Instron AVE3 Advanced Video Extensometer
May 29, 2025
Instron® announced the release of the AVE3, an advanced non-contacting video extensometer that delivers precise strain measurement with unparalleled, micron-level accuracy for tensile, compression, and bend testing.
The highly versatile AVE3 can measure both modulus and strain to failure on a diverse range of materials such as plastics, metals, composites, biomaterials, textiles, and elastomers—along with sensitive materials like films and foils. Compliant with ISO 9513 and ASTM E83, the AVE3 allows labs to reliably test to any standard with one device, without needing to purchase and maintain multiple clip-on extensometers.
The AVE3 can be configured to accommodate a range of gauge lengths and elongations. New kinematic mounting enables each lens to automatically snap into the factory-calibrated location, making it easy to capture accurate data every time.
To guard against typical lab air disturbances like HVAC systems and human operators' movements, the AVE3 uses Instron's patent-pending Constant Density Air Tunnel (CDAT) technology, which creates a force field–like protective barrier around the test space.
This CDAT airflow technology eliminates errors, reduces noise in test data, and improves accuracy by as much as five times (compared to video extensometers without CDAT technology).
In addition, Instron's Dynamic Cross-Polarized Lighting system provides a robust solution for fluctuating lighting conditions in different lab spaces. The patented system dynamically adjusts its illumination levels to ensure all markings on the specimen are perfectly illuminated for consistent results in any test environment.
Designed for compliance with ISO 6892-1 and ASTM E8, the AVE3 extensometer enables closed-loop strain rate control — the preferred mode for testing strain rate–sensitive metals. This capability is especially valuable for laboratories focused on achieving consistent, repeatable results across different systems and locations. Leveraging CDAT airflow technology and advanced dynamic lighting, the AVE3 delivers a virtually noise-free strain signal, eliminating the need for heavy filtering that can distort results or introduce lag in test control.
"Environmental variability has long been the Achilles’ heel of optical strain measurement. Even minor shifts in lab temperature or lighting can introduce significant signal noise and undermine data integrity," said Casey Willis, Instron's Product Manager for strain measurement devices. "The AVE3 directly addresses these pain points with its patent-pending CDAT (Constant Density Air Tunnel) airflow technology and a patented illumination system — two core innovations that ensure consistent data, even in variable lab conditions. For labs that demand reliability at the highest level, the AVE3 sets a new benchmark."
Instron
www.instron.com
KEYWORDS: machine vision manufacturing metrology video extensometers
  • Advanced Video Measurement Solutions
  • Instron Autoinjector Testing
    Instron Autoinjector Testing System
    Instron 100 kN Table Model Universal Testing System
    Advanced Quality Auditing
  • Nanometrology DVD
  • What Lean Means DVD
  • June 9, 2026
  • Instron
    Instron designs and manufactures systems for testing the mechanical properties of materials and components. Trusted by quality engineers and R&D labs for over 75 years, Instron equipment delivers accurate, repeatable results with robust safety standards - backed by a global infrastructure offering local service capabilities, including calibration, verification, training, and more.
  • AV&R
    Experts in industrial automation, at AV&R, we offer robotic systems designed to process robotic surface finishing and visual inspection on parts of different sizes and materials. As a result, our systems are adaptable to the size and shape of your parts, no matter your focus and industrial sector.
