Software
Software
3 Project Planning Recommendations to Ensure QMS Development Success
Inadequate planning is a common reason why QMS projects fail to meet companies’ requirements and end-users’ needs.
By Roman Davydov
three people working together using a laptop
Image Credit: gorodenkoff, iStock / Getty Images Plus, Royalty-free, Dec 21, 2021.
December 3, 2025
Looking to improve the efficiency of inspection management, CAPA management, and other quality control processes, companies across industries are increasingly investing in implementing quality management systems. However, insufficient or inadequate planning is a common reason why QMS projects fail to meet companies’ requirements and end-users’ needs, lead to critical work process disruptions, or increase time and money spending. This highlights the importance of establishing a software development plan that would effectively guide the project team throughout building QMS and ensure the solution’s successful implementation.
In this article, experienced software development consultants share three project planning recommendations to help ensure the success of QMS development.
Define QMS software project scope accurately
Creating a project scope statement, a document that outlines objectives, boundaries, and deliverables, is an essential initial step in QMS project planning and execution. It provides a clear basis for critical planning activities, such as creating schedules, estimating budgets, and building resource plans, increasing the chances of the project being completed without delays and cost overruns. The project scope statement also can be used to ensure that the team and stakeholders are on the same page regarding project goals and outcomes, which minimizes the risk of scope creep.
To build a reliable project scope statement, project managers first need to identify high-level goals for QMS system development. For this, project managers need to interview various project stakeholders, including senior management such as the CEO or CTO, end-users like quality managers and inspectors, external partners, and other relevant groups to know what exact outcomes they expect from the development and how they perceive its success to determine high- and low-level objectives and success criteria for the project.
Based on the estimated goals, project managers can create a work breakdown structure (WBS) and split the project into milestones and smaller, manageable tasks. They should also calculate the resources needed to complete these tasks, including those related to personnel, time, or funding. If the project is Agile-based, instead of WBS, project managers can build product backlogs, prioritized lists of features and tasks a team should deliver to complete a project.
Based on their estimations and other information obtained previously, project managers can proceed to documenting a scope statement. Here, it is essential to use clear and simple language so that both team members and stakeholders can understand it, regardless of their technical expertise. Project managers should also review the scope statement together with the team and stakeholders to ensure they all formally agree upon the project scope.
Use Agile project management and planning practices
Traditionally, software development was planned and executed in a linear sequence of steps, all meticulously documented long before the start of work, and QMS projects were not an exception. Although the waterfall approach allowed companies to better predict work progression, it also had its drawbacks, like the lack of user feedback until the end of the project.
Since end-users could only start using QMS software systems after the development was completed, there was always a risk that the final solution would fail to meet user expectations, especially if software requirements changed during development or couldn’t be altered when user or business needs changed. In some cases, this mismatch could lower end-user satisfaction with the finished software and lead to costly software reworks that increase project budgets or have other negative consequences.
In recent years, we’ve seen a shift from traditional project management approaches towards more flexible Agile methodologies, which involve breaking projects into iterations and planning work activities at the start of each iteration rather than following a single, linear project blueprint. One of the reasons behind it is that Agile enables project managers to incorporate feedback from target users during planning and continuously refine project execution based on it, which eventually helps build QMS software tools that better align with user needs.
This is how it works in practice. After the first few sprints are completed and the first usable version of a QMS solution is built, project managers gather user feedback either by presenting the solution to users during joint Sprint Reviews, conducting surveys and asking users about their experience and satisfaction with the solution, or running comprehensive usability tests. The gathered feedback is then analyzed to understand users’ attitudes towards the available version of the QMS software and prioritize them based on their importance and feasibility. The results of this analysis can be used to make decisions about which features to build next and how to plan new sprints and releases.
Conduct regular budget reviews
To ensure better financial control over QMS software project spending and reduce the risk of budget overruns, project managers should schedule regular budget reviews to compare actual costs with the expected budget, promptly identify any discrepancies, and make necessary adjustments, preventing cost overruns and ensuring project success.
Project managers need to create a review schedule aligned with key project milestones or phases to ensure timely financial assessments. If you’re following the Agile methodology, for example, these can be conducted after one sprint ends and before the next sprint begins. You can also hold additional monthly or quarterly reviews to ensure strategic spending adjustments to the long-term project budget.
In addition to budget reviews, it is also essential to conduct regular financial analysis and budget adjustments. Project managers, along with project owners and sponsors, should define the tools they will use for regular budget tracking, control, and reporting. Moreover, it’s worth setting aside a certain percentage of the budget as a reserve fund to ensure there are always financial resources available to cover extra expenses identified during these reviews.
Final thoughts
Well-thought-out planning is critical for the success of QMS development initiatives, as it ensures project alignment with goals, allows for more efficient resource allocation, and prevents software delays, budget overruns, and other issues. Along with core software project planning activities, we recommend companies initiating QMS development to concentrate on accurate QMS software project scope estimation, adopting Agile practices like user feedback sessions, and scheduling budget reviews.
Nevertheless, careful project planning is still a rather complex and labor-intensive task, so companies can choose to enlist the help of a software development consultant to streamline it. These specialists can share their expertise in software development, project management, and other related domains to help a company build an actionable QMS development plan.
  • How Industrial IoT Trends Are Reshaping the Manufacturing Industry
  • Should You Build or Buy QMS Software?
  • Integrating SPC with QMS Encourages Shop Floor Modernization
KEYWORDS: manufacturing metrology quality quality management system (QMS)
Roman Davydov is a Technology Observer at Itransition with over five years of experience in the IT industry. Roman monitors and analyzes the latest technology trends, helping businesses make informed software decisions that align with their strategic goals. For more information, email [email protected] or visit https://itransition.com or https://www.linkedin.com/company/itransition/.
  • QM 0822 Text & Inspection 2 feature image
    Making The Case For Automated Testing To Ensure PLM Success
  • ERP Implementation
    Best Practices to Ensure a Successful ERP Implementation
  • Paradigm 3 Software
