTAerospace
If you work anywhere near aerospace manufacturing, quality, operations, or supply chain, you already know the pressure is real.
By Emily Elizabeth
heavy-frame gas turbine compressor components
Image Credit: MTL Precision
an industrial 3D printer or scanner designed for additive manufacturing processes
industrial machinery
May 10, 2026
Perhaps “scare” sounds too dramatic.
Maybe a softer word would be more comfortable. Pressure. Urgency. Disruption. Restlessness.
But comfort is exactly the problem.
Because what I am really talking about is the emotion many people in business feel but rarely say out loud: fear of being exposed as too slow, too settled, too committed to a way of working that no longer makes sense.
That is the one thing Elon Musk gets right.
Not every product decision. Not every public comment. Not every strategic bet. Those are separate conversations. What matters here is the mindset. The operating philosophy. The refusal to accept that “good enough” is a valid finish line.
That mindset is deeply unsettling because it forces everyone around it to confront a hard question: are we actually progressing, or are we just moving?
There is a difference.
A company can be busy, growing, hiring, quoting, producing, shipping, reporting, and still be fundamentally complacent. A team can hit deadlines and still be working inside a broken system. A department can be full of smart, hardworking people and still be protecting inefficient processes simply because those processes are familiar.
That is what makes this style of thinking so uncomfortable. It does not just challenge outcomes. It challenges assumptions. It asks whether the process itself deserves to survive.
When you look at Musk’s companies through that lens, a pattern becomes obvious. Every move is about optimization. Every bottleneck is treated like an insult. Every dependency is questioned. Every handoff, every delay, every unnecessary layer gets dragged into the light.
That is how vertical integration happens. That is how established industries get shaken. That is how entire sectors realize that what they once accepted as normal was really just tolerated inefficiency.
And that should scare us a little.
Because much of the world today is rooted in undiagnosed complacency. As humans, we often tell ourselves that if we are moving forward, we must be doing something right. But motion is not the same thing as progress. In industry, motion can hide a lot of waste. It can hide overcomplicated approvals, outdated quality methods, disconnected systems, and labor-intensive steps that no one has had the courage to redesign.
I have had those thoughts myself.
I have looked at certain processes and thought: this is ridiculous. This is too laborious. This takes too long. This asks too much of people and gives too little back. I have seen expectations rise while the systems underneath remain largely unchanged. I have seen teams work heroically just to hold together workflows that should have been reimagined years ago.
Eventually, I realized something simple. You can keep moving in the same direction and call it progress. Or you can change the trajectory.
That choice is becoming impossible to avoid in aerospace.
Aerospace has entered an era where old assumptions are expensive
The industry is dealing with production backlogs measured in the billions. Demand is strong. Delivery expectations are intense. Programs are ramping. Customers want more predictability, more traceability, and more accountability. And all of that pressure is landing on manufacturing systems that were never really designed for this level of strain.
Why is that happening?
Because the backlog is not being caused by one single issue. It is the result of multiple pressures colliding at once: supply chain disruptions, material constraints, labor shortages, fragile onboarding pipelines, capacity limitations, and the simple reality that many suppliers are being asked to do more with operating models that are already stretched.
But there is another issue that does not get enough attention.
A lot of companies are still trying to solve a 2026 production problem with a 2006 quality mindset.
That matters.
Quality is often treated as a downstream checkpoint, a necessary control function, or a protective layer between production and the customer. All of that is true. But it is incomplete. In today’s environment, quality is not just validating output. It is directly influencing throughput, cost, responsiveness, and competitiveness.
If quality is slow, production feels it.
If inspection requires too much expertise, staffing feels it.
If systems cannot adapt quickly to new parts or changing requirements, lead times feel it.
If traceability is fragmented, customers feel it.
If cycle times are bloated, margins feel it.
Quality is no longer sitting quietly at the end of the line. It is one of the forces shaping the economics of the entire business.
