Software
Software
Closing the Loop: Where Metrology Meets Machining Strategy
The first steps toward a data-driven manufacturing floor are simpler than many manufacturers think.
By Tait Stensrud
The image depicts a concept of industrial digitalization or a "digital twin" in a manufacturing environment
Image Credit: gorodenkoff / iStock (Getty Images Plus), Royalty-Free, ID 1481351174
April 7, 2026
Up until the early 2000s, metrology was mostly a pen-and-paper-based profession. Inspection reports, machine data, and charts were all hand-recorded, often scattered across departments. Data existed, but analyzing trends over time was slow, error-prone, and sometimes just impossible, making it fully disconnected from decision-making.
By the mid-2010s, as digital metrology systems and analytics tools became more accessible and widespread, manufacturers gained access to detailed machine data. But the data points collected were often stuck in separate processes, software systems, and departments, limiting their value.
Modern manufacturing allows us to collect vast amounts of high-value data. So, why aren't we using it for actionable insights that drive business growth?
From refining processes and improving throughput to enhancing product quality, there are many ways data can help drive business value, but only if the data is connected, analyzed, and acted upon. The real opportunities are unlocked when inspection results are used not just to validate a part, but to shape the broader manufacturing process.
Beyond the Green Report: Why Data Analysis is Ending Too Early
Manufacturers are under more pressure than ever. We’re seeing supplier quality scorecards prioritize delivery over exceptions, and in that environment, NCCARs tend to dominate, while process improvements are ignored, or worse, forgotten, after an invoice is sent. It doesn’t take long before that becomes shop culture. Encouraging teams to move quickly once a report is “green” and skipping deeper analysis is a missed opportunity to understand process behavior and long-term trends. Having a line of sight into these trends can save time, reduce cost, and drive innovation.
Inspection data often contains signals far beyond pass/fail validation. Dimensional trends can indicate tool wear, sudden shifts in feature location may suggest fixture movement, and variation across batches can point to inconsistencies in a myriad of different places. When shared with machining, process engineering, and production teams, these insights directly inform tooling decisions, machine offsets, fixture design, and preventive maintenance schedules.
Yet, in many organizations, this potential goes untapped. Reports are generated, data is stored, and the green checkmark becomes the endpoint. The consequences are subtle at first – small inefficiencies, minor scrap – but over time, they accumulate into lost productivity, higher costs, and missed opportunities for process improvement. Recognizing that inspection output holds actionable intelligence beyond validation is the first step in closing the data loop.
Building a Culture That Values Insight, Not Just Output
Shifting from recognizing opportunity to acting on it requires deliberate cultural change. Manufacturers must treat inspection data not as a compliance exercise but as a strategic asset that informs decision-making across the business. This requires time, investment, and a mindset shift: instead of seeing analysis as a bottleneck, teams must view it as a partner in achieving operational excellence.
Skilled metrologists are central to this transformation. Beyond generating reports, they must interpret trends, highlight process risks, and communicate findings in a way that machining, production, and engineering teams can apply. Metrologists must contextualize the data, explaining why a tolerance shift matters, what trend is emerging, or where variation originates, so they turn raw numbers into actionable insights. The best metrologists are those who not only perform the required measurements, but also work in tandem with machinists and engineers to get good parts out the door.
Organizations can reinforce this by encouraging cross-functional discussions around inspection trends, investing in upskilling for interpretation rather than just tool operation, and treating inspection results as feedback to guide improvements, not merely validation. Over time, these practices create a culture where metrology data drives continuous improvement, informs design and process decisions, and empowers teams to act proactively rather than reactively.
First Steps Toward a Data-Driven Mindset
  1. Encourage cross-functional review of inspection data, not just sign-off: Teams should feel supported when adding new steps to their processes. Giving employees time to review and learn from inspection data allows them to uncover insights that might otherwise be missed.
  2. Promote conversations between quality and machining teams around trend analysis: Data has little value if it isn’t discussed. Creating regular opportunities for teams to review findings, ask questions and share observations helps turn raw data into actionable insights to inform future product innovations, shop-floor processes and more.
  3. Invest in upskilling to improve interpretation, not just software operation: Organizations need employees who can do more than simply run the tools. They must understand the information the tools produce. Upskilling current employees to interpret machine data builds a strong foundation for long-term business success.
  4. Treat inspection output as feedback into the process, not simply validation of it: Not every data point will be positive, but the value lies in how organizations respond. Inspection results should inform process improvements, machine adjustments, and future decision-making.
What’s Next? The Future of Practical, Data-Driven Manufacturing
As manufacturing evolves, competitive advantages will depend on how effectively organizations activate the data they already generate.
The manufacturers who lead will be the ones who close the data loop, using metrology insights to drive continuous improvement across all areas of business, not just on the shop floor.
Shifting from seeing reports as an endpoint to viewing reports as the starting point for improvement will unlock operational gains and maximize the impact of both data and metrology solutions.
  • Four Technologies to Consider When Navigating Economic Pressures
  • Red Bull Ford Powertrains Uses Hexagon Tech to Ensure Super-High-Performance of Its First-Ever F1 Powertrain
  • Embracing the Future: Why Businesses are Migrating to SaaS for Quality Management
KEYWORDS: data collection manufacturing metrology quality
Tait Stensrud, Expert PC-DMIS Driver & CMM Subject Matter Expert at Hexagon Manufacturing Intelligence.
  • Closing the Digital Loop – Engineering to Manufacturing
  • Passenger vehicle driving on a paved road, representing automotive performance, durability testing, and real-world driving conditions.
    Closing the Quality Gap Between Computer-Aided Engineering and Real-World Automotive Manufacturing
  • Three people having a discussion in the office in car manufacturing. The background is blurred.
    Why Preparation is Critical for Closing the Manufacturing Skills Gap
    The Six Sigma Handbook, 5th Edition
