Automotive
Automotive
Catching Defects Earlier: How Automotive Manufacturers Are Rethinking Inspection
Selecting inspection tools for a production environment involves more than matching technical specifications to quality requirements.
By Genevieve Diesing
Passenger vehicle driving on a paved road, representing automotive performance, durability testing, and real-world driving conditions.
Image credit: igoriss / iStock / Getty Images Plus (Creative #1493574434)
June 4, 2026
Automotive manufacturers have long relied on end-of-line testing to catch defects before vehicles leave the plant. Increasingly, that approach is giving way to something more proactive.
Quality professionals and inspection technology specialists say the industry is shifting inspection upstream, embedding it earlier and more frequently in the production process to catch problems at their source rather than after they’ve compounded. As vehicle electrical systems grow more complex and production volumes stay high, manufacturers face growing pressure to find defects before significant time, labor and material investment is lost. That means rethinking not just when inspection happens, but what it can detect and how fast it can work.
Moving Inspection Earlier
The push toward earlier defect detection is particularly pronounced in wire harness and cable assembly, where electrical interconnects are increasingly tested immediately after assembly rather than at the end of the line.
“Automotive manufacturers are moving defect detection as early as possible into the cable and wire harness assembly process, rather than relying on end-of-line system testing,” said a technical marketing manager at CAMI Research. “Because wiring issues can be difficult and time-consuming to diagnose once installed in a vehicle, early-stage testing helps isolate problems at their source.”
The same logic applies elsewhere on the line. Sanjai Keshavan, president of Jenoptik Automotive North America, said today’s typical production line embeds inspection equipment at multiple strategic points throughout, not just at the end.
“In-process inspection is where the industry is migrating towards,” Keshavan said. “In the production of a crankshaft, for example, the crankshafts are measured after each material removal step and then inspected finally.”
Ian Scribner, product sales manager at ZEISS, said just-in-time manufacturing has accelerated this trend by requiring real-time decisions on the shop floor.
“Manufacturers are pushing to get inspection as close to the production line as possible and, in best-case scenarios, directly in-line,” Scribner said. “The idea is to spot defective parts or production issues before significant value is invested in a part. Customers don’t want to spend time painting a stamped component if it’s already defective, or waste time machining a casting that is already out of spec.”
The Defects That Are Hardest to Find
Earlier inspection matters most when the defects themselves are elusive. Quality professionals point to a category of flaws — particularly in electrical systems — that traditional methods routinely miss.
CAMI Research identified intermittent connections, marginal crimps, high-resistance paths, and insulation breakdown as among the most difficult to detect. Visual inspection cannot reliably catch these issues, particularly in complex harnesses with hundreds or thousands of connections. Even basic electrical checks may come up short.
“A connection might pass a simple continuity test but fail under higher current conditions,” the representative said. “These “hidden” defects are a major source of field failures and warranty issues.”
The challenge is compounded by automotive voltage standards. Because vehicles operate at 12 volts DC (a relatively low voltage), delivering power to components requires proportionally high current. This makes resistance variations and connection quality especially consequential.
Scribner noted that the hardest defects to address depend on the part, but that the common thread is inaccessibility, features that neither vision systems nor contact probes can reach.
“The hardest defect to measure is the defect you can’t see or sometimes even reach,” he said. X-ray computed tomography, he added, can address some of those challenges by capturing features hidden from conventional methods.
Keshavan pointed to defects that require manual operator checks as particularly vulnerable to inconsistency. When inspection depends on individual judgment, results vary, and labor intensity can limit how thoroughly manufacturers apply it.
Inspection Technologies That Keep Pace
Faster production lines demand inspection systems that can match their speed without sacrificing accuracy. Manufacturers and technology providers are pursuing several strategies to close that gap.
On the electrical testing side, one area of advancement involves high-precision insulation testing at very low voltages. The CAMI Research representative described new capabilities that allow manufacturers to measure leakage resistance at extremely high levels — on the order of gigaohms — using test voltages low enough not to stress sensitive components. This type of measurement is becoming increasingly relevant as wiring harnesses grow denser and electric vehicles introduce high-voltage circuits in close proximity to low-voltage control systems.
