Software
Software
Advances in DOE for Today’s Quality Engineers
Rather than changing one factor at a time and looking for patterns, DOE allows us to test several factors together and observe both their individual effects and their interactions.
By Joshua Zable
illustration of a structured process for optimizing product development using Advanced Design of Experiments (DOE)
Image Credit: Minitab
April 23, 2026
Manufacturing has always required thoughtful planning. What sets today apart is the increased complexity we face.
Tolerances are tighter, materials are more specialized, and customer expectations are higher. With more variables affecting performance, trial-and-error or changing one factor at a time is no longer enough.
Design of Experiments (DOE) was built for this level of complexity.
Using DOE to Understand Before Optimizing
When processes involve many inputs, tight limits, costly materials, and strict regulations, guessing can lead to serious financial and operational consequences. DOE reduces that risk. It helps teams find the best settings, reduce variation, improve yield, and make data-driven decisions.
Staying competitive today is not just about lowering costs. Companies that dig deeper into their processes, materials, and limits can innovate and improve more efficiently.
Structured Experimentation vs. Trial-and-Error
Most quality professionals are already familiar with classical DOE methods:
  • Full factorial designs for smaller sets of critical factors
  • Fractional factorial designs to reduce run counts while identifying key effects
  • Screening designs to pinpoint influential variables
  • Response surface methods to fine-tune nonlinear processes
These methods are still highly effective. They help manufacturers reduce scrap, solve production problems, and improve formulas. However, today’s production systems often exceed what traditional designs can manage. There’s little room for extra runs, making planning experiments much more challenging. The focus is no longer on whether to experiment, but on how to do it efficiently within our constraints.
Refining Experimental Design Within Production Constraints
Recent advances in optimal and minimally aliased response surface designs address this challenge. These methods help identify the most important factors and best settings while keeping the number of runs low. Raw materials are costly, production time is limited, and even small improvements in yield can have a significant financial impact.
For example, one pharmaceutical team shortened its testing phase by several weeks and used less expensive raw materials while maintaining high quality. In another case, a sustainable processing project increased yield from about 37 percent to over 57 percent and reduced extraction time. These improvements came not from running more experiments, but from designing better ones.
How AI Supports Engineers in Process Improvement
It’s no surprise that artificial intelligence is drawing a lot of attention in manufacturing. In the context of DOE, AI is not meant to replace engineers, but to support them. Traditional stepwise regression techniques alone often fall short when dealing with many interacting variables.
Today’s experiment design catalogs may include millions of possible setups, which allows teams to evaluate over 500 million possible designs and select the most efficient option within their real-world constraints. This helps manufacturers identify optimal designs faster and build more reliable predictive models.
When experimentation is combined with predictive modeling, teams can create digital twins to test “what-if” scenarios without disrupting production. Engineers can model parameter changes, weigh trade-offs, and understand potential impacts before implementing adjustments on the line.
Good Experiments Start with Good Data
Many factories have invested heavily in data collection, such as metrology systems, uptime monitoring, and OEE tracking. This foundation is important, but data alone does not lead to improvement. The growing integration of shop-floor data systems signals a move toward more connected, closed-loop improvements.
The real benefit comes when experimentation, optimization, and analytics work together. When results are used to set production goals rather than just included in reports, improvement becomes continuous rather than occasional.
In an integrated data environment, teams can:
  • Design experiments based on real production data
  • Optimize for multiple responses simultaneously
  • Monitor performance after implementation
  • Adjust in a structured, evidence-based way
Cross-Industry Applications of DOE
Although industries face different constraints, their challenges with experimentation are often very similar.
Chemical manufacturers work to improve reactions and formulations while reducing material costs. Semiconductor makers pursue even small yield gains because of their significant financial impact. Automotive companies must balance performance, durability, and cost in both design and production.
Despite these differences, the underlying challenges are similar: limited run capacity, the need to optimize multiple factors simultaneously, and ensuring experimental results translate beyond the lab.
Why Structured Experimentation Drives Growth
Quality engineers know that improvement is not accidental. It results from disciplined investigation and deliberate action.
Despite the attention surrounding AI, structured experimentation remains one of the most dependable ways to reduce uncertainty and guide decisions. DOE brings statistical rigor to complex systems, turning data into confident decisions.
In competitive markets, advantage comes from consistently making informed decisions. Modern DOE, paired with advanced analytics and intelligent design tools, embeds that discipline into everyday operations and helps organizations sustain measurable results.
  • How Manufacturers Reduce Trial and Error with Designed Experiments
  • AI Driven Shop Floor Excellence: The Next Frontier in Quality 4.0
  • Design of Experiments: A People-Driven Approach to Process Improvement
KEYWORDS: Artificial Intelligence (AI) manufacturing metrology quality
Joshua Zable, President & CFO, Minitab
  • Asian prompt engineer develop coding app with software data sitting in front of computer monitor at office
    Harnessing the Power of LLMs: Prompt Engineering for Quality Engineers
  • A worker is using tablet to review storage report.
    How Quality Engineers Use Data to Address Root Causes in Manufacturing, Part 2
    3 Key Benefits of High-Performance SPC for Quality Engineers
  • Society of Mfg. Engineers
