Home » Topics » Quality Top Stories
Quality Top Stories
Quality Top Stories RSS Feed RSS
Software: Digital First feature photo. Source: iStock
Software & Analysis
A Corporate Commitment to Quality Requires a Digital-First Approach
Four Trends Shaping the Next Gen in Quality Management
June 10, 2021
Read about the four trends shaping the next generation in quality management and what's driving the new era in digital-first quality.
NDT | Leak Testing
E-Mobility Gives Automakers a Host of Leak Detection Challenges
EV battery cells, battery packs, electric motors and other systems modified for EV applications all require leak testing to assure both quality and safety.
Thomas Parker
Thomas Parker
June 9, 2021
The rapid and unexpected growth in the production of alternative drive systems is presenting automakers and their suppliers with a host of leak-detection challenges to ensure vehicle safety and quality.
Magnaflux MPI. Image Source: Magnaflux
NDT | Back 2 Basics
The Most Common Misunderstandings about Magnetic Particle Testing
When in doubt, always check with a certified Level III or contact your NDT product supplier.
June 9, 2021
Generations of NDT professionals have used the magnetic testing method, and along the way, a handful of common misunderstandings have developed. This article explores these common and incorrect assumptions about magnetic particle inspection and how to combat these misunderstandings.
Eurofighter Jet Engine. Source: Phoenix LLC
NDT | Radiography
Neutron Radiography and Turbine Blades
Neutron Radiography Works on the Same Basic Principles as X-Ray Imaging Except With Neutron Radiation Instead of X-Radiation.
Willow Ascenzo
June 8, 2021
Air cooling is the most readily available means for keeping turbine blades from breaking or melting while the engine is running, and in order to get the most from the air streaming through the engine, turbine blades are cast with delicate cooling channels running through them. In the manufacturing process, though, these channels can become clogged. It's important that these defective blades be screened out as thoroughly as possible in quality assurance, and neutron radiography is the most effective nondestructive testing method for this purpose.
Hexagon MI Asset Management feature photo
CMMs Go Collaborative
Is Your Coordinate Measuring Machine Future-Ready?
June 8, 2021
Digital transformation is placing urgent demands on coordinate measuring machines (CMMs) to be interconnected and communicative. Without the ability to collaborate with other systems and workers on the shop floor, CMMs risk becoming an informational black hole that prevents the flow of data required for smarter manufacturing.
Face of Quality
Redefine Audit Strategy
Organizations Have Been Forced to Redefine Their Quality Audit Strategies.
QM 0222 CLMN Face AUTHOR Jim Smith
Jim L. Smith
June 8, 2021
Organizations have been forced to redefine their quality audit strategies to ensure compliance and render support to their supply base. Over the years, I have been involved with championing three categories of audits: on-site, hybrid and remote audits.
Quality 101 Scope 750 feature image
Quality 101
How to Choose the Best Shaft Measurement Tool for your Specific Application
There are Three Primary Options Available Today for Shaft Measurement: Optical, Tactile, and a Combination System
Patrick Nugent
June 7, 2021
There are three primary options available today for shaft measurement: optical, tactile, and a combination system. The optical systems have become common over the past few decades because of their flexibility and speed. So how do you choose the best option for your specific application?
Inside Pipe Crawler
NDT | Training
Remote Visual Inspection an Important Part of the NDT Toolbox
Remote Visual Inspection has Provided Key Inspection Data While Maintaining Safety for its Operators.
Gregory James Weaver
June 7, 2021
Remote visual inspection (RVI) is a nondestructive testing (NDT) technique used for the visual inspection of an object where the person performing the inspection operates a piece of equipment from a distance. Most of the inspection applications used for quality purposes are carried out using three main types of equipment:  borescopes, unmanned aerial vehicles (UAV), and crawler robots. Find out more about their uses and advantages.
Figure 1: CR Phosphor Plate
NDT | Back 2 Basics
The Basics of Digital X-Ray Inspection
Conventional Radiography Will Continue to Have a Pace in NDT, but Digital Radiography is the Future
George Hopman
June 7, 2021
Digital radiography is the future. Read about the most common modalities, computed radiography (CR) and digital detector array (DDA) radiography, that are replacing traditional film-based inspections.
Speaking of Quality | Charles W. (Wes) Shelton
Measurement System Analysis More Than a Line on a PPAP Submission
June 1, 2021
For those of us in the manufacturing world, measurements on products and processes are all important to ensure the products will meet customer requirements, perform correctly, safely, and for a reasonable lifespan. We place our faith in the measurements to accept or reject product—or to adjust the manufacturing process. But are the measurements correct—and how would we know?
Previous 1 2 … 153 154 155 156 157 158 159 160 161 162 Next
