Home » Topics » Featured Stories
Featured Stories
Featured Stories RSS Feed RSS
Reviewing and managing potential variables
Managing the Variables
6 best practices for ensuring productive, repeatable compression testing.
Dr. Erik Schwarzkopf
November 13, 2017
Not long ago, a manufacturer of needles for medical syringes was in the middle of another shift of quality assurance testing. The test involved three individuals side-by-side, with each grabbing the needles off the line and physically inserting them into a drill “chuck,” piercing a rubber slab to simulate the piercing of human skin.
Metal sliver in sample cup, ready for handheld XRF analysis. Source: Bruker
Handheld XRF for Non-Standard Alloy QA/QC Applications
It can be used for new applications such as inspecting powder for sintered metal used in 3D printing.
Kim Russell
November 13, 2017
Handheld XRF (HHXRF) is the go-to tool for QA/QC, alloy identification and failure analysis of incoming and in-use standard industrial metals and alloys. Advancements in technology and data analysis software now make it an indispensable tool for non-standard and challenging QA/QC situations.
Short Range Guided Wave Ultrasonic Testing
Make inspections more accurate.
Pratik Wagh
November 13, 2017
Short range guided wave testing (SRGWT) is an application of guided ultrasonic sound waves using special types of probes. When the guided waves hit the discontinuities, the mode converted sound is reflected back and received by the transducer.
Test in-service on hot pipes with a handheld XRF. Source: Olympus
XRF 101: Choosing the Right Analyzer
Consider these seven points to help you identify what tool best meets your needs.
Ted Shields Sr. Peter Faulkner
November 13, 2017
Before selecting an X-ray fluorescence (XRF) analyzer, consider what you want to achieve. For example, if you are looking to confirm alloy grades for incoming goods QC, you will want to know what the important element in those grades should be.
State-of-the-art in-process measurement systems
Gaging Quality As It Happens
The economies of in-process gaging are realized when high precision is required over large production runs.
David Sladick
November 13, 2017
In-process gaging for this discussion is the continuous measurement of the workpieces during the grinding process in the work area of the machine.
The Big Picture on the Big Picture
Reflections on the manufacturing landscape of America today.
Arun Jain
November 13, 2017
“Remaining competitive” takes on many meanings, depending on your location in the world, but here are some thoughts on how American manufacturers can do it better today. By the time you finish reading this column, another entrepreneur will have figured out a way to make it happen for his or her company.
A Fresh Look at Cost of Quality
Quality professionals must learn to speak the language of management.
Edward McMenamin
November 6, 2017
Cost of quality is often misunderstood, improperly measured, and underutilized.
The Volume of Data Is Increasing
One of the primary drivers for the amount of data available today stems from integrated systems.
Craig Glick Miller
November 6, 2017
Every day I talk to customers who want to get off paper. They spend an inordinate amount of operators’ time manually capturing data on paper, and then often double-down when they have someone transfer those paper check sheets into a digital spreadsheet.
Roughness and waviness inspected on a CMM. Source: ZEISS
High-Precision CMM and Form Measurement Functions
For a long time, these capabilities could not be effectively combined for several reasons.
David Wick
November 6, 2017
It is generally agreed that engineering is about tradeoffs, and that has always been particularly true in regard to measurement machines. There are several types of measurement, and higher performance in one area generally meant less capability, or none, in other areas.
Mobile audits via tablets make audit data immediately available.
Layered Process Audit Programs: A Fast-Track Strategy for Reducing Cost of Quality
The trick is managing the complexity of these unique audits. By Eric Stoop
Eric Stoop
October 31, 2017
In automotive manufacturing, reducing quality costs can be like trying to bail out a leaking boat. You can empty bucket after bucket over the side, but you can’t get above water until you plug the leaks themselves.
Previous 1 2 … 23 24 25 26 27 28 29 30 31 … 273 274 Next
