ManagementVision & Sensors
CSIA Column | Joshua Chenault
The Hidden Costs of Vision System Integration
Most clients start their vision system projects with understandable optimism.
By Joshua Chenault
High-quality control in manufacturing optical sorting machine for fasteners nuts in product line.
Image Source: MJ_Prototype / iStock / Getty Images Plus
October 12, 2025
As control system integrators, we’re often brought in after the initial excitement around a new vision system begins to fade and challenges have begun to appear. What began as a plug-and-play solution has started creating frustration for plant engineers and quality teams. The system technically operates, but not in the way anyone expected, and certainly not without significant additional effort.
Most clients start their vision system projects with understandable optimism. Vendors give impressive demonstrations which are often set up under ideal lighting, with a handful of stationary parts for inspection, using basic software inspection tools, and assumptions are made regarding a good or bad part. It looks like a simple case of mount, configure, and go. But once the system hits the production floor, that simplicity tends to disappear.
One of the most common issues we encounter is the assumption that a vision system will perform at the same level as a manual inspection station, only faster. In practice, these systems demand precise environmental control, consistent part presentation, and careful calibration. Even with those in place, performance can vary based on lighting changes, part tolerances, or slight misalignments. When the system rejects good parts or lets defects pass through, confidence in the solution quickly drops.
LEARN MORE
  • Do I Need a System Integrator for My Machine Vision Application?
  • Vision & Sensors 101: Machine Vision System Integration
  • Traditional Machine Learning for Practical Machine Vision: It’s Been There All Along
Clients often underestimate the challenges of implementation. They are often sold on basic software functionality and ease of installation. Often, they expect expert level support from the vendors. In reality, most vendors focus on hardware and software tools, leaving the end user looking elsewhere for wiring, logic configuration, and system integration. By the time we’re called in, that gap between expectation and reality has already caused disappointment, delays, and cost overruns.
Hidden costs accumulate quickly. We have seen teams spend weeks repositioning cameras, adding lighting, or retrofitting conveyors to improve consistency. In some cases, teams need to install additional sensors or actuators just to achieve reliable image capture. These additions are not part of the original plan, but they often become necessary for basic functionality.
In one instance a client struggled to determine part presence due to constraints in mounting the vision hardware and inconsistencies of the part presentation. A handful of cameras were purchased based on an off-line presentation that overlooked the full production process, leaving the client in a dilemma. They needed to design mechanisms to get their vision hardware into position, purchase additional vision hardware, or alter the process to achieve their quality goals.
Quality teams tend to feel the strain most directly. Rather than focusing on process improvement, they are pulled into supporting a system that was meant to support them. Time is spent troubleshooting image failures, adjusting software thresholds, and explaining why a defect was missed or a good part was flagged. Production teams lose trust in the system, and the intended benefits aren’t recognized.
From our perspective, most of these issues can be reduced or avoided through early planning and realistic expectations. We always recommend involving integration and controls teams during system design and hardware selection, not just after purchase. Pilot testing with real production parts and environmental conditions is essential. What works in a vendor’s demo room may not work on a busy production line.
It is also important to be clear about what the vision system does and what it does not do. A camera and software package are not a finished inspection solution. They are components that require tuning, support, and a fair amount of customization to meet production needs.
Vision systems have great potential; they can improve quality and reduce human error when applied correctly. However, without proper integration, they can just as easily become a source of downtime, cost, and frustration. As integrators, we see both sides. We know that smooth, effective deployment starts with involving the right people early and planning for the full scope of what these systems really require.
KEYWORDS: cost of quality machine vision manufacturing metrology system integration
Josh chenault
Joshua Chenault, Project Engineer, MartinCSI. MartinCSI is a certified member of the Control System Integrators Association (CSIA)
  • Datum Optimization
    Design Now, Save Later: The Hidden Costs of Late-Stage Manufacturing Changes
  • Surehand white paper
    The Hidden Costs of Hiring in Industrial Inspection: Time for a New Alternative
  • VS 0122 Vision & Sensors 101
