Automation
AI
5 Ways to Use AI for Process Automation with Human Oversight
AI-enabled governance, risk and compliance (GRC) for quality leaders
By Jeff Ladner
This image depicts a business strategy meeting focused on risk management and data analysis.
Image credit: Weedezign via iStock/Getty Images Plus.
February 15, 2026
Governance, Risk and Compliance (GRC) teams are expected to keep audits moving, close corrective actions, manage supplier issues, maintain training records, meet customer requirements and stay ready for whatever regulators expect next. Increasingly, the same discipline is now being applied to risk and compliance work in a way that’s repeatable, defensible and built to last.
AI can help alleviate some of the pressure for overburdened GRC teams. Used well, AI reduces time spent drafting, summarizing, organizing records and chasing evidence across systems. Used poorly, it creates a different kind of burden. A flawed output can steer teams toward the wrong corrective action, hide a recurring failure mode or weaken documentation that needs to stand up under audit. The opportunity is real, but it only pays off when AI is introduced with clear boundaries and review built into the workflow.
Why quality teams feel the pressure first
In manufacturing and industrial environments, quality teams become the “system of record” for a lot more than quality. They are tasked with tracking internal controls, risk and compliance obligations, supplier performance, customer requirements, incident investigations and training evidence. That creates two familiar problems.
First, the work is documentation-heavy. The value is in the judgment and follow-through, but hours get burned on writing, summarizing, reformatting and copying information between systems.
Second, the data is often dispersed across an organization. Critical details live in audit workpapers, corrective and preventive action (CAPA) narratives, supplier questionnaires, incident logs, emails, PDFs and spreadsheets. This fragmentation slows response time and increases the chances of missing a trend that an organization would need to identify early.
AI is well-suited for exactly these conditions: large volumes of text, repetitive administrative tasks and pattern detection across records.
Where AI can make quality and compliance work easier
AI delivers the most value in governance, risk and compliance operations when it supports preexisting workflows, rather than forcing a new process. Here are practical examples that map to familiar quality motions.
  1. Faster documentation without sacrificing consistency
     Quality teams dedicate a significant amount of time to drafting and refining control descriptions, test procedures, investigation summaries, supplier findings and policy updates. AI can help generate first drafts quickly, standardize language across records and reduce the “blank page” problem. The key is that a human still reviews, edits and approves.
  2. Better intake from long documents
     Supplier security assessments, SOC 2 reports and quality manuals often arrive as long PDFs. AI can extract key details and summarize them into structured fields, reducing re-keying that drags down cycle time.
  3. Cleaner records and fewer duplicates
     In real-world programs, the same incident is reported twice, the same finding appears in multiple places, and the same supplier document is uploaded with different file names. AI-assisted deduplication can flag overlaps, ensuring teams don’t split their efforts on duplicate work.
  4. Smarter linking across the program
     A quality program becomes easier to manage when risks, controls, incidents, CAPAs, audits and supplier obligations are connected. AI can recommend links based on context, making it easier to keep mappings up to date without the constant manual hunt.
  5. Better visibility for leadership
     Quality leaders don’t just need data. They need a coherent narrative. AI can help generate summaries, highlight trends and surface key exceptions so teams can spend less time building slides and more time guiding action.
Responsible AI adoption in quality
One of the most common reasons AI projects stall out is a lack of trust and explainability. Quality and compliance teams are asked to sign their names on outcomes, so they need confidence that AI support is controlled and defensible.
A responsible approach doesn’t require a massive new governance program. It requires a few non-negotiables.
Start with a policy people can easily follow.
Before adopting, leaders should clearly define what should never be fed into an AI system (confidential, regulated, customer-identifying, export-controlled). It’s important to clarify when to anonymize and when to escalate.
Keep humans accountable for outcomes.
If AI generates a CAPA summary, a person should review and approve it. If AI proposes mappings between controls and requirements, a person should validate them to ensure accuracy. The workflow should make the review obvious and trackable.
Build evidence as part of the workflow.
If you can’t show what happened, you can’t defend it. AI-supported work should leave an audit trail: what data was used, who reviewed the output, what changed and when it was finalized.
Pilot in low-risk areas first.
The best early wins are internal and repetitive. Best practices recommend avoiding starting with high-impact decisions where errors could impact safety, compliance obligations or customer commitments.
Expect data quality to matter
AI cannot deliver value to an organization if it’s running on broken inputs. If source documents are inconsistent, outdated or incomplete, the outputs will reflect that. Responsible rollout includes cleaning up terminology, record structures and ownership.
Additionally, AI can help capture institutional knowledge and instinct held by long-tenured team members. Codifying practices helps organizations reduce risk and stay ahead of knowledge gaps as roles and teams change over time.
How AI-enabled GRC fits into quality operations
Quality programs already run on governance, risk and compliance discipline: documented requirements, controlled workflows, evidence and sign-offs. AI support works best when it strengthens that same structure by reducing manual documentation, keeping related records connected and making status easier to see without extra reporting cycles. The technology also brings effective triage capabilities, surfacing the highest-risk issues first so experienced judgment is spent where it has the most impact.
Responsible adoption still matters. AI should be optional, configurable and governed, with review steps and audit trails built into the workflow so teams can scale what works without losing control.
The right outcome: less manual effort, more control
The best AI adoption strategy for quality isn’t “use it everywhere.” It’s “use it where it helps, prove it and keep it controlled.” When implemented this way, AI becomes a practical partner for quality leaders: faster documentation, cleaner records, shorter cycle times, better visibility and stronger audit readiness.
  • Updates are Coming to ISO 9001, 14001 and 45001
  • Why Is Corrective Action So Hard?
  • 3 Project Planning Recommendations to Ensure QMS Development Success
KEYWORDS: Artificial Intelligence (AI) continuous improvement manufacturing metrology process control quality
Jeff Ladner, Chief Product Officer, Onspring, a GRC workflow automation platform delivering real-time reporting through a flexible, cloud-based platform. With over 15 years of experience in product leadership, Jeff previously served as Chief Product Officer at Intelex Technologies ULC, where he led the company’s product and innovation strategy. At Onspring, he now oversees product management, development, and design, driving the company’s technology vision to deliver impactful, customer-centered solutions for modern GRC teams.”
  • Aerial view of general bulk cargo ship vessel on departure unberthing from the sea port terminal, assisted by a tug boat.
    5 Ways to Use Simulation to Navigate Tariff Challenges and Uncertainty
  • Q-cast article Justin Newell CEO INFORM
    Podcast: How to Use Trustworthy AI for Quality Control
    5 Ways to Make Sure You Can Trust Your Data
