AutomationManagement
Management | Lean Automation
Automation Should Support, Not Substitute, Fundamentals of Lean Process Discipline
By Jeremy Smith
Lean IMEC: Two women working on universal robots, cobot
Image Source: Illinois Manufacturing Excellence Center
May 6, 2025
Lean manufacturing and automation have historically been perceived as opposing ideologies in many manufacturing environments. Lean emphasizes eliminating waste through visual controls, standardized work, and human-centered problem-solving. It promotes simplicity, flexibility, and continuous improvement driven by those closest to the work. Automation, by contrast, is often associated with capital-intensive investments and a focus on maximizing throughput, sometimes at the expense of flexibility and adaptability. This apparent misalignment has led some practitioners to believe that implementing one necessarily compromises the other.
The current operational realities of manufacturing are more complex and demanding. Today’s manufacturers must manage rising labor costs, skills shortages, global competition, and increasingly customized customer demand, and at the same time maintain high quality and fast delivery. In this context, the integration of lean and automation is not only feasible but increasingly essential. Rather than choosing between the two, manufacturers are finding that the right automation strategies can actually reinforce and expand lean thinking.
This article explores how automation, when applied thoughtfully, can reduce variation, improve process stability, and support lean goals like flow and quality at the source. When automation is grounded in a lean framework, it doesn’t replace the human-centered philosophy of lean. In fact, automation can amplify lean’s impact across the value stream.
The Fundamentals of Lean
At its core, lean manufacturing seeks to maximize value for the customer by minimizing waste. This is achieved through a structured, iterative approach to continuous improvement built around five guiding principles: define value from the customer’s perspective, map the value stream, create smooth process flow, establish a pull system, and pursue perfection relentlessly. These principles help organizations focus on what truly matters, eliminate non-value-added activity, and build capability among frontline staff to solve problems at the root cause.
Lean methods prioritize simplicity, consistency, and sustainable improvement. Classic tools such as 5S, standardized work, visual management, and mistake-proofing are typically low-cost and low-tech, relying more on discipline and insight than automation or software. This emphasis on human systems and manual techniques has historically made lean practitioners cautious about automation. Automating a broken or unstable process risks locking in inefficiencies, compounding problems, and creating hidden forms of waste.
But lean doesn’t reject automation. It simply insists that automation be used deliberately in a way that is aligned with a well-understood value stream, and only after processes have been stabilized and standardized. In this view, automation isn’t an end in itself, but a means to reinforce lean’s core objectives.
Lean IMEC: Three people in hard hats posting in front of rows of stacked pipes.
Myths About Automation in a Lean Setting
Despite a growing number of successful examples, misconceptions still cloud the conversation about automation within lean systems. These myths can prevent companies from taking full advantage of the synergy between the two.
Myth 1: "Lean thinking rejects automation."
Many interpret lean’s preference for manual methods as a blanket rejection of automation. From the very beginning, lean did not oppose technology. The focus was and still should be on the most appropriate technology that is simple, reliable, and adds consistent value. This may be manual, semi-automated, or fully automated depending on the context.
Myth 2: "Automation is too costly and inflexible."
While traditional automation systems have been expensive and rigid, today’s technologies are more affordable and adaptable. Collaborative robots, modular automation kits, and plug-and-play vision systems allow targeted, scalable automation that supports lean’s emphasis on agility and responsiveness.
Myth 3: "Automation eliminates jobs, not waste."
The fear that automation leads to job losses is rooted more in poor implementation than in automation itself. When deployed without lean thinking, automation may indeed replace labor without improving the process. But lean-guided automation aims to relieve people of repetitive or strenuous tasks, freeing them to focus on quality, problem-solving, and innovation.
How Lean Can Be Made Possible by Automation
When thoughtfully integrated, automation becomes a powerful enabler of lean goals, offering specific benefits that reinforce stability, quality, and flow.
