Home » Topics » Quality Top Stories
Quality Top Stories
Quality Top Stories RSS Feed RSS
NDT Trends: Shifting left opening image of automotive manufacturing worker on laptop
Trends
Shifting Left in Manufacturing Quality
The future of quality in manufacturing is predictive.
Greta Cutulenco
January 16, 2024
A new method to manage quality must not only improve quality, it must also address areas of waste. If we could detect defects even earlier in the process and given that increasing the number of quality gates is untenable, what else can we do?
Unraveling Deflategate: Football stadium with closeup of football on field
A comprehensive analysis of measurements, traceability, and uncertainty in the Tom Brady controversy.
Greg Cenker Henry Zumbrun
January 15, 2024
The Deflategate scandal erupted following the 2014 AFC Championship Game between the New England Patriots and the Indianapolis Colts when accusations emerged that the Patriots had intentionally deflated footballs to gain an unfair advantage.
NDT Inspection Eddy Current Testing
NDT | Inspection
Nondestructive Testing (NDT) of Commercial Aircraft Wheels
The main flaws uncovered by NDT on the wheels are cracking, corrosion, geometrical distortion, and overheating.
Gregory James Weaver
January 15, 2024
Aircraft wheels are put through aggressive and cyclic NDT inspection protocol and the wheel’s potential for failure has led manufacturers to require various repetitive inspections at regular intervals.
Case Study Combo Manifold Gray
Case Study
Orbit Irrigation Digitizes and Simplifies Incoming Inspection Tasks
Until a few years ago, Orbit was tracking inspection data on paper and an Excel sheet.
Jon Facer
January 11, 2024
Orbit, which was recently acquired by Husqvarna, is the world's largest manufacturer of sprinkler heads, smart timers, valves, manifolds, and other accessories for residential, agricultural, and commercial irrigation systems.
ZEISS ZEN core with GxP module
Software
FDA-compliant results documentation with Microscopy Imaging Software
Transferring microscopy applications into production often requires validation activities.
Roger Landolt
January 11, 2024
Microscopy systems must ensure data integrity and process reliability to meet regulatory requirements with a software solution providing the respective functionalities such as Audit Trail, Electronic Signatures, and User Management.
NDT Leak Testing. Example of a two point calibration using the Sentinel Blackbelt pressure decay instrument and a CTS calibration Leak Standard
NDT | Leak Test
Two-Point Calibration: The Key to an Accurate, Repeatable Leak Test
How single-point calibration falls short in pressure and vacuum decay leak test calibration.
Gordon Splete
January 10, 2024
Some manufacturers will use a single-point calibration system to measure volumetric flow—however, a two-point calibration provides a much higher level of accuracy.
NDT Leak Testing: The man holding the pouch cell
NDT | Leak Testing
Leak Detection’s Crucial Role in Li-ion Traction Battery Production
Manufacturers that routinely challenge their leak tightness testing process will consistently produce products with reliable performance, battery longevity and safety.
Thomas Parker
Thomas Parker
January 9, 2024
For lithium-ion traction batteries, leak detection is imperative for battery performance, longevity and safety, especially the prevention of fires.
Plug Door Itself Could Be Key to Solving 737 9 Mishap
January 8, 2024
The investigation is under way to explain a “plug” door that blew out shortly after takeoff of a Boeing 737 Max 9 in Oregon on Friday.
Quality Leadership Survey: Tecnova Electronics employees posing for picture
Management | 2024 Quality Leadership Ranking
Five Quality Companies to Know: Tecnova Electronics
The annual Quality Leadership ranking is back.
Michelle Bangert
Michelle Bangert
January 8, 2024
Welcome to our ranking of perennial quality superstars. Tecnova Electronics is our top ranked quality company. Congratulations!
NDT Computed Tomography feature image
NDT | Computed Tomography
The most effective and precise battery inspection technology
It’s the tiniest defects that are the major problems today.
January 8, 2024
Do I need a 3D CT volume with the highest resolution for a detailed analysis, or is a fast overview scan sufficient to define the regions from which I want to make additional high-resolution detail scans?
Previous 1 2 … 104 105 106 107 108 109 110 111 112 … 161 162 Next
