Teledyne Linea HS2 8k Camera
Teledyne DALSA
July 8, 2026
Teledyne DALSA announced the release of its next-generation Linea™ HS2 8k backside illuminated (BSI) 1 MHz Time Delay Integration (TDI) camera.
Designed for ultra-high-speed imaging in light-starved conditions, the Linea HS2 8k camera joins the existing 16k models, delivering exceptional image quality with 5 µm resolution and an industry-leading maximum line rate of 1 MHz.
The Linea HS2 family features a highly sensitive multi-array charge-domain Teledyne DALSA CMOS BSI TDI sensor, available in 8k and 16k resolutions with optimized quantum efficiency to meet the rigorous demands of current and future machine vision applications. The multi-array TDI sensor architecture allows the camera to be configured for superior image quality with maximized line rate, dynamic range, or full well capacity, depending on application requirements. This results in unsurpassed signal-to-noise performance and dynamic range for the most discriminating inspections.
This flexibility makes the Linea HS2 8k particularly well-suited for inspecting semiconductor wafers, high-density interconnects, genomics flow cells, or any other high-speed inspection applications. On-chip binning further enables higher web speeds to boost system throughput. The camera is equipped with Camera Link HS CX4 connectors for Active Optical Cables, providing complete EMI immunity.
Teledyne Vision Solutions
https://www.teledynevisionsolutions.com/
KEYWORDS: cameras machine vision manufacturing metrology quality
Quality’s Dirty Secret
  • XIMEA 8K Camera
    XIMEA 8K Camera
  • The Accel Series LB-8K Camera
    Teledyne Linea HS 16k TDI Camera
  • April 23, 2026
    Quality Leaders Forum: Turning Quality Data Into Meaningful Conversations
  • Teledyne DALSA
    Teledyne DALSA is a part of Teledyne's Vision Solutions group and a leader in the design, manufacture, and deployment of digital imaging components for machine vision. Teledyne DALSA image sensors, cameras, smart cameras, frame grabbers, software, and vision solutions are at the heart of thousands of inspection systems around the world and across multiple industries.
  • Teledyne ICM
    Our mission, at Teledyne ICM, is to facilitate professionals’ life by providing them with innovative, user-friendly, and safe X-ray solutions, while accompanying them throughout the use of our products. For more than 30 years, Teledyne ICM has been a worldwide-active company specializing in developing and manufacturing portable X-ray generators and digital radiography solutions for Non-Destructive Testing.
