Home » Topics » Channels » NDT
NDT RSS Feed RSS
Universal hardness tester from Buehler Wilson.
Buehler Wilson Universal Hardness Tester
April 1, 2019
Buehler announced its latest addition to the Wilson hardness testing range, the new UH4000 Se-ries Universal Hardness Tester.  This tester comes in two key configurations: UH4250 Hardness Scale 0.5-250 kgf and UH4750  Hardness Scale 3-750 kgf.
Subsea inspection solution from Eddyfi Technologies.
Eddyfi Technologies TSC U41 Subsea Inspection Solution
April 1, 2019
Building on the previous model, the U41 brings 14 times the data resolution, performs data ac-quisition 10 times faster and the ability to inspect coating twice as thick as before. These benefits promise to deliver increased revenues and a quick return on investment for our customers.
FPI Indication
NDT Flaw Detection 101
We’re always faced with deciding which nondestructive testing method is the most appropriate for detecting a specific flaw type.
Gregory James Weaver
April 1, 2019
According to ASTM E1316-17a and NET.net, a flaw is defined as ‘‘an imperfection or discontinuity that may be detectable by nondestructive testing and is not necessarily rejectable.”
Stress testing
Bearing Properties: The Impact of Residual Stress and Retained Austenite
Regardless of a bearing’s intended use, it must be designed and manufactured to withstand difficult environments.
Daniel Klawonn Will McAlexander Beth Matlock Snipes
April 1, 2019
As one of the most common mechanical components in the world, roller elements are of critical importance. It is necessary for bearings and raceways to be carefully engineered and manufactured so that the machines which use them are as safe and stable as possible.
To demonstrate proper magnetization, first you need to know what’s in the procedure.
8 System Performance Tools for Magnetic Particle Inspection
Learn more about magnetic particle inspection tools and requirements.
David Geis
April 1, 2019
This article will list and explain why each magnetic particle inspection accessory is needed to validate the system performance of an inspection.
Zetec
NDT Headline
Zetec Names Jenstead Director of Sales for the Americas
March 18, 2019
Zetec Inc. announced the hiring of Wade Jenstead as Director of Sales, Americas.
Olympus
NDT Headline
Olympus Launches New Industrial Research Chair at Quebec Engineering School
March 4, 2019
Partnership outlines 5-year strategic plan to tackle challenges in NDT.
Carestream
NDT Headline
Carestream NDT Appoints New Leadership for Europe, Middle East and Africa Regions
March 4, 2019
Carestream’s Non- Destructive Testing (NDT) business has experienced rapid growth and is ex-panding operations in the Europe, Middle East and Africa region (EMEA).
Fig. 1. Lung ventilator component.
Computed Tomography Scans: The Latest Tool for Industrial Quality Evaluation
There is virtually no limit to the quality evaluation applications of CT scanning.
Dirk Steiner
February 1, 2019
Computed tomography (CT) uses irradiation to produce 3D internal and external representations of scanned objects. The beginnings of CT scanning technology date back to the early 1970s. Although it was originally developed for medical imaging, CT is now used in a wide array of industrial applications including flaw detection, failure analysis, metrology, assembly analysis and reverse engineering.
Dye penetrant testing
The Ultimate Guide to Visible Dye Penetrant Testing
Some handy tips for beginners who are new to visible dye penetrant testing or NDT pros who want an easy reference guide.
Cheri Stockhausen
February 1, 2019
The dye penetrant method of inspection is a nondestructive test for defects open to the surface. It may be used on such materials as aluminum, magnesium, brass, copper, cast iron, steel, stainless steel, carbides, stellite, certain plastics and ceramics.
Previous 1 2 … 32 33 34 35 36 37 38 39 40 … 168 169 Next
