Learning to See the Quality Stream
By creating the value stream map and overlaying each quality process, we were able to see missing data, key constraints, balance of labor, waste in each process and time constraints.
By Mark Preston
Intro Image Quality Stream Map Pic 4
Image Source: Mark Preston
July 27, 2025
Are you making decisions based on “Big Picture Data” or rather “Who Yells the Loudest”?
As a leader, we can often become distracted by fighting the fires of daily management.
Great leaders take the time to collect data and see the big picture in order to focus on the biggest constraint, opportunity, or gap. Never become distracted by those yelling the loudest. Focus your actions on data. One of my favorite quotes is, “In God I trust, all others bring data!” It may very well be true that the squeaky wheel should get the grease but there may be bigger problems to address first. To see the big picture for Quality, try using a lean tool that I call quality stream mapping.
If a quality auditor came and audited your facility, they would be amazed if they could see your entire quality system from supplier to customer on one wall or in one big picture view. Details and systematic improvement could then easily be seen and assessed for planned actions. Quality stream mapping can help any organization.
Critical thinking connects big picture thinking with logical ideas.
When making decisions, we must look at the big picture, understand the current state with data, and form priorities of focus. Leaders must develop critical thinking skills that help drive through the noise or drama and see the most beneficial actions based on the big picture for the company.
Where should you begin? Start with a Foundational Value Stream Map
Value Stream Map Definition: All the activities (both value-added and non-value added) required within an organization to deliver a specific product or service.
“Everything that goes into” creating and delivering the “value” to the end-customer.
I see value stream mapping as a multi layered, 3D spider web that connects everything in the company. Most people do a high-level value stream map that shows: product or service flow, communication flow, and key time and value-added data to identify constraints and opportunities.
I agree that this is a great first step, but this article may help you understand the true connectivity that a value stream map can give your organization.
Lean Figure 1
What are the benefits of Value Stream mapping?
Value stream mapping helps you:
  • Visualize more than a single process
  • See the sources of waste
  • Provide a common language
  • Make decisions about visible flow
  • Show the linkage between information and material flow
After you create a foundational value stream map with the current state, opportunities for improvement, future state map, and improvement plan, you are ready to take the foundation to the next level.
Next Overlay Key Systems on Top of your Value Stream Map
Back in the day, we used overhead projectors instead of Power Point.
We would lay down sheets of plastic on the light lamp and it would project anything written on the clear sheet on the wall. You could also lay a sheet on top of another sheet and layer information to project it on the wall. Think about this layering in terms of a value stream map. After you have completed a foundational value stream map overlay key systems on top of the value stream map.
Figure 2: Quality Stream Map Example — Overlay on top of Value Stream Map
Overlay your Quality System on Top of your Value Stream Map
Derived from the value stream map, a quality stream map can be used to represent the entire quality stream (enterprise wide). A quality stream includes all quality control actions that occur to a given product from its inception as a raw material through delivery to the end customer. Our focus will be primarily from supplier final inspection to customer incoming inspection.
I started quality stream mapping over 15 years ago to improve my supplier’s quality yield for CPAP motors. We wanted to see the big picture for quality and understand what key actions were needed based on data throughout multiple quality processes. By creating the value stream map at the supplier and overlaying each quality process, we were able to see missing data, key constraints, balance of labor, waste in each process and time constraints. We created a focused plan and drove problems out of the entire system.
This was a great way to visualize the entire quality system for a total view of all processes. Think about if your ISO inspector came and saw the entire plants quality system blown up and displayed on the wall. Details and systematic improvement could then easily be assessed. Inspections such as receiving inspection, in process inspection and final inspection could be seen.
Visualization of quality information flow such as quality alerts, non-con reporting, return information flow and defect reporting are just some of the things to display and learn from on the quality stream map. All the templates used in quality were also displayed on one wall around the associated areas of the map. By doing this we were able to see redundant information without value and create standards. Critical to quality product points were also identified for suppliers and communicated from to us from customers.
This is a quality stream map data collection Check list detailing the areas and data that should be collected for the big picture view.
Quality Stream Map – Data Collection Checklist
Design Quality Elements and Systems
Phase Gate Process Verified
DFM - Design for Manufacturing
FMEA - Design and Process Failure Mode Effect Analysis
l
Quality Product Plan Created
Product Requirement Matrix from Marketing Requirement Spec and Design Goals Spec.
