Automation
Robotics
It’s Time for the Robotics Industry to “Prove it”
AI capability has to be balanced against the practical constraints of an audited, repeatable production environment.
By Erik Nieves
Collaborative robot equipped with a precision tool operating in a manufacturing workspace while an engineer monitors the robotic system in the background.
Image credit: fotografixx / Getty Images (Creative #1409088189)
June 27, 2026
The conversation around industrial and warehouse robotics has mostly been about possibility over the last decade. Would a robot be able to pick up a deformable bag? Could machine vision correctly handle SKUs it had never seen?
The demos kept getting better, and the venture capital kept flowing. Every trade show saw a new wave of robotics companies pitching automation that’s smarter, faster and more flexible.
At this stage, the question has changed from “can it work?” to “will it work in my building, on my SKUs, at my throughput over every shift for the next five years?”
The robotics industry has entered its prove-it era. The main evaluation criterion is whether it works in real-world deployments, not just controlled demos.
High Market Pressure
The global warehouse automation market is projected to grow from $24 billion in 2025 to $56 billion by 2031, a 15% CAGR. More than 80% of large 3PLs already operate some form of robotic automation, which means the question for most operators now is what to automate next and how to make sure the automation in place delivers.
The second question is where many programs are getting stuck. Adoption has run ahead of validation. Many buyers signed contracts based on demos and pilots, but are now running into all kinds of barriers on the actual floor. The primary challenges are operational variability and challenging conditions that weren’t present under the controlled conditions. Things like damaged packaging, irregular case packs, lighting that drifts from shift to shift, peak-season order surges and new SKUs that have just arrived from the supplier.
This is familiar territory for quality professionals who are used to the discrepancy between a process capability study run on golden samples and what the line actually produces over a full quarter. The difference for robotics vendors is that until recently, they have been allowed to live almost entirely on the golden sample side of that line.
The New Differentiator is Measurable Performance
In this next phase, determining whether a robotics platform is hitting the mark comes down to the same criteria operations leaders have applied to every other piece of capital equipment for the last 40 years. They are looking at measurable, documented performance:
  • Validated uptime
  • Consistent cycle times
  • Mean time between failures
  • Mean time to repair
  • Process capability across a range of inputs
These aren’t the exciting metrics that make for good keynote slides, but they are the only metrics that matter once a system is past commissioning. Quality teams should be insisting on them at the time of procurement rather than discovering them in production.
Here are a few questions worth pressing every vendor on:
  1. What is your documented scalability across sites and workflows? Not your reference deployment, but the full installed base, including the sites where things did not go smoothly.
  2. What is your real uptime across a full peak season, taken from production data rather than spec sheets?
  3. How does the system perform on the long tail of SKUs?
  4. How does the vendor manage technical support and end of life on components?
Vendors who can answer those questions clearly are the ones whose platforms are likely to still be in service in 2031. Whereas vendors who deflect, qualify or pivot to roadmap slides are ones to be wary of.
Balance AI Capability with Practical Constraints
Foundation models for robotics are driving a lot of discussion right now. Things like “GPT for robots,” generalist AI systems and humanoids that can supposedly pick up anything. This hype puts pressure on procurement teams to chase the most advanced system on the market. But this instinct is worth resisting because what AI can do in a lab is not the same as what belongs on your warehouse floor.
Every additional degree of AI flexibility brings with it a corresponding set of practical constraints. For example, model behavior that is harder to validate, failure modes that are difficult to predict and certification paths that get murkier the more the systems decide on their own.
None of this is an argument against robotics; it’s pointing to the fact that AI capability has to be balanced against the practical constraints of an audited, repeatable production environment.
Human-in-the-Loop is the Practical Model
Coverage of fully automated “dark” facilities often makes it sound like human involvement in robotics operations is a temporary scaffold that won’t be needed as the technology matures. But the operational evidence points the opposite way. The most reliable and resilient deployments are the ones explicitly designed around as-needed human supervision and exception handling.
Robots are solid on general input distribution; it’s the exceptions that cause the systems to fail. Exceptions like the misaligned label, the dented carton, the multipack, the gripper sees as a single item, or a return that came back in a bag instead of a box. Humans remain much more efficient than any current automation at recognizing the problem, deciding what to do and feeding that decision back into the workflow.
One person managing exceptions across a fleet of robots can be responsible for several times the throughput of a manual operation, while also generating a structured stream of exception data that a continuous improvement program can act on. Data around what the robots couldn’t handle and why is one of the most valuable parts of a well-designed deployment.
Robotics as Infrastructure
If you consider what defines infrastructure, robotics fits. Infrastructure is auditable, governed by SPC, FMEA and PM disciplines and judged by its contribution to the whole. Robotics that meets this same bar earns the same trust given to the conveyors, racks and WMS systems already running the building.
Like infrastructure, robotics value is rarely realized by automating one component at a time. For example, if picking is automated, but packing is not, it can lead to a pile-up downstream. Similarly, automating outbound without rethinking inbound just moves the bottleneck. Simply adding another point solution from another vendor introduces a whole different data model with its own maintenance schedule.
The solution is to treat robotics as infrastructure instead of experimentation, starting with how the system is scoped. Rather than evaluating individual robots as standalone purchases, the goal is an integrated production or fulfillment platform orchestrated by software. The benefit is that it coordinates humans, robots and existing equipment into a coherent workflow that adjusts as conditions on the floor change.
The quality of the data flowing through the system ties it all together. Data like inspection results, exception rates, throughput and cycle times need to flow across the whole platform instead of sitting in separate vendor dashboards. When that data moves freely, things like root-cause analysis are possible across the whole process.
What Prove-It Looks Like
In this era of proving that robotics has moved from possibility to reality, here is what you need to keep in mind when evaluating solutions:
  1. Buy validated, auditable, production-grade performance that has been demonstrated across sites and conditions that resemble yours.
  2. Insist on reliability data the way you would for any other piece of capital equipment. Design the human role into the system from the start instead of as a fallback.
  3. Evaluate every point solution against the workflow it has to live inside, from end to end.
The robotics industry is going to do fine in the long run, but the next several years will sort the vendors who can pass an industrial proving regime from the ones who cannot.
LEARN MORE
  • The ‘Dark Factory’ Myth
  • Why 2026 Will Bring a Reckoning for Warehouse Robotics
  • PODCAST | Trends in Robotics for the New Year
KEYWORDS: manufacturing metrology robotics statistical process control (SPC)
Erik Nieves is the CEO and co-founder of Plus One Robotics
  • Lean manufacturing
    It’s Time for Lean Manufacturing
    It's Time for Risk Based Thinking
  • QM 0823 CLMN Face of Quality Manufacturing
    Do the Right Thing at the Right Time for the Right Reason
