ISO 9001: The Most Recognized Standard—and the Least Truly Used
From my experience, the companies that struggle the most are those that treat quality as a department rather than a way of working.
By Dr. Ramazan Gücükturalı
Industrial worker wearing a hard hat and high-visibility vest inspecting equipment and reviewing maintenance data on a tablet in a manufacturing facility.
Image credit: onuma Inthapong / Getty Images (Creative #2218147500)
June 28, 2026
You don’t need a full audit report to understand the real quality level of a company.
A few minutes on the shop floor is usually enough.
I’ve walked through dozens of facilities across different sectors—heavy industry, machining, energy systems, and more. And in most cases, the pattern repeats itself.
Operators continue production without measurement. Defective parts are set aside “for later review.” The same issues reappear shift after shift.
And almost always, there is a certificate on the wall—usually ISO 9001.
Globally, millions of organizations operate under this standard. It is the most widely adopted quality management system by a significant margin. Its flexibility and accessibility make it easy to implement across industries.
But that is also where the problem begins.
Because what is easy to obtain is often easy to misunderstand.
What Audits Reveal—and What They Don’t
Having conducted and observed numerous audits, one reality stands out clearly:
Most systems are designed to pass audits, not to run operations.
During audits, everything looks structured. Documents are in place. Records are complete. Processes appear controlled.
But step into the production area, and the system often fades away.
I have seen production lines where procedures existed for every step, yet operators had never read them. I have seen detailed inspection records being filled out perfectly—while the same defects continued to occur. I have seen corrective actions closed on paper, but the root causes still active on the floor.
At that point, the system is no longer managing quality.
It is managing appearances.
A system that only works during audits does not exist.
Where Quality Actually Lives
One of the most common misunderstandings is the belief that quality is something checked at the end.
But in real operations, quality starts much earlier. It starts when a material is selected. It starts when a tolerance is defined. It starts when a process parameter is set.
When quality is isolated, problems are detected—but not prevented.
When quality is integrated, problems are prevented before they appear.
Quality is not inspected into a product. It is built into the process.
The Gap Between Data and Decision
In recent years, nearly every company I have worked with has implemented some form of enterprise resource planning (ERP). Production is tracked. Inventory is tracked. Purchasing is tracked.
But quality?
In many cases, it still lives outside the system. I have seen companies with fully integrated ERP environments, yet quality data was being managed in isolated spreadsheets. Inspection results, nonconformities, and corrective actions were disconnected from the main operational flow.
This creates a fundamental limitation. You can analyze what happened last week. But you cannot influence what is happening now.
Real quality management is not retrospective. It is real-time.
From Detection to Prediction
One of the most significant changes I’ve observed in the field is the growing role of Artificial Intelligence.
In the past, quality systems were designed to detect defects.
Today, they can anticipate them. I have seen systems where machine data, process variation, and historical patterns are analyzed to identify early signals of failure. In such environments, the conversation changes completely.
Instead of asking: “Why did this defect occur?”
The question becomes: “What is about to go wrong?”
This shift—from detection to prediction—is where modern quality management is heading. But there is a critical point that must not be ignored. Artificial intelligence does not fix weak foundations. If processes are not clearly defined, if data is inconsistent, if discipline is missing…
Advanced tools will not improve the system. They will simply expose its weaknesses faster.
This is why ISO 9001 still matters—not as a certificate, but as a structure.
What Actually Works in Practice
Across all the audits and projects I have been involved in, one thing has remained consistent:
Effective systems are not the most complex ones. They are the ones that are actually used.
From a practical standpoint, a few principles make a real difference:
Do not build your system for audits. Build it for operations.
Keep procedures simple enough to be followed under pressure. If they are not used on the floor, they are irrelevant.
Collect data—but more importantly, act on it. Data without action is noise.
Do not place quality at the end of the process. Embed it into every step.
Use digital systems, but do not depend on them blindly. Technology supports decisions—it does not replace responsibility.
In the End, It’s About How You Work
ISO 9001 is not the problem. But it becomes ineffective when treated as a formality.
In strong organizations, quality is easy to recognize.
Problems are not hidden. They are brought forward. Analyzed. And they do not repeat.
In weaker systems, the opposite happens. Problems are covered, temporarily resolved, and eventually return.
After years of observing different companies, one conclusion becomes clear: The question is not whether you have ISO 9001. The question is whether quality is truly part of how you work.
If it is, the system delivers results. If it is not, the system remains visible—but ineffective.
And on the shop floor, that difference is immediately obvious.
LEARN MORE
  • Upcoming Changes in ISO 9001
  • ISO 9001 in 2026: What’s Changing—and How AS9100 (IA9100), IATF 16949, NIST & CMMC Fit Together
  • Auditing 101: Understand the Audit Process Before Starting One
KEYWORDS: auditing ISO 9001 manufacturing metrology root cause analysis
Dr. Ramazan Gücükturalı is the General Manager of Turalı Group. https://www.turaligroup.com/en
  • Airplane ready for maintenance
    The Evolution of Quality Standards: From ISO 9001 to the 9100 for Aerospace
  • ISO 9001:2015 and the Advantages
  • ISO Standards
    ISO 9001:2015 Implementation: The Good, the Bad and the Trending
  • isoTracker Solutions Ltd.
  • HSB Registration Services
    HSB Registration Services is accredited by the International Accreditation Service (IAS). Our network of technical personnel, together with one of the largest and most skilled audit and inspection staff in the world, provides industry-specific experience to make your ISO 9001, ISO 14001, and ISO 45001 certification a reality.
