Home » Topics » Channels » NDT
NDT RSS Feed RSS
NDT on the Flight Line
A midair engine failure in April puts nondestructive inspections to the test
Jesse Herrin
July 8, 2018
On April 20, three days after a Southwest Airlines Boeing 737-700 experienced an engine failure due to a fractured fan blade, resulting in the death of a passenger, the U.S. Federal Aviation Administration issued an emergency airworthiness directive that requires operators of CFM56-7B engines with more than 30,000 flight cycles to perform a one-time ultrasonic inspection of all 24 fan blades to detect cracking.
additive manufacturing
Producing Quality Metal Parts with Additive Manufacturing
Learn more about the entire 3D printing process from powder characterization to determining the best tests to qualify parts for the aerospace industry.
Cynthia Hagan Larry Somrack
July 1, 2018
The aerospace industry is increasingly adopting metal additive manufacturing for both flight safety-critical aircraft parts and non-critical flight parts. The approach offers a shorter development cycle, which means products can be developed quicker and design changes easily incorporated.
AS9100 Certification: Why and What Next
The standard says that people should understand the importance of what they do.
Brendon Hill
July 1, 2018
I was a group quality manager for an engineering company that made aero-engine parts. As part of the culture change program, I gave a presentation on examples of aircraft crashes and causes. A poorly machined blisk that caused an in-flight turbine failure, an oil-pipe with a thin wall in one area that cracked and leaked causing a fire, and an incident I personally saw, the crash of a military helicopter in Germany which was due to a series of quality failures.
Residual stress measurements
Improvements in Aluminum Aircraft Components Using X-ray Diffraction Residual Stress Measurements
Residual stresses can be controlled in the manufacturing process to produce a superior product that will last even in harsh environments.
Daniel Klawonn Beth S. Matlock Will McAlexander
July 1, 2018
The push for increased fuel efficiencies has pushed the aerospace industry to develop stronger and lighter materials while simultaneously increasing component longevity. In turn, these new designs, materials, and processes require verification.
NDT HEADLINE
Premium Inspection & Testing Group Acquires Quality Testing Services Inc.
June 22, 2018
Quality Testing Services Inc. is a St. Louis-based provider of nondestructive testing (NDT), calibration, training and consulting.
NDT WEB EXCLUSIVE
Eddy Current NDT Equipment Market to Reach $538 Million by 2026
June 8, 2018
Aerospace market, increasing number of oil and gas refineries to fuel growth of eddy current NDT equipment market through 2026.
There are many variables to consider when developing an NDT training program.
Nondestructive Testing Training
Having spent years in the NDT field, I can attest to the importance of a quality NDT training curriculum.
Donald Booth
June 8, 2018
The importance of nondestructive testing training cannot be overstated. What nondestructive testing technicians do every day has a huge impact on the lives around them. Well trained and qualified technicians provide accurate results for prevention of failures in components or structures.
XRF coating thickness measurement
With XRF Measurement, the Goal is Achieving Low Limits of Detection Precisely—and Fast
Here’s how to get there.
Jun Choi
June 8, 2018
X-ray fluorescence is an elemental analysis tool that has been a mainstay of test labs for decades. A versatile NDT method that demands only minimal sample prep and can be run by novice operators, it is perhaps most valued for delivering accurate results quickly. Today, evolving XRF capabilities are moving this quality assurance workhorse into critical new roles in a widening spectrum of industries.
Maximum signal stability thanks to active temperature compensation.
The Precision of a New Generation
Eddy current sensors have continuously improved and adapted to new requirements.
Stefan Stelzl
June 8, 2018
Eddy current displacement sensors combine several advantages. They provide high precision and resolution on a wear-free, noncontact basis. They are resistant to external influences such as dirt, pressure and fluctuating temperatures and therefore are ideally suited to harsh industrial environments.
NDT HEADLINE
Carestream NDT Partners with aycan Data Management
June 6, 2018
Carestream Nondestructive Testing has formed a partnership with aycan Data Management, a worldwide provider of NDT DICONDE data management solutions.
Previous 1 2 … 38 39 40 41 42 43 44 45 46 … 168 169 Next
