NDTAerospace
How Additive Manufacturing Technology is Transforming Repair and Maintenance Strategies
Rethinking Aerospace Repair
By Behrang Poorganji
Nikon Lasermeister Turbine blade repair sample
Image Source: Nikon Advanced Manufacturing Inc.
June 9, 2025
As aerospace and aviation industry fleets around the world continue to age and face increasing operational demands and challenges, the industry, especially commercial aviation, is encountering a pivotal challenge: how to sustain the performance and availability of high value components while controlling and managing the costs. Traditional maintenance models are often reliant on costly part replacement with lengthy lead times. These strategies are being evaluated again considering new and emerging manufacturing technologies. Among the most promising developments is the use of additive manufacturing (AM), particularly Directed Energy Deposition (DED), in repair applications.
Rather than replacing entire components, engineers and maintenance teams are actively exploring how DED and adjacent additive technologies can not only restore but also enhance parts performance and quality at a fraction of the cost and time required for conventional repairs and maintenance methods. By combining DED technology with advanced digital workflows and localized material control, aerospace and aviation industries unlock smarter, faster, and more sustainable approaches to repair and maintenance.
Demand: The Aging Fleet Challenge
Many aerospace platforms currently in service were designed decades ago and are expected to remain operational well into the future. With original equipment manufacturers (OEMs) discontinuing legacy parts production, coupled with increasing demand for flight readiness, fleet operators face compounding difficulties in maintaining aircraft components, particularly those made from high-performance alloys or featuring complex geometries.
Component failures, wear, corrosion, and oxidation damage often require either extensive refurbishment or total part replacement, both of which can disrupt operations and increase maintenance costs. This has encouraged a growing interest in alternative repair technologies that can meet the rigorous quality and safety standards of the aviation and aerospace industries while reducing cost and shortening repair turnaround times.
The Rise of Additive Repair
DED builds up material by melting metal powder or wire using a focused energy source such as a laser or electron beam, making it uniquely suited for repair applications. Unlike other widely used metal AM technologies such as powder bed fusion, which excels in creating entirely new parts, DED can be optimized for adding material to existing structures with ultra-fine precision and control. An optimized and well-controlled DED process can be deployed to rebuild worn features, restore critical dimensions, and repair localized damage. Because the process can be carefully targeted, it minimizes the heat-affected zones and material waste, allowing engineers to fine-tune the microstructure and properties of the deposited material and layers. Recent advancements in high-precision DED repair solutions and multi-axis robotic systems, as well as closed-loop monitoring technologies, are improving DED’s performance and repeatability, opening up more applications and making it a viable option even for mission-critical components in aerospace and aviation.
Nikon Lasermeister LM300A and SB100 Image
From Scan to Repair: The Power of Digital Manufacturing
One of the transformative aspects of additive manufacturing-enabled repair is the integration of digital tools across the maintenance workflow. High-resolution 3D scanning, often powered by structured light or laser-based systems, enables engineers to capture accurate geometries of worn or damaged parts. These scans are then fed into CAD and simulation tools to model repair strategies and even in more advanced ICME (Integrated Computational Materials Engineering) informed case studies to predict material behavior.
This “digital thread” supports a closed-loop feedback system where real-world data drives the repair process, ensuring high fidelity and compliance with aerospace standards. It also supports traceability, which is critical in regulated industries and allows for iterative design modifications over time. The ability to digitize and archive component geometries and repair data is especially valuable for legacy systems, where original design files may no longer be accessible.
Nikon Lasermeister Repair Samples at Formnext
Materials and Metallurgy: The Criticality of Meeting the Standards
A key area of additive repair innovation lies in material science and metallurgy. Aerospace-grade alloys such as Nickel based super alloys, titanium alloys, and various types of steel require precise control over composition, contamination, phase transformations, physical, and mechanical properties. While research into how DED-deposited materials perform under service conditions, including cyclic loading, thermal stress, and environmental exposure, is advancing, it remains an area in need of deeper investigation. Engineers are also considering and experimenting with functionally graded materials, where the composition of deposited layers changes across a single repair to tailor properties like hardness or corrosion resistance. These developments could open new repair opportunities, including performance improvements over the original design, rather than merely restoring it.
Meanwhile, ongoing standardization efforts are helping validate additive repair techniques. Organizations such as ASTM International and SAE International are working with industry partners to define materials standards and specifications, as well as qualification and certification procedures, paving the way for broader adoption of DED in safety-critical environments.
Nikon Lasermeister Repair Samples display
Economic and Sustainability Benefits
The economic logic of additive repair is compelling. By extending the life of high-value components, operators can reduce inventory costs and avoid the capital expenditure associated with new part production. Additionally, the ability to perform on-site or near-site repairs reduces logistical burdens and lead times.
From the sustainability standpoint, additive repair also reduces the amount of waste compared to subtractive methods. Because DED can be highly localized, it avoids the need to scrap entire parts for relatively minor damage.
Challenges and Future Outlook
Despite meaningful progress, additive repair still faces challenges. Ensuring process consistency, managing potential residual stresses for larger parts or faster depositions, and scaling production remain active areas of ongoing research. Integrating DED into established maintenance, repair, and operations (MRO) environments also requires retraining personnel, retooling facilities, and updating regulatory compliance protocols, which impact adoption costs.
However, the momentum is building – as more case studies validate the performance and economics of DED repairs, and the digital ecosystem matures, additive manufacturing is poised to become a cornerstone of next-generation aerospace maintenance.
The convergence of additive manufacturing, digital engineering, and material science is ushering in a new era for aerospace maintenance. DED in particular is proving to be a transformative tool, not only for making parts but for repairing and improving them in ways that were previously unfeasible. Additive repair technologies offer a viable and economic path forward that is strategically aligned with the demands of modern aviation.
  • Behind the Scenes, Behind Schedule: NDT’s Workforce Shortage
  • Compliance Standards Are Experiencing Disruption
  • Nondestructive Testing for Additive Manufacturing
  • Trends in Manufacturing: Advances in Technologies and Methodologies
KEYWORDS: additive manufacturing manufacturing metrology
Behrang Poorganji is vice president of technology at Nikon Advanced Manufacturing Inc. For more information, visit https://www.linkedin.com/in/behrang-poorganji-a6637433/.
  • How the Cloud is Transforming Document Management in Modern Manufacturing
  • The image shows a machinist operating a CNC (Computer Numerical Control) milling machine
    How AI is Transforming Metalworking in 2026
  • Artificial intelligence and machine learning concept.
    AI-Driven Automation is Transforming Manufacturing and Overcoming Key Challenges in the Industry
  • Total Productive Maintenance Blitz DVD
