Software
Software
Practical Digital Twins: Getting 80% of the Value with 20% of the Effort
If you’re new to digital twins, you don’t need a moonshot program. You need a clear question, a modest scope, and a disciplined way to keep your model useful.
By Richard Rahn
an automated car manufacturing assembly line utilizing industrial robotic arms
Credit: imaginima / iStock / E+
January 23, 2026
A digital twin is a high-fidelity model of something in the real world – a product, machine, production line, or entire factory – that you can safely test and optimize on a computer instead of the shop floor. It behaves like the real thing, responds to different scenarios, and, in advanced forms, is continuously updated with real data from sensors, systems, and people.
The concept isn’t new. Discrete-event simulation has existed since the 1960s, when engineers fed punch cards into mainframes to model complex systems in aerospace, defense, and heavy industry. During the Apollo program, NASA created detailed physical and digital replicas of spacecraft to diagnose problems and test solutions, an approach that evolved into today’s digital twin technology.
What is new is the level of computing power, connectivity, and data now available. Modern definitions emphasize three elements: a physical system (your line, cell, or factory), a digital representation (your model), and the data connection between them, often called the “digital thread.” When that connection is live, the twin can mirror what’s happening in the real world and help predict what will happen next.
This article builds the case for a pragmatic approach. Most organizations can capture the majority of value with a simple digital twin that is quick to implement, easy to maintain, and tightly aligned with day-to-day decisions. Think of three levels of “digital twinness”:
Phase I – The Simulation Model: A 2D or 3D discrete-event simulation that emulates your value stream reasonably well
Phase II – The Lightly Integrated Twin: The same model fed periodically with real data (daily or weekly) to stay current and support ongoing planning
Phase III – The Fully Integrated Digital Twin: A real-time, or near real-time, living model continuously updated by sensors, systems, and IoT infrastructure
You don’t need to start at Phase III. In fact, you shouldn’t.
Simulation software has been used for process improvement for decades, with many commercial and open-source tools available today, from heavyweight 3D visualization platforms to lightweight discrete-event engines. No matter how far you ultimately go on the digital twin journey, you begin by building a good model of your production line, factory, or value stream.
This is where many teams stall. Simulation tools can be intimidating, the data seems messy, and the project can feel “extra” compared to keeping up with orders. But a solid Phase I model is already a powerful asset, especially in mixed-model environments where product variety, changeovers, and demand volatility create constant variation.
With a Phase I model, you can explore “what if” questions that are either risky, expensive, or impossible to test on the actual line. What if you change the sequence of products? What if you reduce WIP between stations? What happens if you move two operators from one area to another? A discrete-event simulation lets you study throughput, WIP, utilization, and lead time under different assumptions, safely and repeatedly.
Even without live data connection, the model can guide major decisions: new line designs, layout alternatives, capital investments, and product introductions. For many companies, this alone is worth the effort. But the real magic happens when you stop thinking of the model as a one-time project and start treating it as a daily planning tool.
Phase II – The Lightly Integrated “Simple Twin”
Too many simulation models are built for specific projects then quietly retired. Once the new plant is commissioned or the new line is running, the model file is archived and forgotten. Phase II is about avoiding that waste.
In a lightly integrated digital twin, you bring the simulation model into the daily rhythm of planning and operations. You don’t need a massive IoT program to do this. Simple interfaces – scheduled data exports from your ERP/MES, CSV files, or API calls – are enough to refresh the model with current demand, mix, takt, and performance data. The model becomes part of your normal management system, not a science experiment.
A Simple Digital Twin shines in several practical areas:
First, production sequencing. If multiple products flow down the same line, the order in which they run matters. The twin helps test different sequences against constraints such as changeover times, shared resources, differences in work content times, and downstream bottlenecks.
Second, staffing planning and flexing. In a cross-trained workforce, people can move between stations as mix and volume change, and you don’t need to staff every station all the time. The twin shows how many people you need in each area for tomorrow’s planned mix, and where flexing will relieve bottlenecks or reduce idle time. Companies have reported a 30% productivity gain, virtually overnight, by having workers move to the work in a disciplined manner.
