When Lean Becomes Fragile: Why Being “Too Lean” Is Quietly Killing Manufacturing Productivity
Lean practices can create waste if they come at the cost of resilience.
By Venkata Ravi Kumar Jonnalagadda
Worker wearing a safety vest and hard hat in a warehouse.
Image credit: Portra / Getty Images (Creative #1476176507)
June 12, 2026
For years, manufacturers have tried to become leaner by cutting inventory, staff, schedules, and tolerances to boost agility and cut waste. But in many cases, these efforts have gone too far, making operations fragile rather than efficient.
Across industries like automotive, metal fabrication, casting, steel, and renewable energy, a clear pattern is showing up. Plants that look efficient on paper often deal with frequent stoppages, missed shipments, unstable workflows, and constant crisis management.
The truth is that lean practices can actually create waste if they come at the cost of resilience.
The Misunderstanding That Created Hyper-Lean Factories
Lean was never meant to be a starvation diet for factories, but many companies now see it that way. What started as a careful approach to cutting waste has turned into an obsession with getting rid of anything seen as “extra.”
In many factories, lean has become just a numbers game:
  • zero inventory
  • zero downtime
  • zero spare parts
  • zero floaters
  • zero backup fixtures
  • even zero unplanned tie
These targets might look good in presentations, but they actually make operations more rigid and less resilient.
Real lean systems work because they are flexible. For example, Toyota, the gold standard for lean, never got rid of all buffers. Instead, they used controlled buffers where variation naturally happens, cross-trained their teams, and focused on standard procedures, reliable equipment, and practical safeguards to keep things running smoothly when surprises happen.
When companies only focus on cutting costs instead of keeping processes stable, their systems become too rigid and can break down from even small problems. Many factories try to copy Toyota without realizing how important Toyota’s buffers really are.
A Moment from the Floor That Changed My Thinking
Years ago, when I was working on an automotive transmission assembly project, I had an experience that changed how I see lean systems. We promised to make 6,000 machined parts a week for a major customer. In pre-production, our lean setup, quick changeovers, standardized work, and quality systems all worked great. The customer even said our line looked “as efficient as a stopwatch.”
But two months after starting full production, everything came to a halt.
Our main 5-axis CNC machine broke down. Normally, we would have used a backup machine or another fixture, but both had been removed to make things ultra-lean. The replacement part would take four weeks to arrive.
I still remember the moment the maintenance technician walked into my office, hat in hand, and told me,
“We are down, and we are not coming back up anytime soon.”
Within an hour, the whole production process stopped. Supervisors asked for emergency help, planners scrambled to make new schedules, and operators stood by their stations with nothing to do. The next morning, customers started escalating issues. All the efficiencies that had impressed auditors disappeared instantly because the system wasn’t resilient.
That experience taught me a lesson I’ve remembered ever since:
A lean system without strategic backups is not lean; it is fragile.
Why Hyper-Lean Systems Break Down in Today's Manufacturing Environment
In the last ten years, manufacturing has become much more unpredictable. Supply chains change without warning, engineering changes happen more often, customers expect more, and labor shortages and old equipment make things even harder.
In this kind of unpredictable environment, hyper-lean systems seem efficient when everything goes right, but they fall apart quickly when something goes wrong.
A Real Example: When One Missing Bolt Stopped a Plant
At a tube manufacturing plant I worked with, one bearing failure stopped a production line worth millions. The bearing cost less than fifty dollars, but there was no spare because the company followed a strict zero-inventory policy.
It took almost twenty hours to get a replacement. In that time, three shipments were missed, and the overtime costs wiped out a month’s worth of planned savings.
That’s not lean—that’s creating your own problems.
The Human Effects of Bare-Minimum Staffing
At 8:10 a.m., I saw a production supervisor packing assemblies by hand. One operator had called in sick, and without floaters, cross-trained staff, or any backup, the production plan fell apart in the first hour.
The supervisor pulled me aside and said something that stayed in my mind:
“We're not lean—we're just exhausted.”
The hidden productivity losses that no KPI reveals, hyper-lean systems often mask their biggest losses behind attractive metrics. Metrics like OEE and scrap rates may appear satisfactory, even while actual productivity declines.
The Decision-Latency Trap
In a solar component operation I led, a batch of roll-form tooling developed subtle dimensional drift. Normally, we would have used backup tooling to keep the line running during evaluation, but it had been removed as part of a corporate “efficiency” initiative.