“Ensuring strong isolation between conductors is critical for both safety and performance,” the representative said. “Even extremely small leakage paths can pose risks, especially as systems age or are exposed to heat, vibration, and environmental stress.”
Keshavan said optical measurement is one of the tools inspection system developers lean on to keep pace with line cycle times, since light-based measurement is faster than contact-based methods. Adding multiple sensors and coordinating part loading and unloading with the measurement cycle helps prevent inspection from becoming a bottleneck.
Scribner pointed to software advances, including tools that simulate real-world clamping conditions and material behavior using 3D scan data, as another way manufacturers are streamlining inspection without adding physical fixturing.
“Virtual clamping and de-warp tools use high-resolution 3D scan data to simulate how a component will perform in its assembled state without the need for physical fixtures,” Scribner said.
Choosing the Right Inspection Technology
Selecting inspection tools for a production environment involves more than matching technical specifications to quality requirements. Experts say usability, durability, and integration support are equally important factors.
The CAMI Research representative emphasized that a difficult-to-use system will underperform regardless of its capabilities.
“A reliable, easy-to-use system that operators trust and use consistently will deliver better long-term quality results than a more complex solution that is underutilized,” CAMI Research said. Flexibility is also a consideration, particularly in automotive production, where design updates and multiple product variants are common.
Keshavan pointed out that equipment designed for controlled laboratory environments often fails in the realities of 24-hour production.
“The gages that work in environmental controlled quality labs do not necessarily work on the shop floor,” he said. “Manufacturers should look for machines designed to absorb the rigors of 24x7x365 production and harsh environment.”
Scribner stressed the importance of choosing vendors who can deliver a complete solution — hardware, software, deployment, and ongoing support — rather than assembling components from multiple providers.
“There are too many failure points coming from multiple providers that can cripple a production line the moment an issue arises,” Scribner said.
The Data Challenge
As more inspection systems move in-line and generate data continuously, manufacturers face a different kind of problem: too much information without the infrastructure to act on it.
Scribner said comprehensive data management software is becoming as important as the inspection equipment itself.
“More data can lead to paralysis by analysis, making it difficult to see the bigger picture,” he said. “It’s important to be able to pull information from the production line, but it’s also important to be able to visualize it and store it in a way that enables real-time decision-making.”
The CAMI Research representative echoed that point from a practical standpoint, noting that thorough testing only delivers value when manufacturers test every assembly, not just a sample.
“When testing systems are fast, intuitive, and easy to adapt, manufacturers are more likely to test every assembly,” CAMI Research said. “Investing in the right tools early in the process helps manufacturers avoid costly downstream issues and ensures long-term product reliability.”
As vehicle electrical complexity continues to increase, particularly with the growth of EVs, the ability to perform complete, repeatable testing at speed is becoming less of an advantage and more of a baseline expectation.
  • Driving the Future: Transforming a Manufacturing Plant into an EV Hub
  • Energy Costs, EV Growth Drive Changes in Leak Testing Methods
  • EV Batteries: Materials Quality Testing to Avoid Bumps in the Road
KEYWORDS: data collection machine vision manufacturing metrology quality
Mug genevieve headshot
  • Close up of an AHP ball joint tester system.
    A Challenge and A Solution: Automotive Manufacturers Can Do Something They Simply Couldn't Before
  • This image shows a man in a factory setting with a laptop
    5 Changes Manufacturers are Making Today and for Tomorrow
  • QTY 0922 InfinityQS IC Topic 4 Editorial Updated
    Why More Manufacturers Are Turning to SPC
  • Mistake Proofing: Achieving Zero Defects DVD
  • Work Measurement DVD
  • February 17, 2026
    Quality Leaders Forum: How Automotive Leaders Are Redefining Quality
  • Inspection Technologies Inc.
    We are a manufacturers' Rep and distributor for all NDT Methods. We also manufacture our own Dye Penetrant Systems.