Summary of Regulatory Controls Requirement
Engineering Change Order during Design Process
Life Test Action Items from Findings
Environmental Test Action Items from Findings
Purchasing and Suppliers
Approved Supplier Process - Verify Approved Suppliers on Product
Supplier Audit System
Supplier Scorecard System
Supplier Corrective Action Reporting System
Traceability of Parts Information
Supplier Guidebook
Supplier Change Notification Process
Production
Standard Work Verification and Update
Cross Training Verification and Update
Critical to Quality Points of the Product
Utility - Water, Air, Controls and Risk
Traveler standard work and Call outs
ECO - Engineering Control Order System
Software Revision Control - Verify current Revision in process
Customer Supplied Product - Control System
Scrap Information
Visual Final Inspection
Rework Process and Standard Work - Findings
Shipping and Customer
Shipping Damage - RMA - Return Material Authorization
Customer RMA - Findings
Replacement Process for Damage
Evaluation from Customer Process - Corrective Action System - Escalation
Customer Satisfaction Process
Inspections
Supplier Inspections
Incoming Inspections
Internal Supplier Inspections
Production Inspections
Production Audits
Lot Inspection Audits
Visual Inspection
Customer Inspections
Systems
Non-Conformance System Supplier
Non-Conformance System Production
Non-Conformance System Customer
Calibration Control System
Corrective Action / Root Cause Counter Measure System
Preventative Maintenance System
Key Deliverables
Value Stream Map
Quality Stream Map
Pictorial VSM
Plant Flow of VSM
Metrics from each Area of VSM
Gap Analysis
Transformation Plan
Link Other Key Information to your Value Stream Map
Think of a value stream map as a spiderweb that connects key information to ensure that it is present and updated. Another great unknown function of value stream mapping is linkage to critical information. You can link anything important to the associated area of a value stream map. By linking information, it makes it very easy to see what you have, what you are missing and what you need to update.
Information that I link to Value Stream Maps:
  • Standard Operating Procedures
  • Work Instructions
  • Standard Work
  • Templates
  • Process Maps
  • Department Playbooks
Time to Get to Work
Just like a good garden needs constant tending, your value stream and quality stream need continuous improvement. It’s a journey, not a destination. You must keep asking those tough questions, dig for root causes, and never settle for good enough.
No better time for action using value stream mapping and quality stream mapping than now! You have a much better chance of creating a great annual improvement plan if you have a value stream map, a quality stream map and a linked value stream map. Improve the way you improve. Seeing the big picture will set you up for success!
  • The Secrets to Creating an Effective Value Stream Map
  • Strategy Planning and Deployment: A Tool to Achieve Excellence
  • The Role of Lean Daily Management in Sustaining a Lean Culture
KEYWORDS: auditing lean manufacturing mapping quality
Mark Preston is the president / CEO of Lean Applications LLC. For more information, call (404) 308-2898, email [email protected] or visit Leanapplications.io. Mark has been driving change in manufacturing, office, and sales environments for 35+ years. He is passionate about improving People, Processes, and Products. After graduating Georgia Tech, he studied kaizen manufacturing techniques in Japan with TDK. After 11 years with TDK, he then held various executive operations positions at Respironics / Phillips including setting up Global Sourcing for Respironics, creating the Respironics Supplier Development Program and heading the companies Asthma and Allergy Division. After 8 years, he became the director of Acuity Business System at Acuity Brands Lighting and later, Vice President of supplier development and operational excellence. After Acuity, Mark created his own company Lean Applications and continues to help companies all over the globe reach their potential for excellence. Mark was the Director of the AME (Association of Manufacturing Excellence) Champions Club and served on its national board. His book, “Southern Sensei,” takes readers on an engaging application-based approach to further their lean journey. Mark also helped write and launch the AME Lean Sensei Assessment, which helps companies assess their progress on their lean journey.
  • Minitab
    Do Executives See the Impact of Quality Improvement Projects?
  • Quality Test & inspection: See the Forest and the Trees
  • Quality America Inc.
    Since 1982, Quality America's customer-driven approach to software support and development has led to innovative SPC and Calibration Management software, sold separately or combined, used by thousands worldwide. Learn SPC, Lean Six Sigma and Quality Management skills from a leading author and subject matter expert, who's helped thousands of students achieve certification.
