Home » Topics » Quality Top Stories
Quality Top Stories
Quality Top Stories RSS Feed RSS
Quality Magazine: Training that meets the needs of today's manufacturers. Image of people being trained.
Training is Required to Meet the Needs of Today's Manufacturers
Michelle Bangert
Michelle Bangert
June 1, 2021
When the pandemic hit, manufacturers were already behind in terms of embracing new forms of learning. Training people, recruiting new people, troubleshooting problems in training and education is a must for manufacturers and now is the time to do it.
Additive manufacturing inspection. Source: Phuchit / iStock / Getty Images Plus via Getty Images.
TEST & INSPECTION
Changing Face of Additive Manufacturing Inspection
As Manufacturers Embrace Increasingly Complex Materials and Processes, Their Inspection Methods Evolve with Them.
Genevieve Diesing headshot
Genevieve Diesing
June 1, 2021
As additive manufacturing (AM) applications are more widely adopted, processes and material specifications, testing and inspection requirements are all gaining importance.
Utilizing a 3D inspection method provides vital information on the bead such as volume and location on part, it also saves productivity of the operators’ time.
Inspection
Quality and Process Control for the Dispensing Process
For Many Applications, Good Robot Programming is an Art.
Zhenhua Huang
May 18, 2021
Manufacturing industries have been striving for years for a robust quality control solution which can reliably sort out bad parts of the dispensing process without causing much production downtime. What the industry craves is a robust 3D solution that provides a 360° view of the bead regardless of the dispensing direction.
Additive Manufacturing Standards
Manufacturers should be aware of the many standards for this technology.
Michelle Bangert
Michelle Bangert
May 7, 2021
Shane Collins often hears people say that there aren’t any additive manufacturing standards. This is frustrating because he’s worked on additive standards for more than 10 years and there are dozens out now.
two people in hard hats in a factory setting
Assessment of a Best Practice
The goal is to achieve excellent results.
Van Nuland
Yves Van Nuland PhD
Grace L Duffy MBA, LSSMBB
May 7, 2021
In management literature you will often encounter the concept of a best practice. However, until recently no method was available to assess a best practice.
GD&T’s New Rule and What it means for Measurement
Here we will explore the implications of rule "S" and the limits/requirements of today's metrology as it is applied to these GD&T requirements.
Mark Malburg Mike Zecchino AJ Mennuti
May 6, 2021
In Geometric Dimensioning and Tolerancing (GD&T) there has been a long-standing conflict between the worlds of specification and measurement. The goal of specification is to ensure that components will function; the goal of measurement is to ensure that manufactured components meet those functional requirements.
Vision & Sensors | Cobots
Cobots for the Win
Collaborative robots helped manufacturers keep production lines running during the pandemic. They're accessible to small- and medium- sized businesses. And their simplicity just may help to shrink the skills gap.
Genevieve Diesing
May 5, 2021
Collaborative robots, or cobots, help humans and robots work together safely. Small, medium and large companies are increasingly choosing these human-friendly versions over traditional industrial robots, which are complex to use and are typically relegated to safety cages.
Vision & Sensors | Machine Learning
How AI Software Enables More Accurate Quality Inspection
AI is being adopted across industries to harness the power of data and use it to make more informed decisions.
Bruno Menard
May 5, 2021
Artificial intelligence, machine learning, and deep learning are interrelated concepts involved with computer-based learning from vast amounts of data – and then making predictions based on that information. This article will show how these technologies can provide good alternatives to traditional image processing, and how software works to make this happen.
conveyor weighing
Vision & Sensors | Machine Vision 101
The Benefits of Smart Sensors & IO-Link
For many applications, good robot programming is an art.
Dana Holmes
May 5, 2021
A smart sensor is simply a sensor that can communicate to provide real-time diagnostic data and adapt based on that data. The data can be used to optimize a system, reducing costly downtime and increasing quality.
Quality 101
Cylindrical Ring Gages: One Ring to Rule Them All
Cylindrical ring gages may be used as master gages to set variable measuring tools.
Mike Oddy
May 5, 2021
Cylindrical ring gages have a number of inspection purposes. They are used as Go/No-Go gages to inspect the outside diameter of a shaft or rod. They are masters for dial bore gages, internal micrometers and coordinate measuring machines (CMMs).
Previous 1 2 … 154 155 156 157 158 159 160 161 162 Next
