Home » Topics » Channels » Vision & Sensors
Vision & Sensors RSS Feed RSS
Profile: Emerging Trends in Machine Vision
Philip Colet
May 1, 2007
Machine vision operators have an ongoing quest for solutions that are faster, cheaper, more accurate and more robust. Source: Dalsa
Integrated Vision
Greg Hollows
May 1, 2007
Vision system integration has come a long way. With increased processing power, more powerful algorithms, and lighting and optics designed for more demanding requirements, more applications can be solved today than ever before.
Cameras Get Smart
Larry Adams
May 1, 2007
The term smart camera has been somewhat of a misnomer. It is true that it is a camera, but it has not necessarily been smart. But that is changing as the cameras of the past, which could only work at less than optimal feed speeds and do less than complete image analysis, have evolved into a powerful quality assurance tool.
Case study: High-Speed Bottle Inspection
May 1, 2007
German beverage industry specialist BBull (Königsbach-Stein, Germany) faced a challenge to inspect tens of thousands of containers an hour. BBull’s high-speed machine vision system Stratec BV 3000W effects an all-around control of labels, tins and bottles.
Color vision sensor
May 1, 2007
The DVT 535C entry-level color vision sensor is not limited to a single machine vision function such as color sorting, but can handle a much broader range of applications with a compete set of color tools for sorting, color match and defect detection.
IR-Sensitive camera
May 1, 2007
When used with an IR LED illuminator, the CS8620Hi near-IR RS-170 analog camera can achieve detailed surface inspection of superficial irregularities, blemishes or defects not easily observed in the visible spectrum.
Multi-line lasers
May 1, 2007
Lasiris laser line generators are able to project from three to 99 parallel lines with a high degree of uniformity across the lines. Multiline patterns are compatible with all Lasiris lasers that emit from 375 to 1,550 nanometers.
Retroreflective sensor
May 1, 2007
The BOS 6k miniature-32 by 20 by 12 millimeter-photoelectric sensor enables transparent objects to be identified regardless of shape, color or composition. The new retroreflective sensor’s low hysteresis makes it suited for detecting transparent objects such as glass bottles, test tubes or transparent films in industrial and packaging applications.
CCD camera
May 1, 2007
The 2-megapixel GE1650 provides 12-bit image data running 30 frames per second at 1,600 by 1,200 resolution. The GE1650 incorporates a Kodak KAI-2020 progressive scan CCD sensor with electronic shutter suitable for capturing high-speed motion events.
Laser distance sensor
May 1, 2007
The OADM 13 is a compact sensor that measures distances up to 550 millimeters and delivers noncontact measurement independent of color and surface texture. Offering 10 micrometer resolution and 900 microsecond measuring cycles, the sensor has dot or line-shaped laser beam options that enhance performance based on surface texture.
Previous 1 2 … 157 158 159 160 161 162 163 164 165 Next
