The Quality Industry Voices Management
Guest Column | Travis Ellinger
Capability Study Showdown: 30-Piece vs. 125-Piece Explained
Why the 125-piece study provides improved accuracy and reliability in decision making.
By Travis Ellinger
A male warehouse worker wearing a safety uniform and a helmet inspects the quality of products with a laptop computer in a storage warehouse.
Image Source: Amorn Suriyan / iStock / Getty Images Plus
September 1, 2025
In the world of manufacturing and quality engineering, process capability studies are important tools used to determine whether a process can produce parts within specification limits consistently. Two common approaches when analyzing process capability include a 30-piece study and a more comprehensive 125-piece study. Both studies serve the same basic purpose, but they differ significantly in methodology, statistical power, and scope.
In this article, we will explore the background of each study type, and decision-making criteria for selecting the appropriate method. We will also look at why the 125-piece study provides improved accuracy and reliability in decision making.
Background and Purpose of Capability Studies
  • Control Charting Integration with Process Capability and Enhanced KPI Reports
  • Why Measurement System Analysis Student Capstone Projects Lead to Lasting Benefits
  • Building Trust: The Role of QA/QC and Specialized Inspections in High-Stakes Manufacturing
Process capability studies evaluate how well a manufacturing process meets specification limits by comparing the variability of the process output with design tolerances. Capability studies are typically performed using one of two statistics:
  • Cp/Cpk (Process Capability Index): Measures how centered and consistent the process is within the specification limits.
  • Pp/Ppk (Performance Capability Index): Similar to Cp/Cpk but includes long-term variation. This is useful for initial process evaluation.
The goals of capability studies include:
  • Verify that a process is stable and under statistical control.
  • Assess whether a process can reliably produce parts within specification limits.
  • Provide a statistical basis for continuous improvement or redesign.
30-Piece Capability Study: A Common Starting Point
The 30-piece capability study is widely used, especially early in the developmental stages or setup. It involves measuring 30 consecutive parts from a stable process and calculating basic statistics such as mean, range, and standard deviation. This is most often used when:
  • Time or resources are limited.
  • A rapid assessment of capability is needed.
  • The process is in its early development stages and under close monitoring.
Advantages:
  • Quick and cost-effective.
  • Requires minimal sampling effort.
  • Sufficient for preliminary or short-run validation.
Limitations:
  • Small sample size reduces statistical confidence.
  • Limited ability to detect variation trends (e.g., shift, drift, special causes).
  • Poor representation of long-term performance.
125-Piece Capability Study: 25 Subgroups of 5
A 125-piece capability study using 25 subgroups of 5 provides more accurate statistical insight. Each subgroup of 5 parts is collected over time (e.g., every hour, shift, or lot), capturing the process’s natural variation more effectively.
Advantages:
  • Higher statistical confidence due to increased sample size.
  • Subgrouping allows for calculation of within-group and between-group variation.
  • Enables more accurate estimates of process standard deviation.
  • More reliable detection of special cause variation.
Limitations:
  • More time-consuming and resource-intensive.
  • Requires a stable process over a longer period of time.
  • May be excessive for short-run or low-risk parts.
Comparison of Data Distributions
The histogram below shows the distribution difference between a 30-piece study and a 125-piece study. Both datasets are sampled from the same distribution (mean = 5, standard deviation = 1.5), but the larger sample size in the 125-piece study produces a more pronounced and representative distribution:
Graph: Distribution Comparison: 30-piece vs. 125-piece Capability Study
Image Source: Strategic Manufacturing Solutions
As shown, the 30-piece histogram is more irregular due to its limited sample size, whereas the 125-piece histogram better approximates a normal distribution, resulting in statistical conclusions that are more reliable.
Why the 125-Piece Study Produces Improved Results
The superiority of the 125-piece study comes from its statistical robustness:
  1. Improved Estimation of Standard Deviation: A larger sample size allows for more accurate estimates of standard deviation, which directly impact the accuracy of both the Cp and Cpk calculations.
  2. Improved Process Variability Detection: Subgrouping across different times (hours, shifts, etc.) captures both short-term and long-term variability, allowing the study to differentiate between common cause and special cause variation.
  3. Control Chart Utilization: The subgroup format enables the use of control charts, such as X-bar and R or X-bar and S charts, which are instrumental in monitoring process stability / drift over time.
  4. Greater Confidence for Decision Making: Capability studies enable critical decisions such as process qualification, production release, or need for corrective action. 125-piece studies reduce the risk of false conclusions.
  5. Customer and Industry Standards: Some customers in industries, such as automotive or aerospace, require 125-piece studies (or more) to meet quality standards. You can find these requirements defined in customer specific requirements for industry action group manuals like AIAG’s Statistical Process Control manual (AIAG, 2023).
Choosing between a 30-piece and a 125-piece capability study depends on the situation a manufacturer is dealing with, the criticality of the part, and the required confidence level. While a 30-piece study is valuable for quick assessments, 125-piece studies provide significantly more accurate and comprehensive understanding of a process’s capability. In quality-critical industries, where precision and reliability are paramount, the 125-piece capability study is a preferred and often required method.
By understanding the strengths and limitations of each approach, engineers and quality professionals can make informed decisions that balance time, cost, and statistical reliability to ensure the success of their manufacturing processes.
Works Cited
AIAG. Statistical Process Control (SPC) Manual. 2nd ed., Automotive Industry Action Group, 2023.
Montgomery, Douglas C. Introduction to Statistical Quality Control. 8th ed., Wiley, 2020.
Wheeler, Donald J. Understanding Variation: The Key to Managing Chaos. SPC Press, 2021
KEYWORDS: continuous improvement manufacturing process control quality quality professionals
Travis ellinger author headshot 200x200
Travis Ellinger is the president and founder of Strategic Manufacturing Solutions. Having engaged with hundreds of manufacturing facilities over his career, he is a highly sought-after manufacturing consultant with extensive experience implementing strategic solutions that provide significant return on investment to his clients. Travis has 20 years of management and consulting experience and is an alumnus of Ford Motor Company, Lear Corporation, and Wilhelm Karmann GmbH. He brings a unique blend of strategy, business acumen, shop floor knowledge, and a deep understanding of people, organization, and culture. [email protected]
linkedin.com/in/travisellinger
  • Q-Cast Podcast with Travis-Ellinge 1170x658 feature article
    VIDEO PODCAST | The Right Capability Study
  • Initial Thirty-Piece Sample
    The Limits of the Thirty Piece Sample
  • NDT1124-FEAT-Test-p1-Image 1_Preparing VCI Film Strips for VIA Testing.jpg
    Corrosion Testing: An Important Piece of the Quality Assurance Puzzle
  • Single Piece Flow DVD
