AutomationManagement
A3 Column | Bob McCurrach
Sharper Eyes on Manufacturing Quality
Whether you opt for hyperspectral or multispectral imaging, these advanced technologies are transforming industrial operations.
By Bob McCurrach
Machine vision, AI algorithm outline color icon.
Image Source: seamartini / iStock / Getty Images Plus
October 11, 2025
Ensuring quality can depend on seeing more than the surface, which is why manufacturers are turning to advanced imaging to look beyond what the eye or a standard camera can capture. While conventional cameras use visible light to expertly identify quality issues and other data, spectral cameras can use non-visible light for even more use cases. Every material has a unique spectral signature that reveals what it is and its current condition. In manufacturing, that insight helps improve quality decisions, reduce defects, and support better maintenance planning.
Two advanced imaging methods used in manufacturing are hyperspectral and multispectral imaging. Both use sensors to capture information across many parts of the light spectrum that a conventional camera does not see. The key distinction in these techniques is how they capture the spectral information and the level of detail each provides:
  • Hyperspectral imaging records hundreds to thousands of narrow, contiguous bands. Each pixel carries a detailed spectrum that helps distinguish subtle variations in materials. This makes it well suited for tasks that demand maximum precision, such as contaminant detection, material verification, or uniformity checks. However, because hyperspectral sensors gather so much information, they require more complex hardware and greater processing power, which increases cost and setup effort.
  • Multispectral imaging uses fewer and broader spectral bands. It captures less detail per pixel but allows faster acquisition and simpler analysis. This makes it better for high-throughput inspection, basic sorting, or applications where speed is more important than fine detail. Multispectral systems are generally less expensive and easier to deploy, which broadens their use in manufacturing.
Top Use Cases for Spectral Imaging in Manufacturing
Whether you opt for hyperspectral or multispectral imaging, these advanced technologies are transforming industrial operations. They can also integrate with robotic automation and AI for real-time decision-making, furthering their value. Key applications include:
Material Handling
Spectral imaging excels when the task is to recognize what a part or object is made of rather than how it looks in color. In recycling, for example, spectral signatures help separate plastics, papers, and metals, ensuring accuracy and efficiency while reducing environmental waste. Robotics companies have also combined spectral platforms with vision and gripping to classify and pick objects more accurately. These examples show why spectral data is valuable when color alone is not enough.
Quality Assurance
LEARN MORE
  • Machine Vision Standards: A Review and Update
  • A Quick Overview Of Industrial Camera Interfaces
  • Talking Automation Trends with the President of the Association for Advancing Automation
Quality teams need to spot tiny variations before they become customer problems. Spectral imaging helps detect changes in composition, color, and texture that suggest defects or contamination. Because each pixel contains spectral information, the system can highlight areas that deviate from a known “good” signature, which makes it easier to flag issues that a conventional image might miss. For example, in the food sector, hyperspectral cameras are used to identify and remove faulty items and foreign material, which improves overall product purity. The same approach can confirm that incoming material matches specifications before it moves deeper into production.
Predictive Maintenance
Materials and machine surfaces change as they wear, corrode, or overheat. Those changes alter the spectral response. By monitoring those signatures over time, a team can spot subtle shifts that typically precede failure. Maintenance can then intervene before the issue becomes a stoppage. This is a practical way to reduce unplanned downtime and to extend the life of equipment. The result is fewer unplanned stoppages and lower long-term costs.
Safety Monitoring and Environmental Compliance
Spectral imaging can detect hazards that are not visible to the eye. Gases and other substances have specific signatures. Imaging can help identify and locate changes or leaks quickly. In larger areas, spectral sensors mounted on drones or other platforms can survey facilities and surroundings to identify pollutants or signs of environmental degradation. These capabilities support safety programs as well as environmental regulatory compliance.
Getting Started
Like any advanced technology, spectral imaging brings challenges. Data sets are large, systems are complex, and integration with existing infrastructure can take time. The most successful teams start small with a single high-value use case. They ensure lighting and optics are consistent, build reference libraries of good and bad product, and connect outputs to familiar systems such as Programmable Logic Controllers (PLCs) and Manufacturing Execution Systems (MES). This focus keeps adoption practical and results actionable.
The Quality Advantage
Spectral imaging’s power is in revealing what traditional cameras cannot. For use cases where non-visible light can be used to advantage, it can strengthen material identification, improve defect detection, and provide earlier warnings of equipment problems. The outcome is higher first-pass yield, less scrap, and more reliable operations. For quality leaders, the question is not if spectral imaging will matter, but where it can make the biggest impact in your operation today.
KEYWORDS: Artificial Intelligence (AI) environmental testing imaging manufacturing quality
Bob mccurrach
Bob McCurrach, Director of Vision & Imaging Standards, Association for Advancing Automation. McCurrach has over 25 years of experience in the manufacturing and product development sector, with a focus on global engineering management, strategic program and process management, primarily for the nuclear, defense and automotive industries. He holds a BS in mechanical engineering from Lehigh University as well as an MBA from Georgia Institute of Technology. Bob joined the Association for Advancing Automation (A3) in 2011 as their director of standards development for vision & imaging. He has been a key leader in A3’s standards development and coordination of vision standard development globally. Standards play a key role in the vision & imaging industry by ensuring interoperability of components, increasing market size, and shortening the time it takes to get new products to market. For more information, call (734) 929-3267, email [email protected] or find A3 on LinkdedIn: www.linkedin.com/company/association-for-advancing-automation/.
Quality’s Dirty Secret
  • Registration Now Open For The 2nd Bi-Annual Quality Show – The Only Tradeshow Focused Exclsively On Quality Manufacturing
  • Registration Now Open For The 2nd Quality Show – The Only Tradeshow Focused Exclusively On Quality Manufacturing
  • Attend The Only Tradeshow Focused Exclusively On Quality Manufacturing
  • June 4, 2026