Third, continuous line balancing. By feeding back actual cycle times and uptimes, you gradually improve both the model and the real line. As new products are introduced and old ones retired, you can rebalance on the screen first, then implement on the floor with confidence, and quickly.
Fourth, buffer and Kanban design. The right level of WIP is notoriously hard to calculate analytically, especially with product variety. Simulation lets you test different buffer policies against throughput and stability, revisiting these settings as mix and takt evolve.
This is the level most organizations should consciously target. Phase II provides a living, practical planning tool without the cost and complexity of full real-time integration.
Phase III represents what many people imagine when they hear “Digital Twin”: a virtual factory wired into the physical one in real time. Sensors, RFID tags, PLCs, scanners, cameras, and software systems stream data into a high-fidelity model that’s constantly updated.
There are compelling examples in industry. BMW has captured full 3D scans of its production sites and uses them as digital twins that engineers can walk through virtually, across locations and time zones, to plan and optimize lines before changes hit the floor. Similar approaches are being used to design new factories in a “digital-first” mode, commissioning them faster with fewer surprises.
Beyond quick feedback on delays and quality issues, a fully integrated twin offers several further benefits: predictive maintenance using condition data to forecast failures, real-time optimization of production schedules and energy use, improved training through virtual environments, and common collaboration spaces for engineering, operations, and suppliers.
Phase III isn’t overkill in every environment. In highly capital-intensive, high-speed, or safety-critical operations, the business case can be very strong. But the investment in data infrastructure, integration, and governance is substantial. That’s why capturing the “easy” value first is so important.
A Practical Blueprint: Building a Useful Twin in Weeks
Start by clarifying which decisions you want the twin to support in the next 90 days. Is it sequencing tomorrow’s orders? Planning staffing? Testing buffer levels for a new product introduction? Tie the effort to concrete outcomes—throughput, lead time, overtime, or WIP—rather than building a model “of everything.”
Define a tight scope for Phase I: perhaps one mixed-model line or single value stream, not the entire factory. Identify the flow, major resources, and key constraints. Keep the first version intentionally simple; you can add nuance later.
Gather the minimum viable data set: process definitions, process times, routing, changeover times, shift patterns, and key availability parameters. Where measurements are weak, use best available estimates and ranges, marking them for later refinement. Data will never be perfect; it only needs to be good enough to distinguish better from worse choices.
Invest time in calibration. Compare model output to actual historical performance: throughput, WIP, and utilizations. Adjust assumptions until the model reproduces reality within a reasonable band. This exercise both improves the model and surfaces data quality issues worth addressing anyway.
Move to Phase II by setting up lightweight integration. Decide on a refresh rhythm—daily, weekly, or per major schedule change—and define a simple pipeline for updating demand, product mix, and performance data. This can often be done with scheduled reports and imports, or a small script rather than a full-blown IT project.
Finally, put governance around the twin. Assign ownership, define who can change logic versus input data, and agree on when it’s used in the planning cycle. Treat it as a “model of record” for its scope, not just a one-off analysis.
Final Thoughts
The 80/20 rule applies beautifully to digital twins. Phase I and II can deliver 80% of the value for perhaps 20% of the total effort and cost of a fully integrated Phase III solution. While some environments warrant full digital twins, most organizations will benefit enormously from building a good model and using it consistently in daily management.
  • What Goes Around: A Fresh Look at Quality from a Lean Perspective
  • Digital Twins: Elevating Manufacturing Standards and Reducing Errors
  • How Digital Twins & AI Are Transforming Training, Quality & Recruiting in Manufacturing
KEYWORDS: digital twins manufacturing metrology quality
Richard D. Rahn is a principal at Leonardo Group Americas. For more information, call (303) 494-4693, email [email protected] or visit www.leonardogroupamericas.com.
  • Jim's Gems: The Real Value is in the Effort
  • Management feature image of Quality inspector and manual worker in a factory.
    The Price of Excellence: Understanding the Value of Quality, Part 1
  • Senior official woman and male architectural engineer talking, wearing suits and safety hats.
    The Price of Excellence: Understanding the Value of Quality, Part 2
