New ProductsTest & Inspection
Phillips Precision Skinny-Vise Fixture Solution
May 8, 2019
Inspection Arsenal® adds even more versatility with the all new Skinny-Vise™. Improve visibility, and repeatability on your CMM and Vision Systems. With the gentle twist of the thumb screw, inspectors can easily hold small, thin and odd parts with simplicity and precise repeatability.
The static jaw is adjustable up to 1.25”, while the locking jaw is easily engaged with just a quick, gentile twist. Allowing for incredibly fast swaps and repeat inspection of very thin, small parts. Soft aluminum jaws can be customized to hold parts of all shapes including pins and spheres and the vise base can be mounted in any direction desired, giving inspectors even more options to hold parts more efficiently than ever before.
Modular inspection with Inspection Arsenal® is the new revolution in inspection fixturing. Finally offering LEAN solutions to break bottlenecks that plague inspection labs everywhere. Build fixtures just once and add them to the job box, quickly swap between unlimited fixtures on one machine or use one fixture across unlimited machines.
Phillips Precision
www.inpsectionarsenal.com
KEYWORDS: fixture system Inspection Arsenal
    Phillips Precision Mini-Vise
  • Phillips Precision 3-Legged Spider Clamp
  • Phillips Precision Inspection Arsenal Quick-Swap Fixturing
  • Rayco Fixture
    For over 45 years, Rayco Fixture has provided high-quality fixturing solutions to the metrology industry. Our modular and custom fixtures are designed for coordinate measuring machines (CMMs), vision systems, and portable measuring devices. By using a Rayco fixture, you can increase the efficiency of your measurement processes and streamline setup transitions.