As a result, the line sat idle while engineering and quality teams worked with the customer to resolve the issue. No KPI showed this delay, but the cost was higher than any spare die.
Premium Freight: The Silent Counterweight to "Efficiency"
I’ve seen plants spend $5,000 on rush shipping to fix problems caused by cutting $800 worth of safety stock. This kind of imbalance almost never shows up on scorecards.
Overburdened People Become an Invisible Liability
Lean principles warn against unevenness and overburden, but hyper-lean systems end up causing both. Without relief operators or time to solve problems, fatigue becomes the most expensive kind of waste.
Lean Using Resilience: A More Realistic Model for Modern Manufacturing
Today, operational excellence means being strong, not just lean. This means using lean principles but also being able to handle changes. I call this Lean with Resilience.
A resilient lean system adds strategic buffers only where they help prevent breakdowns, like before bottlenecks, ahead of long-cycle machines, or for critical finished goods. It keeps backup capacity where failures are likely, using spare fixtures, extra gages, and alternate inspection paths instead of full redundancy.
It depends on flexible staffing, with a focus on cross-training, rotating floaters, and using people based on their skills. Schedules are based on real variation, not just ideal ERP forecasts, and they include preventive maintenance, realistic workloads, and time for changeovers.
Most importantly, it makes decision-making stronger. As systems get leaner, decisions need to be made faster. Clear escalation paths, local authority for routine approvals, and onsite engineering support help stop small problems from turning into big productivity losses.
Lean Alone Is No Longer Enough
A plant that is only lean is fragile. A plant that is both lean and resilient can compete.
The goal isn’t to get rid of every buffer or all slack. The main aim is to keep things moving, handle disruptions, protect workers, and deliver reliably as things change. The best manufacturers balance being lean to cut waste, resilient to handle problems, and flexible to keep productivity up.
These factories are built for both efficiency and endurance.
A Feasible Next Step for Operations Leaders
When I visit a plant today, whether it’s steel, castings, roll-forming, or renewables, I don’t start by looking at inventory or takt boards. I look for weak spots.
  1. Where could this system fail if something unexpected happens?
  2. Who is the operator responsible for addressing the system’s weaknesses?
  3. Where has the drive for efficiency quietly pushed out resilience?
Start by fixing these areas. Bring back controlled resilience where it matters most. That’s the real foundation of strong operations.
LEARN MORE
  • Don’t Ignore Gravity: Lean Management Laws for Better Problem-Solving
  • The Role of Lean Daily Management in Sustaining a Lean Culture
  • Expanding Lean Waste: The Case for Material Underutilization
KEYWORDS: continuous improvement lean manufacturing manufacturing metrology process control
Venkata Ravi Kumar Jonnalagadda is an engineering and quality leader with 15+ years of experience across the automotive and renewable energy sectors. He has led factory startups, new product development, product launches, IATF 16949 and ISO 9001 quality systems, and lean manufacturing initiatives, driving operational excellence and process improvement. https://www.linkedin.com/in/jvravikumar/
  • With CMM automation, look at the whole value stream.
    Improving Your Manufacturing Productivity and Quality with CMM Networking and Automation
  • Hexagon acquisition 3D Systems Geomagic
    Hexagon Supercharges Design, Manufacturing Productivity with Geomagic Software Acquisition
  • QTY 0921 Quality 101 feature photo 1170x878
    Lean 101: An Introduction to Lean Manufacturing
  • Lean Automation DVD
  • Lean Manufacturing: A Plant Floor Guide
  • Levinson Productivity Systems P.C.
    Industrial statistics, quality management systems (ISO 9001), and lean manufacturing.
  • Productivity Engineering Services LLC
    PES is your go-to source for cutting-edge industrial engineering and operations management consulting services! From factory planning and plant layout design to process improvement, we optimize operations to achieve world-class performance. We're not just consultants, we're partners, building trust through collaboration and delivering measurable results that turn heads (and profits).
  • GBMP Consulting Group
    Founded in 1994, GBMP Consulting Group is a not-for-profit organization dedicated to helping its clients increase their productivity, profits, and employee engagement through customized Lean & Six Sigma training. Our Lean training philosophy is based on the principles of The Toyota Production System. As a licensed Shingo Institute affiliate, GBMP also offers best-in-class Shingo Model™ training.
