Color Consistency in a Multisite World: How to Standardize Across Locations
Establishing clear color benchmarks is the first step in any effective multisite quality control program.
By Greg Shrider, Noah Morgan, Rae Roby, Sherri Thompson
Rainbow blend layers abstract horizontal background.
Image Source: filo / DigitalVision Vectors / Getty Images
August 28, 2025
Color consistency is critical in maintaining product quality and protecting brand reputation in manufacturing. With global supply chains growing in complexity and production distributed across multiple sites, maintaining consistent color appearance becomes a greater challenge. Variations in materials, environment, and instrumentation can introduce inconsistencies where color is critical. However, with the combination of precision measurement tools, integrated quality systems, digital standards, and proper training, global manufacturers can achieve reliable color uniformity across manufactured batches as well as locations around the world. This article discusses technologies and strategies that make consistent color control in a multisite world feasible.
The Challenges of Multisite Color Consistency
Variations in the Environment
Standardization is essential for effective color communication and coordination across multiple locations. The first step begins with establishing clear methods for visually evaluating color differences and accurately describing what you observe. Using consistent, controlled lighting ensures that all color evaluations are made under the same visual conditions. Light booths or luminaires with standardized illuminants help simulate real-world environments and reduce subjectivity. Performing color analysis under multiple light sources is also beneficial for checking metamerism. By coordinating lighting conditions during visual inspections and instrument measurements, manufacturers can ensure consistent product appearance across the entire supply chain.
Surrounding colors can greatly influence visual color perception. For consistency, all walls, fixtures, or tables in or around visual color checking areas should be painted with gray paint (target color Munsell N7). This action minimizes the impact of the surrounding environmental conditions that can influence the appearance of the colors being evaluated. Light booths mimic these standardized conditions and are, therefore, a preferred option for visual analysis on small samples.
For optimal lighting selection, always adhere to the international standard relevant to your industry. To ensure compliance, consult the table below for recommended light sources and illumination levels.
Light Source Selection and Illuminant Specification Chart
ISO 3668
ASTM D1729
DIN 6173
SAEJ 361
Main Illuminant
D65
D65/D50/D75
D65
D65/Horizon
(~ D50)
Illuminants for Metamerism
A
A/F2/F11
Nd
F2
Level of Illumination
1000 - 4000 lx
1080 – 2150 lx
1000 – 5000 lx
1080 – 1730 lx
Color of Interior
Matte neutral grey (a*,b* < 1)
General:
L*= 45-55
Light color L* > 65
Dark color L* = 25
Matte neutral grey
N6 – N7,
(~ L* = 61-71)
Matte neutral grey
Matte neutral grey
N6 – N7,
(~ L* = 61-71)
Subjectivity in Visual Assessment
Human color perception varies due to differences in cone cells (cells sensitive to red, green, and blue) and rod cells (cells sensitive to lightness/darkness) sensitivity found in the eye. Therefore, it is recommended that visual color sensitivity testing be performed on individuals who are responsible for critical color matching. Tests like the Ishihara Color Plates identify color blindness, while tests like the Farnsworth 100 Hue test specifically check for an individual’s ability to recognize subtle differences in hue across the visible spectrum.
Instrumentation
  • Color Measurement 101: The Basics of Managing Color throughout Production
  • Cloud-Based Workflow Delivers More Consistent Brand Colors
  • Maintaining Data Integrity in Color Management and Quality Control
LISTEN
  • Solve Color Measurement Challenges | Quality Podcasts
Instrumentation elevates color control by offering objective data, but only if tools are consistent across sites. Multisite programs should use spectrophotometers with the same geometry (e.g., d/8, 45/0, or multiangle) to ensure data comparability. Each instrument type is designed to measure different aspects of color and produce spectral reflectance data, making the measurement geometry critical if you need to share or compare data from plant to plant. In addition, routine maintenance and annual recertification ensure continued accuracy and data confidence.
When considering spectrophotometers for multisite or supply chain solutions, one needs to assess repeatability and reproducibility. Repeatability is simply the ability of an instrument to repeat the exact measurement on a white standard. The typical range is 0.01 – 0.05 Delta E. Reproducibility is stated as inter-instrument agreement with a range of 0.08 – 0.30 Delta E. When considering digital standards and multisite color measurement networks, the inter-instrument agreement is the most critical specification.
