Home » Topics » Channels » Test & Inspection
Test & Inspection RSS Feed RSS
David Valdez, 2020 Inspector of the Year from ASQ’s Inspection Division
Air Force Master Sergeant Honored as 2020 Inspector of the Year from ASQ’s Inspection Division
April 20, 2020
The ASQ Inspection Division will honor United States Air Force (USAF) Master Sergeant David A. Valdez as the 2020 Chuck Carter International Inspector of the Year. Valdez will be acknowledged at an award cermony to be held later this year.
machine shop
Evolving Quality Processes Propel Growth
All inspectors are initially trained in first article inspection and then on assembly, sheet metal, and CMM inspection.
Mari Luke
April 8, 2020
Mike Terrell is the quality assurance manager at B&B Airparts Inc., a machine shop that specializes in manufacturing high precision parts for aerospace OEMs. B&B Airparts Inc. has been in business for over twenty years, offering machining, sheet metal fabrication, and assembly capabilities.
Symbrium gear test stands
Multi-Axis Motion Controller Accelerates Gear Testing
The testing can be used in a pre-production environment as companies evaluate changes in materials designed to improve the characteristics of end products.
Reid Bollinger
April 8, 2020
Materials testing and characterization is often a lengthy process. It can take more than a year and billions of testing cycles for a manufacturer to characterize the properties of a new metal alloy to be used in a critical application, such as a component of an automotive or jet engine.
X-ray image
Nondestructive Inspection of Automotive Computers
As with the testing and evaluation of raw materials, controlling the quality of electronic devices is essential
Satoshi Iguchi Akane Garner
April 8, 2020
In the automotive industry, quality control/assurance has often focused on the physical testing and evaluation of raw materials and finished products. From a safety perspective, it is imperative that the strength of these materials and products meets established standards. Tensile, compression, bending and hardness tests are used for these evaluations.
handheld XRF analyzer
X-Ray Fluorescence (XRF) Frequently Asked Questions
You can point an XRF analyzer at almost anything and get a result.
Ted Shields Sr.
April 8, 2020
When we talk to customers who are interested in learning more about XRF, there are some questions that we answer all the time. Check out some of the most frequently asked questions and their answers below.
Gleason
Gleason Metrology Systems Expands Accredited Calibration Services
April 7, 2020
Gleason Metrology Systems’ A2LA Accredited Gear Calibration Laboratory has added ISO/IEC 17025:2017 accreditation and invested in new metrology equipment to expand the scope of its gear calibration services.
ATEC Announces Rental Partnership With JULABO USA
April 7, 2020
Advanced Test Equipment Rentals announced a new rental partnership with JULABO USA.
collaborative robot
Quality in Automation > Robotics
The Need for 3D Imaging Performance Standards for Robotic Assembly
NIST is working with the 3D imaging industry to develop performance standards for systems that can be used for robotic assembly applications.
Kamel S. Saidi
April 6, 2020
Manufacturing often involves the fabrication of products that are made up of multiple smaller parts or components. Assembling these parts into finished products can be complex and labor intensive.
robots
Quality in Automation > Trends
The Latest Trends on the Shop Floor
Automation has made closed-loop metrology systems, nondestructive testing and productivity increasingly accessible.
Genevieve Diesing headshot
Genevieve Diesing
April 6, 2020
As developments in machine learning and the Internet of Things (IoT) impact how manufacturers run their businesses, automation can support these changes and boost productivity.
XRF coating thickness measurement instrument
The Right Detector
XRF systems use one of several types of detectors.
Zach Dismukes
April 4, 2020
Electroless nickel (EN) is industry’s most common plated finish. It’s widely used for applications that demand wear resistance, hardness and corrosion protection—particularly if parts have complex geometries. It is also used in PCB manufacturing within a process known as ENIG, electroless nickel immersion gold.
Previous 1 2 … 23 24 25 26 27 28 29 30 31 … 91 92 Next
