Mitutoyo Dial Test Indicators
April 1, 2017
Mitutoyo America Corporation announces the release of lever-type dial test indicators with increased durability, sensitivity and readability.
A wide array of styli and ruby tips allows for probing of many applications. Stylus length is marked on the dial face to assist customers when ordering replacement styli.
To improve readability, a glare-free, flat crystal face has been incorporated to allow for easy viewing of graduations. In addition, the font and dial face color were changed. Multiple layers of hard, smudge-resistant coatings on the crystal prevent scratches and contamination.
An O-ring seal on the bezel provides smooth rotation and prevents oil and dust from contaminating the dial face. A flange was added to prevent the bezel from becoming detached during use. Optional limit hands can be attached to the bezel, allowing for easy identification of tolerance limits.
Improved impact-resistance and a one-piece internal assembly protect your indicator. The one-piece assembly also makes replacement of internal components simple, should service be required.  A unique sub-plate structure has been incorporated into all models to prevent the stylus from becoming loose. Redesigned mounting of the gears allows the indicators to maintain good trackability even with prolonged use.
Choose from a variety of dial positions: horizontal, horizontal with a 20-degree tilted face, vertical and parallel.
(630) 820-9666
[email protected]
www.mitutoyo.com
KEYWORDS: Indicator Gage Mitutoyo America testing tools
  • Mitutoyo iChecker
    Mitutoyo Inspection Instrument for Indicators
  • QM 0422 Quality101 3900M 5cUSa2
    Quality 101: The World Of Indicators
    Mahr MarTest 800 EWR Digital Test Indicator
  • Measurement and Gaging DVD
  • Chicago Dial Indicator Co.
    For more than 80 years CDI has been a trusted supplier of dial indicators, contact points, depth bases, thickness gages, and granite stands for major manufacturers and OEMs across the globe. Along with more than 400 standard mechanical dial indicators and electronic dial indicators we also have the expertise to meet your special gaging requirements including special mounting backs, special contact points, and custom mechanical and electronic dial indicators.
  • Mitutoyo America Corp.