That is why complacency in quality is so dangerous. It does not stay contained. It multiplies downstream.
We need to stop thinking like caretakers and start thinking like builders
One of the most important shifts leaders can make is to stop asking, “How do we improve what we have?” and start asking, “If we were building this from scratch today, would we design it this way?”
That is a much more uncomfortable question.
Because if the honest answer is no, then incrementalism is not enough.
If this were your business from day one, your own baby, how would you build the quality function? Would you choose workflows that depend heavily on tribal knowledge? Would you accept long inspection cycle times as inevitable? Would you tolerate systems that are difficult to learn, difficult to scale, and difficult to integrate? Would you create processes that require heroic effort just to maintain consistency?
Probably not.
You would go study the best in the world. You would look outside your own four walls. You would learn from people and organizations that are solving parallel problems in smarter ways. And then you would ask the question that matters most: can we do that here, and can we do it even better?
That kind of outside-in thinking is where real transformation begins.
It is also where many organizations get stuck, because this type of rethinking threatens more than process charts. It threatens identity. It challenges the idea that experience alone is enough. It forces leaders to admit that some legacy systems survive not because they are optimal, but because changing them feels politically difficult or operationally risky.
But the greater risk is pretending there is still time to wait.
The future is already arriving faster than most organizations are prepared for. AI is reshaping roles. Automation is redefining value. Customer expectations are rising. And the companies that win will not necessarily be the ones with the biggest footprint. They will be the ones willing to rethink the fastest.
The payoff is real
This is not theoretical.
We have seen what happens when suppliers step back and challenge assumptions around quality and throughput. I have personally seen engine block suppliers save millions of dollars per year by reducing inspection times by 73 percent. That kind of change does not come from working harder inside the same box. It comes from redesigning the box.
When cycle time drops that dramatically, the gains spread everywhere. Capacity improves. Bottlenecks ease. Labor becomes more effective. Decision-making speeds up. Production planning becomes more realistic. Customer confidence grows. Margin has room to breathe again.
Most importantly, the organization stops treating quality as a drag on growth and starts using it as an enabler of growth.
That is the shift.
And it is a powerful one, because it changes the role quality plays in the business conversation. Instead of being framed as a necessary expense, it becomes a strategic lever. Instead of being judged only by whether defects were caught, it gets measured by how much value it helps unlock.
That is the kind of thinking more aerospace leaders need right now.
A little fear might be healthy
So yes, maybe “scare” is the right word after all.
Not panic. Not paralysis. Not fear for fear’s sake.
But the kind of fear that wakes people up. The kind that breaks complacency. The kind that forces us to confront where we have confused tradition with excellence, or activity with progress.
The lesson is not that every company should try to become Elon Musk. The lesson is that every leader should be willing to look at their world and ask what no longer makes sense, what is being tolerated without reason, and what could be fundamentally rethought.
In aerospace quality, that question is becoming urgent.
Because the industry does not need more people protecting yesterday’s assumptions. It needs more people willing to redesign what tomorrow requires.
The future comes fast. We can already see it. The only real question is whether we meet it by defending familiar systems, or by building better ones.
The individuals and organizations that choose the second path will not just keep up.
They will change the trajectory.
  • Businesses Have Endless Supply of Maladies that Need to be Addressed
  • The Shifting Tariffs Landscape: Impact on Small Business, Manufacturing, and Supply Chains
  • Built to Waste? How Outdated Manufacturing Practices Are Costing Us More Than Money
KEYWORDS: manufacturing metrology supply chain
Emily elizabeth managing director mtl precision 200
Emily Elizabeth, managing director, U.S, at MTL Precision. For more information, call (913) 645-8499, email [email protected], or visit Mtlprecision.com or
https://www.linkedin.com/in/emily-elizabeth-ks/.
  • MPI inspection
    Still the One: The Enduring Attraction of Magnetic Particle Inspection
  • Machine Vision 101: What Machine Vision Solution is Right for You?
