How Much Does That Calibration Test Really Cost?
The true cost of calibration testing often stays hidden, escaping scrutiny in operational and maintenance metrics.
By Greg Cenker
Professional calibration of pressure gauges and sensors. Working person sits at desk and is engaged in verification of instrumentation.
Image Source: Sergey Pakulin / iStock / Getty Images Plus
April 30, 2025
Calibration lab managers and sales teams typically quote customers based on ideal conditions—assuming the test passes, with minimal risk, everything in tolerance, and no adjustments required. As a former lab manager, I can confirm this isn’t always the reality. The true cost of calibration testing often stays hidden, escaping scrutiny in operational and maintenance (O&M) metrics.
When these hidden costs surface, some managers quickly blame the lab for delays. Yet, by leveraging risk control tools, investing in high-quality test equipment, and making smart decisions about adjustments, labs can effectively reduce these concealed costs.
In this example, we analyze a recalibration test of an “Acme” model 123 Digital Multimeter (DMM) using an “Acme” Multifunction Meter Calibrator (MMC) as the reference standard. The test includes 22 Test Points (TP) with a maximum Probability of False Accept (PFA) of 2%. It takes one hour, costing $200 (including salary and benefits). We focus on the Probability of False Reject (PFR) risk, as the lab cannot quantify the cost of falsely accepting an item, but PFR can be measured and tracked for a more accurate understanding of recalibration costs.
The PFA and PFR formulas, based on a complex bivariate cumulative distribution function, are included in an unprotected Excel workbook available for download, allowing users to explore these functions. The omitted PFAGBMult function, which calculates a guard band multiplier for symmetrical or asymmetrical tolerances using a bisection routine, can be referenced in the VBA code within the Excel file. This multiplier adjusts test tolerance to manage compliance risk.
The document emphasizes PFR over PFA for cost analysis because PFR can be tracked and quantified by the lab, whereas the cost of falsely accepting an out-of-tolerance (OOT) item is borne by the customer and thus unknowable to the lab.
To make this a meaningful metric, a few setup parameters need established. These are
  1. The loaded hourly internal billing rate: $200
  2. Estimated re-calibration testing time: 1 hour
  3. Maximum allowable risk, known as PFA, which is a value of 2% typically. This value ensures that any items calibrated by the service lab have an in-tolerance probability of 98%
  4. The initial in-tolerance probability of the Unit Under Test (UUT)
    1. If true historical information is available about the actual EOPR of the UUT, enter that known value. (e.g. 95%)
      1. If no information regarding EOPR of is known or available, the conservative estimate for EOPR is ~91.67%. This is derived from the normal distribution function for the SQRT(3). Using Excel, it is = 2 * NORM.S.DIST(SQRT(3),1) – 1
  5. Test Points (TPs): 22, measured against an “Acme” Multifunction Meter Calibrator (MMC)
Process:
With inputs entered, we:
  • Create a TP data sheet
  • Assign reference standards
  • Perform uncertainty analysis
  • Calculate PFR
  • Enter “as-found” measurements
  • Determine tolerance status (blank for in-tolerance, “FAIL” for out-of-tolerance)
Workbook Details:
The downloadable Excel workbook contains all setup formulas and a random function, NORM.INV(RAND(), Nominal Value, Expanded Measurement Uncertainty), to simulate UUT failures. Only results and costs are shown here. Press “F9” to update OOT values.
The results for our test data are shown below in Table 1
Table 1: Results for Test Data
Table 1. Source: Morehouse
Table 1 Explanation:
  • Result Column: 'FAIL' indicates the test point (TP) is out of tolerance.
  • PFR Column: Shows the Probability of False Reject (PFR) for each TP, indicating risk level.
  • Cost Column: Calculates cost for each failed TP as $200 × PFR.
  • Certainty Column: Reflects confidence in correctly identifying an out-of-tolerance (OOT) condition and deciding to adjust (e.g., 48.8% for 25µA and 42.1% for 100µA on the 100µA range).
  • TUR Column: Test Uncertainty Ratio (TUR) = (UUT tolerance span) / (2 × expanded uncertainty), as shown in Figure 1.
Figure 1: TUR Column: Test Uncertainty Ratio (TUR) = (UUT tolerance span) / (2 × expanded uncertainty)
Image Source: Greg Cenker
The divisor consists of all the applicable uncertainty contributors. For symmetrical specifications, it can be expressed as shown in figure 2 and provides the same result (the span being replaced by a single ± tolerance and divided by the expanded uncertainty).
Figure 2: Expression for symmetrical specifications
Ideally, the TUR should be held at a value of 4.0 or greater as this provides the highest confidence if any TP is OOT. This higher value provides ~98% certainty the OOT condition is truly OOT and likely requires adjustment.
The Actual Testing Cost (top left area) consists of the initial calibration cost + sum of costs due to failed TPs (calibration cost x PFR) + As-Left verification. The ideal calibration cost went from $200 to an actual $753.91.
Should any out-of-tolerance (OOT) conditions arise, the recalibration cost will double to $400; however, the primary focus remains on failed test points (TPs) with low confidence in identifying OOT status and determining necessary adjustments. These failed TPs represent a hidden cost that many lab managers and sales representatives often overlook when providing recalibration service quotes.
The true cost of calibration testing often surpasses the initial quote due to hidden expenses tied to test point failures and the adjustments they necessitate. By focusing on the Probability of False Reject (PFR), labs can quantify these concealed costs and make strategic decisions about whether to adjust instruments. Employing risk control tools, investing in high quality test equipment, and maintaining a Test Uncertainty Ratio (TUR) of 4.0 or greater are critical steps to minimize these costs and boost decision-making confidence. As shown in the recalibration of the “Acme” model 123 Digital Multimeter, what starts as a $200 test can rise to $753.91 when PFR-related risks are factored in. This deeper insight into calibration expenses not only refines cost accuracy but also underscores the value of equipment upgrades, paving the way for enhanced lab efficiency and greater customer confidence.
READ MORE FROM GREG CENKER
  • Unraveling the Tom Brady Deflategate
  • The Definition of a Fool is a Drowning Man Who Tries to Keep It a Secret
  • Ensuring Data Integrity
LISTEN
  • Podcast | This Quality Show Workshop Will Offer Pain Relief for Measurement Headaches
KEYWORDS: calibration cost of quality manufacturing metrology
Greg Cenker serves as Senior Metrologist at IndySoft, Inc. and brings 42 years of experience in metrology and calibration laboratory operations. Prior to joining IndySoft, he held roles as a bench technician, metrology engineer, and laboratory manager. In his current position, he develops statistical tools and training materials for IndySoft Software and the broader calibration industry. He may be contacted at [email protected].
  • QTY July 2021 Back2Basics: Leak Test 101 feature. Source: Getty Images
    Leak Test 101: The Basics Rule, No Matter How Much Technology Evolves
  • VIDEO BLOG: How Much Training is Enough?
  • This image shows two individuals in high-visibility orange jackets and white hard hats collaborating in an industrial setting.
    If Safety Is on the Line: Designing a Quality Strategy That Does Not Overtrust Tools