Quality Integration
Establishing clear color benchmarks is the first step in any effective multisite quality control program. When production spans multiple locations, standardized color specifications ensure all teams are targeting the same visual expectations. Key elements of the program include standardizing illuminants and observers, selecting the appropriate spectrophotometer geometry, choosing the correct color difference equations, and aligning digital standards with visual evaluations. It’s also essential to define workflows, select software, and determine how data can be shared. The program should extend to external partners like suppliers, distributors, and customers. Clear communication and shared expectations, supported by data and international standards such as ASTM or ISO, help ensure color consistency and strengthen collaboration across the supply chain.
Digital Color Standards
Digital color standards offer a more consistent, efficient, and reliable approach to color control compared to physical visual samples. They eliminate inconsistencies caused by lighting, surroundings, or human perception, providing objective, repeatable benchmarks for color evaluation. By measuring a physical master standard and converting it into digital form, manufacturers can preserve the master standard and digitally share the master spectral reflectance data and tolerances across sites via any file-sharing software.
Digital standards also integrate with spectrophotometers and quality software for fast, automated evaluations. These standards help ensure every location works with the same color reference and specification. Ideally, each manufacturer should have a designated location/department that manages and releases all digital standards for each plant and supply chain to ensure consistency between raw materials and products.
Historically, master panels or color chips have been used as internal physical color references at multiple locations and plants around the world. If physical standards are still in use, routine audits and timely replacements are essential to maintain color accuracy. For best practice, storing the physical master in a cool, temperature-controlled, dark environment retains its integrity, while working standards can be used for visual comparisons.
Training and Communication
Implementing a successful multisite color measurement program involves many considerations, but at its foundation is a strong, well-executed training program. Whether the program is launched to solve a color issue or to meet new business demands, it requires a dedicated champion, someone with color expertise or a willingness to learn, who can lead the effort and build a consistent, company-wide approach. This leader often forms a team with representatives at each site, assigning a “go-to” person responsible for ensuring local adherence to the corporate color standards.
Case Study: Optimizing Consistency—and Customers—with Digital Color Standards
A global plastics manufacturer was on the brink of losing a major client due to persistent color inconsistencies across production batches. Despite strict visual inspections and the use of multiple standard color chips, parts made at different locations around the globe did not match. The mismatch led to mounting complaints, costly rework, and a risk to brand reputation.
To address the issue, the company partnered with a reputable instrument company, replacing outdated tools with new generation spectrophotometers capable of utilizing digital color standards across production and QA teams. The new instruments with digital color standards created a closed-loop color matching program, ensuring color standards developed by R&D could be digitally shared with each production and quality team across the globe, guaranteeing every location matched the exact color metrics and tolerances. Instruments were integrated with existing QC software, enabling real-time, objective evaluations and global harmonization on tolerances and specifications.
The results were immediate: rework dropped by over 40%, throughput increased, and—most critically—the at-risk client renewed their long-term contract, citing vastly improved color consistency.
Lesson learned? When visual quality defines your brand, switching to standardized, data-driven color control isn’t just a technical upgrade; it’s a business-saving decision.
KEYWORDS: color measurement manufacturing metrology quality
Greg Shrider – BYK-Gardner USA. For contact information, call (301) 483-6500 or visit byk-instruments.com.
Noah Morgan – BYK-Gardner USA. For contact information, call (301) 483-6500 or visit byk-instruments.com.
Rae Roby – BYK-Gardner USA. For contact information, call (301) 483-6500 or visit byk-instruments.com.
Sherri Thompson – BYK-Gardner USA. For contact information, call (301) 483-6500 or visit byk-instruments.com.
  • These items are Pre-painted Galvanized Steel Coils (PPGI) used primarily as building materials for roofs, walls, and workshops.
    Futureproofing Quality: Trends in Digital Color and Appearance Management
  • Wenzel CMM
    Consistency in production, efficiency to meet changing demands.
  • Cropped and blurred image of a man touching the screen with ISO and globe icons on smart background.
    Configuration Management: Consistency in Product Performance and Design Throughout Its Lifecycle
  • Florida Standards Lab Inc.
    Florida Standards Laboratory was founded in 1960 to accommodate the industry's need for a modern, independent source for test & measuring equipment repair, calibration and maintenance services. We pride ourselves on maintaining staff with years of experience, and keeping our facilities stocked with state-of-the-art equipment to meet requirements and exceed expectations. ISO 17025:2017 accredited calibrations available. We provide: "World Class Service - One Customer at a Time."
