MeasurementManagement
Calibrating Humidity for Data Centers
Proper calibration is essential to ensure these sensors deliver trustworthy data, but data centers face significant challenges when calibrating these devices.
By Abhishek Kamerkar
calibration
Image: tiero / iStock / Getty Images Plus
June 24, 2025
  • The Standard Explained: What is ISO 17025: 2017?
  • The International Definition of Calibration, Verification, Validation, Certification, and Adjustment
  • ISO 17025 standards
As data centers continue to evolve into vital infrastructure, maintaining environmental compliance and operational reliability are increasingly important. Environmental compliance encompasses factors like temperature, dewpoint, and humidity.
The American Society of Heating, Refrigerating and Air-Conditioning Engineers (ASHRAE) TC 9.9 outlines specific humidity recommendations for maintaining optimal conditions for sensitive electronics. Data centers rely on hundreds of humidity sensors to provide real-time, precise information to comply with these recommendations, but even a single inaccurate reading can cost a data center millions of dollars in downtime, penalties, and equipment damage. Proper calibration is essential to ensure these sensors deliver trustworthy data, but data centers face significant challenges when calibrating these devices.
The Importance of Humidity Control
ASHRAE TC 9.9 recommends maintaining relative humidity between 40 and 60% for equipment safety, though modern systems may tolerate a wider range depending on the equipment class and manufacturer’s recommendations.
Humidity below recommended levels creates a higher potential for electrostatic discharge, increasing the risk of damage to sensitive electronic components. This can lead to shortened equipment lifespan, increased costs, and lost revenue. Experts estimate the cost of electrostatic discharge (ESD) damage in the electronics industry is at least half a billion dollars per year. Conversely, humidity above this range can cause condensation buildup, resulting in equipment damage, electrical shorts, and corrosion.
Humidity control is preventive protection that safeguards uptime, preserves infrastructure investments, and ensures the environment remains stable enough to support the nonstop demands of modern data processing. Effective humidity control goes beyond meeting ASHRAE standards. It plays a vital role in safeguarding sensitive data, upholding Service Level Agreements (SLAs), and avoiding costly equipment damage.
Why Calibration Matters
Even the most stringent humidity monitoring protocols are only as accurate as the sensors taking the readings. Sensors can drift over time, and the humidity percentage displayed on the monitor may not be accurate.
In a data center environment, even short-term inaccuracies can have significant consequences, especially when SLAs are involved. A single deviation, even one caused by a faulty sensor, can trigger a cascade of issues that undermine both compliance and credibility.
Inaccurate readings can prompt unnecessary HVAC adjustments, destabilizing the climate and putting equipment at risk. Overcooling or excessive humidification due to inaccurate sensors can drive up energy use and operating costs unnecessarily. In large-scale facilities, even small inefficiencies can scale into thousands of dollars per year in wasted energy. Proper calibration ensures HVAC systems respond only when needed, helping data centers reduce their carbon footprint and reduce utility costs.
Just as critically, these false readings can be logged as environmental violations potentially breaching SLA terms, even if the actual conditions remained within the correct range. For data centers supporting industries like healthcare, finance, or government, these missteps can also lead to audit failures or regulatory scrutiny.
Properly calibrated humidity sensors are a frontline defense against SLA breaches and operational misjudgments. By ensuring humidity sensors are correctly calibrated and providing reliable readings, data centers can protect the integrity of their services.
Calibration Best Practices
There is no one-size-fits-all frequency recommendation for humidity sensor calibration. However, many data centers opt to perform calibration on an annual basis. For data centers located in particularly humid environments, more frequent calibration, such as semi-annually, may be prudent.
However frequently calibration is performed, the calibration must be documented and traceable. The documentation must be able to stand up to internal audits, SLA verification, and regulatory inspections. Each humidity sensor must have a traceable calibration record, showing when it was last tested, the reference standard used, and whether it passed or required adjustment.
Calibration Challenges
Humidity sensors in data centers are typically located in critical areas such as the white space, server racks, air handlers, and return ducts, locations that are essential for accurate environmental monitoring but often hard to access. These zones are protected by strict security protocols designed to safeguard sensitive data and equipment. Staff often face layers of clearance requirements, tightly controlled maintenance windows, and the need to coordinate with both facility and IT teams to ensure operational continuity during calibration.
These restrictions introduce real-world complications into what might otherwise be a routine process. For example, bringing in external calibration equipment may require advance approvals, escorted access, or adherence to strict change management protocols. In some high-security environments, even transporting calibration data off-site for documentation purposes must be handled carefully to avoid violating data governance policies.
Outsourced vs. In-house Calibration
While many data centers elect to outsource their sensor calibration, this process can introduce several challenges. First, to maintain security in highly sensitive white space areas, any contractor and its employees must be thoroughly vetted and their access carefully controlled and scheduled. Second, for data centers that elect to send sensors to an outside lab for calibration, the timeline and logistics are largely controlled by a third party, making it challenging to comply with internal maintenance schedules. Third, sending devices off-premises poses inherent security risks from third-party personnel and their internal procedures. And finally, costs for calibrating hundreds of sensors annually can quickly escalate, limiting the center’s ability to invest in growth.
Many data centers, particularly hyper-scale data centers, are shifting to in-house calibration using specialized tools that simplify the process while still enabling calibrations that reach ISO 17025 standards, which, while not mandatory, establish credibility. These tools work by generating humidity and temperature in a controlled chamber with a drier and humidifier system. The calibrator measures the difference between the humidity and temperature in the chamber and compares it to the sensor being tested. If there is a discrepancy, the sensor can be adjusted in order to take accurate readings. These devices are portable, configurable for measuring multiple sensor sizes and specifications, and some may even have the ability to test multiple sensors simultaneously, saving time without compromising data integrity.
In-house calibration allows the data center to maintain strict security protocols by using only staff with the proper clearance levels to perform the calibration. Staff can be thoroughly trained on proper calibration protocols and provide the documentation necessary for audit compliance, and calibration can be performed on the correct schedule without relying on the availability of an outside vendor. Though purchasing the calibration tool can be a large investment, many data centers recoup their costs faster than expected.
Bridging Compliance and Operations
As data centers grow in scale and criticality, the margin for environmental error continues to shrink. Maintaining ASHRAE TC 9.9 compliance is more than a regulatory checkbox, it’s a proactive defense against equipment failure, service interruptions, and costly SLA violations. Accurate humidity monitoring is only as strong as the sensors behind it, and ensuring those sensors are regularly and properly calibrated is essential.
Whether calibration is handled in-house or outsourced, the process must account for the realities of secure environments, documentation requirements, and the high stakes of uninterrupted operation. By investing in proper tools, staff training, and traceable calibration practices, data centers can take control of their environmental monitoring and protect the integrity, reliability, and reputation of the services they deliver.
As data centers continue to grow, smart environmental monitoring practices will be just as critical as the servers themselves. Data centers must prioritize calibration to future-proof their operations in an era of growing demand.
KEYWORDS: calibration data collection manufacturing metrology standards
Abhishek Kamerkar, Product Manager, Fluke Corp.
  • a modern data center server room
    Beyond the Checkpoint: Building Quality into Data Centers
  • ATEQ Metrology Laboratory,
    Ensuring Reliability in Data Centers: The Evolving Role of Leak Testing
  • QM 0723 Software and Analysis AI
    AI for Data Collection is Here!
    NAVIGATING BIG DATA ANALYTICS
  • Data Optics Inc.
    Data Optics is a manufacturer of precision optical research equipment and a dealer / distributor of optical measurement instruments.