Reducing variation and defects:
Automated inspection systems using vision cameras, sensors, and lasers can detect quality issues in real time, enabling operators to address problems before they escalate. This supports lean’s goal of building quality into the process rather than inspecting it at the end.
Increasing throughput and minimizing delays:
Technologies like autonomous mobile robots (AMRs) ensure just-in-time material delivery, helping maintain takt time and reduce transportation waste. Automated changeover tools allow faster transitions between product variants, supporting the flexibility required for high-mix, low-volume production.
Standardizing and simplifying routine tasks:
Cobots, guided operator systems, and interactive work instructions help ensure consistency in task execution, reduce training time, and make it easier to identify deviations. These technologies augment human workers rather than replace them, reinforcing lean’s emphasis on quality at the source.
Lean First, Then Automate:
One of the most common missteps is automating a process that hasn’t been properly stabilized or standardized. In lean terms, this is equivalent to automating waste. Without a clear understanding of the value stream, automation can institutionalize inefficiencies and obscure the real root causes of problems.
Before introducing automation, organizations should:
  • Map the value stream to understand where value is created and, more crucially, where it is not.
  • Eliminate obvious forms of waste, overburden, and variation.
  • Establish standardized work and visual controls to ensure consistency.
Once a process is predictable and repeatable, automation can help take it to the next level by increasing efficiency and reducing human error. A pilot-and-learn approach of testing automation in a single cell or area before scaling enables teams to validate improvements, refine the design, and build internal capability.
Automation should always support, not substitute, the fundamentals of lean process discipline.
Lean IMEC training
People and Lean Culture Still Matter
Respect for people is a foundational principle of lean. Effective automation must enhance the role of human workers, not diminish it. In fact, automation can elevate people’s contributions by shifting their focus from manual labor to higher-value activities such as quality control, process improvement, and innovation.
To achieve this, manufacturers must:
  • Involve operators early in automation planning and deployment.
  • Offer training to develop new technical and problem-solving skills.
  • Cultivate a culture of ownership, where people feel empowered to improve their work.
Automation should be embedded into the daily rhythm of lean systems. When integrated into visual controls, layered audits, and continuous improvement activities, rather than managed as a separate, top-down initiative, the two improvement approaches accomplish more than either can alone.
Typical Mistakes and How to Prevent Them
Automating unstable processes:
If a process is highly variable or plagued by frequent defects, automation will only amplify these issues. Stabilize first.
Overengineering solutions:
Complex automation systems often introduce unnecessary rigidity, cost, and maintenance demands. Begin with the simplest possible solution that effectively solves the problem.
Ignoring operator input:
Those closest to the process are critical to making automation work. Skipping their insight can lead to poor design and resistance to change.
Implementing in silos:
Automation should not be solely owned by engineering or IT. Cross-functional collaboration with input from quality, operations, and continuous improvement teams is essential to align automation with lean objectives.
Lean and automation are not opposing strategies, but in fact, they are complementary. When applied together with intention and discipline, they can unlock powerful improvements across the value stream. Automation should be viewed not as a shortcut, but as a strategic tool that supports people, enhances flow, reduces variation, and stabilizes processes.
By integrating automation within a lean framework, manufacturers will be better positioned to meet the demands of modern markets, deliver consistent quality at scale, and sustain operational excellence for the long term.
  • Beyond Lean Thinking: "Doing Better with Less of Everything"
  • Lean 101: An Introduction to Lean Manufacturing
  • The Role of Lean Daily Management in Sustaining a Lean Culture
  • Obeya: Introducing The Lean War Room
KEYWORDS: lean manufacturing lean principles manufacturing metrology
Jeremy Smith, IMEC Technical Specialist. For more information, email [email protected].
  • QM 0822 Quality 101 Automation
    Automation: Should Manufacturers Fight Or Flight?
  • Fundamentals of 3-D Machine Vision
  • DELMIAWorks Connected worker on a tablet
    Understanding the Fundamentals of a Manufacturing ERP System
